  2. RF Design
  3. rfLib ACPR source usage
  • Subscribers 63
  • Views 17076
Steve Mikes
Steve Mikes over 13 years ago
I'm attempting to use the ACPR_source block as an input to my circuit. I have baseband I and Q files for a modulated waveform, sampled at 30.72MHz. I'm encountering a problem that I believe is due to oversampling and interpolation, where unwanted images are appearing at multiples of the BB sampling frequency (see attached image). I see there is a filter option on the ACPR block, but when I tried using it it didn't seem to filter the images at all. How does one normally remove these?
Steve
    Steve,
    Please log a service request with customer support for this.
  • Steve Mikes
     Yeah I did that eventually, what we concluded in the end is that the block is set up to work as-is with envelope simulation. If I wanted to run it in transient, I would need to provide the necessary filtering myself. There was another problem with this block where the output power is 3dBm off from what you set it to, I got a CCR fix request in for that already.
    Steve
