  2. RF Design
  3. changing the simulator sampling time
  • Subscribers 63
  • Views 15786
nevinalex1234
nevinalex1234 over 14 years ago
 Hi
I was trying to import cadence spectre values into matlab for analysis. I assumed that cadence samples a sinusoid for a given freq, for example if theoretically from transient signal of length upto 350ps i was expecting 1ps samples(sampled at 1000GhZ), ie 350 samples. But when i imported the values into MATLAB, there are hardly 80 odd values. The envelope of the wave resembles by cadence plot, but still i have lost a lot of values. Isnt the simulator trying to negate out some redundant values.
How do i change/freeze the simulator sampling time so that i recover the entire values ?
    Why do you think it should be sampled? spectre uses variable (adaptive) timesteps to ensure it follows signals to the desired accuracy - so there's nothing that would give you a regularly spaced timestep (by default) - why would it sample at 1000GHz unless you told it to?
    You can specify the strobeperiod parameter on the tran analysis (see "spectre -h tran") to specify that the simulator should write out the results at the specified interval - note that it also ensure that it solves at these strobeperiod timepoints - although it will also solve at intermediate points too if needed to preserve accuracy, but won't output them by default (unless you set strobeoutput=all - which is only available in relatively recent versions of MMSIM).
