  2. RF Design
  3. Using .PWL for Input waveform for doing PSS (shooting method...
  • Subscribers 63
  • Views 2375
Using .PWL for Input waveform for doing PSS (shooting method) & Pnoise
RFQuery
RFQuery over 13 years ago
Dear All,
I was trying to simulate my  circuit  (using PSS/PNOISE) which has mixer for downconversion.
The clock for the mixers are coming from another circuit block.
When I simulate with my clock source circuit it takes a lot of time to  simulate the PSS.
So I want to simulate the clock source separately and capture the output waveform in a .PWL file.
This .PWL file I want to feed the main circuit for doing PSS/PNOISE analysis.
I am confused how it will work. Can anybody tell how this way of simulation will work with PSS/PNOISE. How this will affect the accuracy of the PSS/PNOISE simulation.
Kind Regards,
  • Tawna
    Tawna over 13 years ago
    Hi RFQuery,
    If you want to use a PWL source in your circuit, you should look at Chapter10 of the MMSIM 12.1 (note the version!) of the SpectreRF User Guide.
    Below is a link (you must have a Cadence Online Support account to view this.)
    http://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:DocumentViewer;src=pubs;q=/spectreRF/spectreRF12.1/Chap10.html
    There are caveats of which you should be aware.  This document will tell you how to do it.
    Best regards,
    Tawna
  • RFQuery
     Dear Tawna,
    Thanks a lot.
    Kind Regards
