  2. RF Design
  3. Ocean script is NOT writing into the file in the first ...
  • Subscribers 64
  • Views 16411
Ocean script is NOT writing into the file in the first run
RFQuery
RFQuery over 14 years ago
Dear all,
I have written a code which actually does SP analysis and also DC analysis for each corner.
I am writing the S21 wave using ocnPrint( ) for each corner into separate file.
I am also writing two MOS transistor "vds"  into two files  using  fprintf() command.
However, while  ocnPrint( ) is writing into file in the first run of the ocean script, the  fprintf() comand writing into the files after the 2nd RUN
In the first run  the files are created but they are empty. They are filledonly after 2nd run.
Can anybody please tell why this is happening.
 My OCEAN codeis as below:--
envSetVal("spectre.envOpts" "simOutputFormat" 'string "psfbin")
ocnWaveformTool( 'wavescan )
simulator( 'spectre )
design(     "/home/../.../spectre/schematic/netlist/netlist")
resultsDir( "/home/../simulation/../spectre/schematic" )
myCors = list("tt" "ss" "ff" )  ;;; Available corners
out0 = outfile("MOS_OPERATING_M0.txt" "w")
out1 = outfile("MOS_OPERATING_M1.txt" "w")
fprintf( out0 " %s  \n"  "vds_M0" )
fprintf( out1 " %s \n" "vds_M1" )
foreach(myModelSec myCors
myResultsDir = strcat("/home/../simulation/..spectre/schematic/")
resultsDir(myResultsDir)
modelFile(
'("/home/manas/work_cad/LNA_CORNER_dc.scs" "")
 list("/home/../MOS_MODEL.scs" myModelSec)
analysis('sp ?ports list("/PORT1" "/PORT2")  ?start "4G"  ?stop "10G"
        ?lin "10"  ?donoise "yes"  ?oprobe "/PORT2"  ?iprobe "/PORT1"  )
analysis('dc ?saveOppoint t ?oppoint "rawfile" )
desVar(      "input_power" 0    )
desVar(      "f1" 5.38G    )
desVar(      "f2" "f1+4M"    )
option(    'temp  "27.0"
ocnPrint(?output strcat("/home/../../S21_" myModelSec ".dat") ?numberNotation 'scientific s21_db20)
selectResult( 'dcOpInfo )
vds_M0=pv("/I42/M0" "vds")
vds_M1=pv("/I42/M1" "vds")
fprintf( out0 " %e \n" vds_M0)
fprintf( out1 " %e \n" vds_M1)
plot(db20(S21) ?expr list(strcat("S21_" myModelSec))
);;; End of Script
  • marcelpreda
    marcelpreda over 14 years ago
     Hi there,
    I do not see any close() call, you need to close the file handlers.
    Best Regards,
    Marcel
  • RFQuery
    O Sorry. I have forgotten to add close().
    Thanks a lot for pointing the mistake.
    Kind regards,
