  2. RF Design
  3. Different op amp gains using different spectre analysis
  • Subscribers 63
  • Views 19163
OneNewBoy
OneNewBoy over 13 years ago
Hi all,
I am new to analog design. I have created an op-amp schematic and tried to get open loop gain by 2 ways:
(Simulation uses cadence virtuoso)
1) Transient analysis: applied a ramp pulse of 0->VDD to +ve input [with a dc value of VDD/2] and kept -ve input to Vdd/2, then plotted Vout vs V+ and took its derivative, this gave me 1300
2) DC analysis: applied a volt of 0->VDD at +ve volt and kept -ve input to VDD/2. Processed Vout as in step 1 and got ~ 50
I cannot believe what makes the 2 gains so different and which is correct ? Voltage supply is from 0->VDD.
Can someone help in this regard ?
Thanks a lot
  • HamidKhatibi
    HamidKhatibi over 13 years ago
    Hi
    When you do not have a feedback for a high gain amplifier, it is not possible to avoid saturation in the output. You need to have a DC feedback at least and then you can find the gain.
    Best
    Hamid
  • OneNewBoy
    Thanks for reply, However I am facing a very strange problem in my simulation, please help me with this:
    I am running a parametric simulation to experiment & get the optimal bias current of Op-Amp .
    For this I gave a list of "I_bias" as "5u 7u " in the parametric analysis window, and ran a parametric transient analysis with these 2 parameters
    Problem is the output I get with  7u in above parametric analysis is very different from the same value plugged directly in transient analysis.
    I figured out that if I remove 5u in the list of current values I pass in parametric analysis then the output of parametric analysis and transient analysis become same.
    I have never seen this difference before, is this related to some initial value problem ? [part of 5u solution getting used for 7u simulation ?]. Please help me in debugging this.
    Update: I figured out that if I do skipdc transient analysis, my results are okay as expected, what does that imply, the circuit's DC behaviour is not good ? And also skipdc takes much longer, what should be the most appropriate initial condition and how may I include them ?
     Thanks a lot.
    Using skipdc is not a good idea - it means that the transient will have a much harder time converging.
    The behaviour you are seeing suggests that your circuit has more than one stable operating point.
  • OneNewBoy
    Thanks Andrew, I will play more with the circuit to dig more about this
