  2. RF Design
  3. reading simulation results from cadence to matlab/ cds_...
  • Replies 23
  • Subscribers 63
  • Views 30278
reading simulation results from cadence to matlab/ cds_innersrr
nevinalex1234
nevinalex1234 over 14 years ago
Hi
I am using MATLAB 2009a/2012a and MMSIM 10.11 and cadence virtuoso IC6.1.5.500.11
I build a small low pass filter and ran the simulation in ADE and tried to read using MATLAB Spectre Toolbox. Its not working.
The error is attached as follows. I have referred to Matlabspectre.pdf and set the appropriate environments in matlab. Dont know why?
mydir =
/home/njacob2/simulation/design1_rcresponse/spectre/schematic/psf
>> nevin=cds_srr('mydir')
??? Undefined function or method 'cds_innersrr' for input arguments of
type 'char'.
Error in ==> cds_srr at 16
    sig = cds_innersrr(dirname);
  • nevinalex1234
    env | grep MATLAB returns nothing
    asf24lin2-28: env | grep LD_LIBRARY
    LD_LIBRARY_PATH=/cad/adi/apps/cliosoft/sos/linux_5/6.23.p3/lib/64bit:/cad/adi/apps/cliosoft/sos/linux_5/6.23.p3/lib:/usr/lib:/usr/libexec:/lib:/usr/lib/X12:/cad/adi/apps/gnu/linux/x86_64/5/lib:/cad/adi/apps/gnu/linux/x86_64/5/lib64
    ADIM_APPEND_TRACKER=MANPATH|LM_LICENSE_FILE|newPATH|CDSLMD_LICENSE_FILE|LD_LIBRARY_PATH|PERL5LIB|INFOPATH|PYTHONPATH
    matlab -n same results as earlier (shows version)
     Ah, it's possible you might be using a too old version of spectre - in the early MMSIM10.1 versions it had an issue with compiler compatibility. What does "spectre -W" return?
     I would also expect you to have MATLABPATH set - otherwise it won't find cds_srr (it needs to be set to <MMSIMinstDir>/tools/spectre/matlab if using 32bit Matlab).
  • nevinalex1234
    sub-version  10.1.1.017
    Where's your working directory? (what does "pwd" say?). I assume you're trying to run this from your workspace.
    You've not copied cds_srr.m into your user area?
    Have you tried setting MATLABPATH to the place I mentioned? That's what you're supposed to do.
     By the way, that version should be new enough not to have the compiler incompatibility.
  • nevinalex1234
    Yes i ran that from workspace.
    Do i need to copy that cds_srr.m ? I entered the matlab environment so it must automatically read it write ?
    cds_srr is getting correctly initiated in matlab
      but its cds_innersrr thats propping up the issue. In fact there is no pure cds_innersrr.m function in the path. there is only a cds_innersrr.mexglx
    Is it why the error below props up
    >> cds_srr
    >> help cds_srr
       sig = cds_srr(dirname, dataset, signame, verbose)
       dirname: the path of psf or stt2 results
       dataset: the dataset name in the results, when only 'result dir' give out, the command will return all dataset names.
       signame: the name of signal in the dataset, the command will return all signal names in the dataset,
                when this parameter unset.
      Copyright(C) Cadence Design Systems, Inc., 2004-2006. All rights reserved.
    of type 'char'.
    No, you don't need to copy it - I was wondering whether you had - I can't see how it is being found if MATLABPATH is not being set. IOt won't find cds_innersrr.mexglx unless MATLABPATH is set.
    Once matlab has started, can you type "path" and then post what it returns.
