  2. RF Design
  3. What is the USE of No of Harmonics/maxacfrequency if one...
  • Subscribers 63
  • Views 3206
What is the USE of No of Harmonics/maxacfrequency if one does simulation for IIP3/P1dB
RFQuery
RFQuery over 13 years ago
 Dear All,
 Can anybody please tell "What is the USE of No of Harmonics/maxacfrequency if one does simulation for IIP3/P1dB" in PSS analysis.
  • Tawna
    Tawna over 13 years ago
    Hi RFQuery,
    You didn’t mention if you were using the Harmonic Balance or the Shooting Newton engine.
    You may want to look at:
    Cadence Online Support Solution  (11784002) Which is better:  Setting pss harmonics or maxacfreq to obtain good pnoise accuracy?
    The same concept applies to small signal analyses such as IIP3.  This is geared towards Shooting Newton.
    I also recommend looking at the blog posting:   Guidelines for Maximizing Speed vs Accuracy for Harmonic Balance - Part 2
    This is geared towards Harmonic Balance.
    Best regards,
    Tawna
    See this previous thread from the last time you asked a very similar question.
  • RFQuery
     Dear Andrew,
    Thanks a lot for pointing me my last query-post.
    However I actually posted this after going through the post http://www.designers-guide.org/Forum/YaBB.pl?num=1170976620/15 .
    It seems that by increasing the No. of Harmonic in PSS improves the IIP2 or IIP3 values ( if they are really high. i.e. the IM2/3 components are very very small)
    Kind regards,
    As Tawna said, you didn't mention whether you are using harmonic balance or shooting. With harmonic balance, if you don't have enough harmonics to represent the harmonic content of the signals, the energy from the missing harmonics can leak into the harmonics you've chosen, compromising the accuracy. With shooting that doesn't happen because it is simulated in the time domain, but it tends not to be so good at simulating circuits with extremely high dynamic range (such as IIP2/IIP3 simulations where the input power was low).
  • Tawna
    Also, RFQuery, I am pointing you to solutions on Cadence Online Support so you can learn and gain understanding
    rather than me just providing an answer.   (Teaching you to fish, rather than just giving you fish.  J  )
    Best regards,
    Tawna
