  2. RF Design
  3. Corner and varible sweep simulation in spectre
  • Replies 11
  • Subscribers 64
  • Views 26129
lahsivece
lahsivece over 13 years ago
Hi ,
I am trying to do a multivariable sweep and corner simulation in spectre .
In ocean , it is easy , I can do following
b0_list = list(0.0 1.2)
b1_list = list(0.0 1.2)
b2_list = list(0.0 1.2)
corners='("ss" "ff" "tt" "snfp" "fnsp")
foreach(corner corners
modelFile(list("<path_to_model_library>/model.lib.scs" sprintf(nil "%s" corner)))
foreach(x b2_list
desVar("b2" x)
foreach(y b1_list
desVar("b1" y)
foreach(z b0_list
desVar("b0" z)
  resultsDir(sprintf(nil "<path_to_result_directory>/spectre/schematic/corner=%sb5=%gb4=%gb3=%gb2=%gb1=%gb0=%g",corner,b5_z,b4_y,b3_x,x,y,z))
run()
How can I modify above to use it  for spectre simulations from command line ?
Due to some logistical issues , I can have access to either one  MMSIM (for spectre) or IC514( for ocean) for simulation .
Please advise.
    I'm guessing that you're asking what the equivalent syntax is for doing this within a spectre netlist (i.e. with no OCEAN involved at all). Is that correct?
    In other words, you want to just do "spectre yournetlist.scs" and have it run all the simulations?
  • lahsivece
    Thanks for the reply, Andrew.
    Yes I am looking for equivalent syntax for doing the same within the spectre netlist .
    and yes I just want to do "spectre netlist.scs" and have it run all the simulations .
    Vishal
    Vishal,
    Unfortunately you can't sweep model sections in spectre, but you can do something like this:
    // example using nested sweeps
    include "models.scs" section=nn
    parameters b2=0.0 b1=0.0 b0=0.0
    // silly circuit just to do something
    M1 (d g 0 0) nch w=1u l=0.5u
    vd (d 0) vsource type=dc dc=b1
    vg (g 0) vsource type=sine freq=1M ampl=b2
    sweepb2_1 sweep param=b2 values=[0.0 1.2] {
      sweepb1_1 sweep param=b1 values=[0.0 1.2] {
        sweepb0_1 sweep param=b0 values=[0.0 1.2] {
        tran_1 tran stop=1u
    alt1 altergroup {
        include "models.scs" section=ff
    sweepb2_2 sweep param=b2 values=[0.0 1.2] {
      sweepb1_2 sweep param=b1 values=[0.0 1.2] {
        sweepb0_2 sweep param=b0 values=[0.0 1.2] {
        tran_2 tran stop=1u
    alt2 altergroup {
        include "models.scs" section=ss
    sweepb2_3 sweep param=b2 values=[0.0 1.2] {
      sweepb1_3 sweep param=b1 values=[0.0 1.2] {
        sweepb0_3 sweep param=b0 values=[0.0 1.2] {
        tran_3 tran stop=1u
  • lahsivece
    Thank you, Andrew . Regards, Vishal
    Vishal,
    At the time I first responded to your question, I also looked into using SpectreMDL as a way of avoiding having to duplicate the sweeps for each alter. Unfortunately it didn't work properly - so I requested a fix for this. This was implemented in MMSIM12.1 ISR8 (available on downloads.cadence.com). Here's the explanation of how this works:
    In the spectre netlist (testsweep2.scs), I have:
        sweepb2 sweep param=b2 values=[0.0 1.2] {
          sweepb1 sweep param=b1 values=[0.0 1.2] {
    	sweepb0 sweep param=b0 values=[0.0 1.2] {
    	    tran tran stop=1u
        altff altergroup {
        altss altergroup {
    And then the MDL script (testsweep2.mdl) is:
        run sweepb2 as sweepb2_nn
        run altff
        run sweepb2 as sweepb2_ff
        run altss
        run sweepb2 as sweepb2_ss
    Then I can run:
    spectremdl testsweep2
    If you do this (from MMSIM12.1 ISR8 onwards) it conveniently runs the nested sweep for all corners with the minimum of coding in the netlist/MDL file.
    Just thought you (and maybe others) might be interested in this alternative approach!
  • lahsivece
    Hi Andrew ,
    This is great. Thanks a lot for looking into this.
    Vishal
  • jerry124
    jerry124 over 13 years ago
    I would like to sweep parameter in one of sub circuit. I am running simulation from command line. If I run sweep parameter on one of device on top lavel it works fine, but when I want run sweep parameter on sub circuit (circuit contains only one type of devices- mos) I get an error. below is part of my simulation file and error i get. do you have any suggestion what I am doing wrong?
    // sw1 sweep dev=m1 param=w values=[ 5u 6u 7u 8u 9u ] {
    sw1 sweep sub=xs25 mod=mos bsim3v3 param=w values=[5u 6u 7u 8u 9u] {
      ac ac start=100 stop=150M dec=20
     Error found by spectre during circuit read-in.
        ERROR (SFE-874): "test.scs" 389: Unexpected keyword "param".
            Expected equals.
        ERROR (SFE-874): "test.scs" 395: Unexpected end of block
            statement "}".
    Warning from spectre during circuit read-in.
        WARNING (SFE-618): Unterminated block statement. Terminating statement at
            the end of file.
  • lahsivece
    Hi ,
    Could you please try by removing "mod=mos bsim3v3" ? Also check for the dangling "}" .
    Vishal
  • jerry124
    Hi Vishal,
    Thx for quick replay. if I remove "mod=mos bsi3v3" I get an error:
     Error found by spectre during Sweep analysis `sw1'.
        ERROR (SFE-54): Subckt instance `xs25' (an instance of `mir3_s25') does not
            have a subckt parameter `w'.
    as I understand correct I need to use "mod=" option in syntax or I am wrong?
     regarding to "}". there was mising last "}".
     BR
    Jerry
     It's really not that clear what you're trying to do. Maybe if you showed something of the structure of your netlist, and what it is you're trying to vary?
