  2. RF Design
  3. mtline model "Display Cross Section"
  • Replies 11
  • Subscribers 63
  • Views 10850
sohaiba
sohaiba over 14 years ago
As you know that there is now a cross sectional viewer button in the analogLib mtline component edit properties/add instance form.  The "Display Cross Section" button becomes visible when the Type of Input is set to Field Solver. The issue is that when I click on "Display Cross Section" button the IC 6.15 tool displays "Starting Displaying" .... in the CIW but does not display anything even after waiting for it to respond. What could be the issue?
Regards
  • Ashish Patni
    Ashish Patni over 14 years ago
    Hi Sohaiba,
    Which version of IC615 are you using?
    This issue has been seen in the earlier version of IC615 and was fixed in IC615 ISR2.
    Please refer to the following COS Solution -
    http://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:ViewSolution;solutionNumber=11709824
    With Regards,
    Ashish
  • sohaiba
     I am using IC6.1.5.72 . Please can you tell me exactly which version of hotfix should I download or do I need to download an updated base file to fix this ?
    Regards
    Sohaib
    Sohaib,
    Ashish already pointed out that this was fixed in ISR2. Since you can only load the latest hotfix (ISR12) from downloads.cadence.com (although a couple of previous ISRs are available if you pick the hotfixes in InstallScape) - but you might as well use the latest.
    There is no "updated base file". The whole point of a Base release is that it stays static...
  • Eduard Atkin
    Eduard Atkin over 6 years ago in reply to Andrew Beckett
    Andrew,
    in IC 6.1.8
    after I have filled the Edit Object Properties form:
    and clicked Display Cross-section button the CIW replied:
    What is a reason?
    Eduard
  • Eduard Atkin
    Eduard Atkin over 6 years ago in reply to Eduard Atkin
    ... and nothing happened. No window popped up.
    Andrew Beckett over 6 years ago in reply to Eduard Atkin
    Hi Eduard,
    Probably would have been best to start a new thread rather than on the end of an old thread from 8 years ago (for a specific bug which was fixed in IC615). My guess is that this is due to some missing library, but let's see. Try this:
    First create a file called (say) input.rlgc which contains:
    ;  lmgNumLines = 1
    ;  lmgNumLayers = 1
    ;  lmgDielectricLossType = tangent
    ;  lmgNumGndPlanes = 1
    Then in the terminal window type:
    lmgUI input.rlgc `cds_root lmgUI`/tools.lnx86/dfII/etc/tlg/displaylmg.tcl
    (note, those two quotation marks are back-quotes). Alternatively, in the terminal type:
    cds_root lmgUI
    and then see what the result of that is and pass the full path to lmgUI:
    lmgUI input.rlgc /export/home/apps/IC618_isr10/tools.lnx86/dfII/etc/tlg/displaylmg.tcl
    Let me know if it reports anything or whether the UI appears.
  • Eduard Atkin
    I have copied and pasted to create a file called input.rlgc (4 commented lines in it) in my current directory:
    ;  lmgNumLines = 1
    ;  lmgNumLayers = 1
    Then in the terminal I typed:
    cds_root lmgUI
    and got the reply:
    /tools/IC618
    When I typed:
    lmgUI ./input.rlgc /tools/IC618/tools.lnx86/dfII/etc/tlg/displaylmg.tcl
    No reports, no UI – silent reply.
    By the way the file /tools/IC618/tools.lnx86/dfII/etc/tlg/displaylmg.tcl exists.
    Are there any wrong actions?
    Thanks.
    Eduard
    Hi Eduard,
    Hmm, odd. Can you try two things:
    1. virtuoso -W
    2. wish /tools/IC618/tools.lnx86/dfII/etc/tlg/displaylmg.tcl input.rlgc
    I'm interested whether the second launches the UI.
  • Eduard Atkin
    Hello Andrew,
    user@dell:~/tsmc65$ virtuoso -W
    sub-version IC6.1.8-64b.500.2
    bash: wish: command not found
    which wish
    /usr/bin/which: no wish in ... ("$PATH")
    kind regards,
    Eduard
    Hi Eduard,
    Ah, that's the issue. It seems that the cross section UI (which calls lmgUI from the button on the mtline form) requires Tcl/Tk to be installed on the system and "wish" to be in the path.
    On my machine:
    UNIX> rpm -q -f /usr/bin/wish
    tk-8.5.7-5.el6.x86_64
    tk-8.5.7-5.el6.i686
    This is on a RHEL6.5 machine - it may need to be a different RPM on your machine. Essentially for me it's in /usr/bin/wish.
    So I think you'll need to get that installed. I think this is a pretty common package to have installed on Linux, so I'm a little surprised that it's not installed (I can't believe you wouldn't have /usr/bin in your path).
    If I remove wish from my path, I see the same symptoms that you do. Strictly speaking it just looks for "wish" in the path - so if you have wish elsewhere, you could use that. Whilst we do have Tcl/Tk in some of our releases, we don't have the wrappers set up to set up the shared library paths.
