  2. RF Design
  3. No Insufficient Memory Promble in PSS/Pnoise simulation
  • Subscribers 63
  • Views 2750
Charley Hou
Charley Hou over 13 years ago
I have some promblems on VCO Post-simulation of PSS and Pnoise. The Frequency of the VCO is 20GHz. When I simulate the schematic, everything is good. But when I comes to Post-simulation, there will always be the error "no insufficient memory".
At first, I can't finish the pss and one of my classmates told me to set a swapfile. It's very useful and I can finished pss in about an hour. But now, I can finish the pnoise.
My parasitic resistor number is about 70,000. I try to run PEX with the output "C+CC", and the two simulation can finish quickly. So, is the parasitic resistor number is too much? Or there is something wrong in my setup.
My setup is followed:
pss
engine shooting
Beatfrequency 18.46GHz(I have simulate transient to be sure of the oscillating frequency.)
Number of harmonics 11
Accuracy Defaults conservative
tstab 40n(it is stable nearly 20ns.)
Oscillator ON and OP
swapfile set already
method gear2only
tstabmethod gear2only
Pnoise
sweeptype default relative harmonic 1
frequency sweep range 10k 100M
  Points per Decade 10
Maxmum sideband 11
voltage ON OP
And I also select "Run with 64 bit binary" in the Environment setup
This problem has confused me for a long time, and I have googled it, but didn't find something helpful.
 I would appreciate it very much if anyone would help me with it.
As I'm in UTC+8, so maybe I can't reply immediately.
  • Tawna
    Tawna over 13 years ago
    Hi Charley,
    If this is a VCO like a ring oscillator (strongly nonlinear, sharp waveforms), use shooting engine with full spectrum pnoise.
    If a crystal oscillator or LC oscillator, use the harmonic balance engine.
    To speed things up, use APS. You can also set parasitic reduction (see spectre -h for more information). For example:
    spectre +aps +parasitics=rf input.scs
    best regards,
    Tawna
  • Charley Hou
    Hi Tawna,
      Thank you very much for your reply. The problem was solved.