  • nevinalex1234
    >> path
            MATLABPATH
        /home/njacob2/matlab
        /cad/adi/apps/cadence/mmsim/linux/10.11.017/tools/spectre/matlab
        /cad/local/apps/mathworks/matlab/2009a/toolbox/matlab/general
        /cad/local/apps/mathworks/matlab/2009a/toolbox/matlab/ops
        /cad/local/apps/mathworks/matlab/2009a/toolbox/matlab/lang
        /cad/local/apps/mathworks/matlab/2009a/toolbox/matlab/elmat
        /cad/local/apps/mathworks/matlab/2009a/toolbox/matlab/randfun
        /cad/local/apps/mathworks/matlab/2009a/toolbox/matlab/elfun
        /cad/local/apps/mathworks/matlab/2009a/toolbox/matlab/specfun
        /cad/local/apps/mathworks/matlab/2009a/toolbox/matlab/matfun
        /cad/local/apps/mathworks/matlab/2009a/toolbox/matlab/datafun
        /cad/local/apps/mathworks/matlab/2009a/toolbox/matlab/polyfun
        /cad/local/apps/mathworks/matlab/2009a/toolbox/matlab/funfun
        /cad/local/apps/mathworks/matlab/2009a/toolbox/matlab/sparfun
        /cad/local/apps/mathworks/matlab/2009a/toolbox/matlab/scribe
        /cad/local/apps/mathworks/matlab/2009a/toolbox/matlab/graph2d
        /cad/local/apps/mathworks/matlab/2009a/toolbox/matlab/graph3d
        /cad/local/apps/mathworks/matlab/2009a/toolbox/matlab/specgraph
        /cad/local/apps/mathworks/matlab/2009a/toolbox/matlab/graphics
        /cad/local/apps/mathworks/matlab/2009a/toolbox/matlab/uitools
        /cad/local/apps/mathworks/matlab/2009a/toolbox/matlab/strfun
        /cad/local/apps/mathworks/matlab/2009a/toolbox/matlab/imagesci
        /cad/local/apps/mathworks/matlab/2009a/toolbox/matlab/iofun
        /cad/local/apps/mathworks/matlab/2009a/toolbox/matlab/audiovideo
        /cad/local/apps/mathworks/matlab/2009a/toolbox/matlab/timefun
        /cad/local/apps/mathworks/matlab/2009a/toolbox/matlab/datatypes
        /cad/local/apps/mathworks/matlab/2009a/toolbox/matlab/verctrl
        /cad/local/apps/mathworks/matlab/2009a/toolbox/matlab/codetools
        /cad/local/apps/mathworks/matlab/2009a/toolbox/matlab/helptools
        /cad/local/apps/mathworks/matlab/2009a/toolbox/matlab/demos
        /cad/local/apps/mathworks/matlab/2009a/toolbox/matlab/timeseries
        /cad/local/apps/mathworks/matlab/2009a/toolbox/matlab/hds
        /cad/local/apps/mathworks/matlab/2009a/toolbox/matlab/guide
        /cad/local/apps/mathworks/matlab/2009a/toolbox/matlab/plottools
        /cad/local/apps/mathworks/matlab/2009a/toolbox/local
        /cad/local/apps/mathworks/matlab/2009a/toolbox/shared/controllib
        /cad/local/apps/mathworks/matlab/2009a/toolbox/shared/dastudio
        /cad/local/apps/mathworks/matlab/2009a/toolbox/matlab/datamanager
        /cad/local/apps/mathworks/matlab/2009a/toolbox/simulink/simulink
        /cad/local/apps/mathworks/matlab/2009a/toolbox/simulink/simulink/slresolve
        /cad/local/apps/mathworks/matlab/2009a/toolbox/simulink/blocks
        /cad/local/apps/mathworks/matlab/2009a/toolbox/simulink/components
        /cad/local/apps/mathworks/matlab/2009a/toolbox/simulink/fixedandfloat
        /cad/local/apps/mathworks/matlab/2009a/toolbox/simulink/fixedandfloat/fxpdemos
        /cad/local/apps/mathworks/matlab/2009a/toolbox/simulink/fixedandfloat/obsolete
        /cad/local/apps/mathworks/matlab/2009a/toolbox/simulink/simdemos
        /cad/local/apps/mathworks/matlab/2009a/toolbox/simulink/simdemos/aerospace
        /cad/local/apps/mathworks/matlab/2009a/toolbox/simulink/simdemos/automotive
        /cad/local/apps/mathworks/matlab/2009a/toolbox/simulink/simdemos/simfeatures
        /cad/local/apps/mathworks/matlab/2009a/toolbox/simulink/simdemos/simgeneral
        /cad/local/apps/mathworks/matlab/2009a/toolbox/simulink/dee
        /cad/local/apps/mathworks/matlab/2009a/toolbox/shared/dastudio/depviewer
        /cad/local/apps/mathworks/matlab/2009a/toolbox/stateflow/stateflow
        /cad/local/apps/mathworks/matlab/2009a/toolbox/rtw/rtw
        /cad/local/apps/mathworks/matlab/2009a/toolbox/shared/sigbldr
        /cad/local/apps/mathworks/matlab/2009a/toolbox/simulink/simulink/modeladvisor
