  2. RF Design
  3. Issue with Flicker phase noise simulaiton with PSS+Pnoise...
  • Subscribers 63
  • Views 2535
Issue with Flicker phase noise simulaiton with PSS+Pnoise in cadence
lraf
lraf over 13 years ago
I have a problem with Flicker phase noise of a quartz crystal oscillator (RLC equivalent cirucit + opamp current amplifier + opamp inverter) simulated with PSS + Pnoise of CADENCE:
Indeed I simulate the phase noise of a quartz crystal oscillator and I include only Flicker noise (verilogA) in the feedback opamp inverter. The simulated phase noise shows white phase noise, f-2 phase noise and f-3 phase noise near the carrier, instead of only f-1 phase noise and f-3 phase noise!
Can you please help me solve this problem?
Best regards
Raphael
    It would help to see your veriloga model and the input.scs that you are simulating. Much easier than trying to guess what you've done.
  • lraf
     Dear andrew,
    Thank you for your prompt answer!
    Please find attached to this post:
    the input.scs file, the verilogA model of noise, and the simulations results: transient, noise, PSS, Pnoise and noise summary for phase noise.
    The Phase noise and its associated noise summary show that there is only Flicker noise contribution to phase noise but there is still 0 slope phase noise and 1/f2 slope phase noise whereas there should be only 1/f slope and 1/f3 slope phase noise !
    I hope you have enough informations..
    Raphael
     SCHEMATIC:
  • lraf
     still no answer....... snifff.....
