  2. RF Design
  3. Does anyone ever meet this error in your simulation?
  • Subscribers 63
  • Views 16331
Henrytqy
Henrytqy over 13 years ago
Hi all,
My transition simulation is from 0 to 2us, but a error occurs in the 1.5 us as "spectre - 7031 SST2 error invalid control value".
Anyone can help?
 Thanks a lot~~~
    Which version of the tools are you using (Help->About in the CIW, and "spectre -W" at the UNIX command line - subversion also shown at the top of the spectre log file)? If using IC614/IC615 and (say) MMSIM10.1, MMSIM11.1 or MMSIM12.1 I would recommend changing the output format to "psfxl" rather than sst2 (This is on the Outputs->Save All form).
    However, I think the specific issue you're seeing is quite likely fixed if you're using a recent enough subversion of MMSIM10.1, MMSIM11.1 or MMSIM12.1
  • Henrytqy
    Thanks a lot.
    I resolved my problem by change the setup on transition option to default.
    when I set a value on, 1.5us, in the " transition/option/output start ", the problem occurs, if I set it as 0, then I can simulate succesfully.
    I don't kown why?
    The problem is related to changing the range of simulation results in SST2 from one simulation to the next. I believe it's been fixed nowadays, but the issue is best solved by using PSF XL (which is a faster format anyway).