        /cad/local/apps/mathworks/matlab/2009a/toolbox/simulink/simulink/modeladvisor/fixpt
        /cad/local/apps/mathworks/matlab/2009a/toolbox/simulink/simulink/MPlayIO
        /cad/local/apps/mathworks/matlab/2009a/toolbox/simulink/simulink/dataobjectwizard
        /cad/local/apps/mathworks/matlab/2009a/toolbox/shared/hdlshared
        /cad/local/apps/mathworks/matlab/2009a/toolbox/rtw/accel
        /cad/local/apps/mathworks/matlab/2009a/toolbox/stateflow/sfdemos
        /cad/local/apps/mathworks/matlab/2009a/toolbox/stateflow/coder
        /cad/local/apps/mathworks/matlab/2009a/toolbox/commblks/commblks
        /cad/local/apps/mathworks/matlab/2009a/toolbox/commblks/commmasks
        /cad/local/apps/mathworks/matlab/2009a/toolbox/commblks/commmex
        /cad/local/apps/mathworks/matlab/2009a/toolbox/commblks/commblksdemos
        /cad/local/apps/mathworks/matlab/2009a/toolbox/commblks/commblksobsolete/v3
        /cad/local/apps/mathworks/matlab/2009a/toolbox/commblks/commblksobsolete/v2p5
        /cad/local/apps/mathworks/matlab/2009a/help/toolbox/commblks/examples
        /cad/local/apps/mathworks/matlab/2009a/toolbox/comm/comm
        /cad/local/apps/mathworks/matlab/2009a/toolbox/comm/commdemos
        /cad/local/apps/mathworks/matlab/2009a/help/toolbox/comm/examples
        /cad/local/apps/mathworks/matlab/2009a/toolbox/comm/commobsolete
        /cad/local/apps/mathworks/matlab/2009a/toolbox/control/control
        /cad/local/apps/mathworks/matlab/2009a/toolbox/control/ctrlguis
        /cad/local/apps/mathworks/matlab/2009a/toolbox/control/ctrlobsolete
        /cad/local/apps/mathworks/matlab/2009a/toolbox/control/ctrlutil
        /cad/local/apps/mathworks/matlab/2009a/toolbox/control/ctrldemos
        /cad/local/apps/mathworks/matlab/2009a/toolbox/shared/slcontrollib
        /cad/local/apps/mathworks/matlab/2009a/toolbox/dspblks/dspblks
        /cad/local/apps/mathworks/matlab/2009a/toolbox/dspblks/dspmasks
        /cad/local/apps/mathworks/matlab/2009a/toolbox/dspblks/dspmex
        /cad/local/apps/mathworks/matlab/2009a/toolbox/dspblks/dspdemos
        /cad/local/apps/mathworks/matlab/2009a/toolbox/shared/filterdesignlib
        /cad/local/apps/mathworks/matlab/2009a/help/toolbox/dspblks/examples
        /cad/local/apps/mathworks/matlab/2009a/toolbox/emlcoder/emlcoder
        /cad/local/apps/mathworks/matlab/2009a/toolbox/emlcoder/emlcodermex
        /cad/local/apps/mathworks/matlab/2009a/toolbox/shared/simtargets
        /cad/local/apps/mathworks/matlab/2009a/toolbox/eml/eml
        /cad/local/apps/mathworks/matlab/2009a/toolbox/fixedpoint/fixedpoint
        /cad/local/apps/mathworks/matlab/2009a/toolbox/fixedpoint/fidemos
        /cad/local/apps/mathworks/matlab/2009a/toolbox/fixedpoint/fixedpointtool
        /cad/local/apps/mathworks/matlab/2009a/toolbox/slvnv/simcoverage
        /cad/local/apps/mathworks/matlab/2009a/toolbox/signal/signal
        /cad/local/apps/mathworks/matlab/2009a/toolbox/signal/sigtools
        /cad/local/apps/mathworks/matlab/2009a/toolbox/signal/sptoolgui
        /cad/local/apps/mathworks/matlab/2009a/toolbox/signal/sigdemos
        /cad/local/apps/mathworks/matlab/2009a/toolbox/shared/spcuilib
        /cad/local/apps/mathworks/matlab/2009a/toolbox/shared/siglib
        /cad/local/apps/mathworks/matlab/2009a/toolbox/sl3d/sl3d
        /cad/local/apps/mathworks/matlab/2009a/toolbox/sl3d/sl3ddemos
        /cad/local/apps/mathworks/matlab/2009a/toolbox/slcontrol/slcontrol
        /cad/local/apps/mathworks/matlab/2009a/toolbox/slcontrol/slctrlguis
        /cad/local/apps/mathworks/matlab/2009a/toolbox/slcontrol/slctrlutil
        /cad/local/apps/mathworks/matlab/2009a/toolbox/slcontrol/slctrldemos
        /cad/local/apps/mathworks/matlab/2009a/toolbox/shared/optimlib
        /cad/local/apps/mathworks/matlab/2009a/toolbox/shared/sldv
    Looks as if MATLABPATH is indeed set.
    If you do Help->About in matlab, can you do a screenshot (using ksnapshot say) of the popup and post that (use the Options tab at the top of the Reply to an Existing Message section on the form)?
  • nevinalex1234
    screenshot
