  2. RF Design
  3. reading simulation results from cadence to matlab/ cds_...
  • Replies 23
  • Subscribers 63
  • Views 30270
reading simulation results from cadence to matlab/ cds_innersrr
nevinalex1234
nevinalex1234 over 14 years ago
Hi
I am using MATLAB 2009a/2012a and MMSIM 10.11 and cadence virtuoso IC6.1.5.500.11
I build a small low pass filter and ran the simulation in ADE and tried to read using MATLAB Spectre Toolbox. Its not working.
The error is attached as follows. I have referred to Matlabspectre.pdf and set the appropriate environments in matlab. Dont know why?
mydir =
/home/njacob2/simulation/design1_rcresponse/spectre/schematic/psf
>> nevin=cds_srr('mydir')
??? Undefined function or method 'cds_innersrr' for input arguments of
type 'char'.
Error in ==> cds_srr at 16
    sig = cds_innersrr(dirname);
  • nevinalex1234
     How is it different from creating a netlist of the schematic and creating .raw files which are to be read into matlab. Either of them doesnt work for that matter
  • Ashish Patni
    Ashish Patni over 14 years ago
    Hi Nevinalex1234,
    If you are using 64 bit version of the tool then please set the LD_LIBRARY_PATH as mentioned by Andrew in the post you referred i.e. -
    setenv LD_LIBRARY_PATH `cds_root spectre`/tools/lib/64bit:$LD_LIBRARY_PATH
    but you need to keep in mind (as mentioned by Andrew) that if running on a 32-bit machine (or running 32 bit matlab), you'll need to miss out the 64bit part of the path. You may also refer to the following COS Solution for more details when trying to run the SpectreRF/Matlab toolbox on a 64 bit OS -
    http://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:ViewSolution;solutionNumber=11500586
    and see if this helps.
    Also, I see one more thing but not sure if that is the case i.e. you are setting -
    mydir = '/home/njacob2/simulation/design1_rcresponse/spectre/schematic/psf'
    and then using, e.g.,
    datalist = cds_srr(mydir)
    or some other command like that. I see that you have used -
    cds_srr('mydir')
    Please remove these single inverted commas and then try. I tested this at my end and gets the same error if I use these single inverted commas.
    With Regards,
    Ashish
  • nevinalex1234
     1) MIne is 32 bit system
    "getconf LONG_BIT" in terminal
    2) tried without inverted commas. Not working
    3) I dont have hostid/reference. Cannot access the document link you sent.
    What does "matlab -e" show?
  • nevinalex1234
     matlab 2009a 2012a
     matlab -e should show a whole load of environment variable settings - so not sure what your last post was trying to tell me. I don't need to know the versions you're using (you already said that) - but I want to see what the setup of your environment is.
  • nevinalex1234
     I was not sure where to type it.
    I typed it in the terminal and it gave the me the versions ONLY.
    Maybe you have some wrapper around matlab? I'm assuming you're running on Linux, not Windows?
    What do you get when you type "which matlab"?
  • nevinalex1234
     which matlab gives
    /cad/local/bin/matlab
    Yes im on linux
    Maybe that is a script which intercepts the -e argument for its own purposes. In my case I am directly including the path for matlab:
    UNIX> which matlab
    /export/home/apps/matlab_R2012a/bin/matlab
    What I'm really interested in is what:
      env | grep MATLAB
      env | grep LD_LIBRARY
    produce.
    Try running "matlab -n" to see what that outputs...
