  2. RF Design
  3. Executing multiple statements inside if-else command in...
  • Subscribers 63
  • Views 19607
Executing multiple statements inside if-else command in OCEAN
RFQuery
RFQuery over 14 years ago
 Dear All,
I need to implement something like below:-
Is it possible to do so in OCEAN ?
if( statement is true)
   Execute---statement-1
   Execute---statement-2
   Execute---statement-3
else
   Execute---statement-4
   Execute---statement-5
   Execute---statement-6
end
Kind regards
    Of course - OCEAN is SKILL, and SKILL has an if function (covered in the documentation):
    if(expression then
    ; true bits
    else
    ; false bits
    Note that the open parenthesis must be after the if with no space, and there is a close parenthesis at the end of the if() function. See the SKILL Language User Guide for more details.
  • RFQuery
    Dear Andrew,
    Thanks a lot for your reply..
    I just want to know is it possible to do very simple Array or Matrix operation like ( assigning values to matrix, adding two Matrixes) in OCEAN. If so , can you give some examples or point to some documents which elucidate the operations.
    Kind Regards,
    Nothing built-in (that's public), but it would be easy enough to write something.
