  2. RF Design
  3. *WARNING* QRC_HOME environmental variable is set but UI...
  • Subscribers 63
  • Views 3213
*WARNING* QRC_HOME environmental variable is set but UI can't locate correct QRC installation
Aldo2
Aldo2 over 14 years ago
I get the following warning with QRC:
 *WARNING* QRC_HOME environmental variable is set but UI can't locate correct QRC installation.
          In order to run UI in QRC compatibility mode you need to have QRC executables in your $PATH and QRC version should be 8.1 or greater.
          Check your QRC installation and environmental settings.
I am using:
ic 615isr20120513 and pve 1111isr20120629
Thank you very much
Best Regards
Aldo
    Aldo,
    The only way I can get this to happen is if I have QRC_HOME set to <PVEinstallationDir> but not having <PVEinstallationDir>/bin in my PATH. So can you check $QRC_HOME and $PATH to ensure they are correct?
  • Aldo2
    I have found the error! It is not explained on CIW (only the message I wrote previously is shown on CIW), but in the pvsUI_ipvs.log file, created in the directory on which I run virtuoso.
    The error was caused by a missing library (GLIB_2.4) in the server I was using for my simulations.
    I'm wondering why the same message is not shown on CIW or why is not shown a message telling the user to open this file.
    Thank you
    Best Regards,
    Aldo
    Aldo,
    I agree, reporting every possible error in a way that is clear to the user is important - but sometimes it's hard to anticipate every possible error - and some things get missed when designing the software and testing it.
