  2. RF Design
  3. PSS-PSP simulation running into a hang mode.
  • Subscribers 63
  • Views 14956
RFStuff
RFStuff over 13 years ago
Dear All,
I am running a PExed circuit for PSS-PSP simulation with APS enabled.
CDS.log shows that  it hangs at
" Conv norm = 28.7, max dI(V10:p) = 7.1098 uA, took 632.41 s. " The machine also becomes slow.
Can anybody please tell wht is the cuase of this and how it can be tackled.
Without PEX, the PSS_PSP coverginging nicely and fast and giving desired results.
The portion of CDS.log file is as below:-
\o
\o
\o Time for EDB Visiting: CPU = 5.95409 s, elapsed = 5.99736 s.
\o Time accumulated: CPU = 11.1893 s, elapsed = 14.0158 s.
\o
\o Peak resident memory used = 314 Mbytes.
\o
\o
\o
\o
\o Warning from spectre during initial setup.
\o
\o     WARNING (CMI-2424): I251.mXI0/XI0/XI13/XI2/XI0/MNM2@2: `Moin' = 4.977 is
\o         unusually small.
\o
\o     WARNING (CMI-2424): I251.mXI0/XI0/XI13/XI11/XI1/XI0/MNM2@2: `Moin' = 4.977
\o         is unusually small.
\o
\o     WARNING (CMI-2424): I251.mXI1/XI3/XI1/MNM4@4: `Acde' = 300e-03 is unusually
\o         small.
\o     WARNING (CMI-2424): I251.mXI0/XI0/XI13/XI0/XI0/XI0/XI0/XI1/MNM33@3: `Acde'
\o         = 300e-03 is unusually small.
\o
\o     WARNING (CMI-2424): I251.mXI0/XI0/XI13/XI0/XI0/XI0/XI0/XI2/XI1/MNM9@32:
\o         `Acde' = 300e-03 is unusually small.
\o         Further occurrences of this warning will be suppressed.
\o
\o
\o Reading file:  /home/../DIVIDER_OUTPUT_CAPTURE/Q_P_1GHz.txt
\o
\o Reading file:  /home/../DIVIDER_OUTPUT_CAPTURE/I_M_1GHz.txt
\o
\o Reading file:  /home/../DIVIDER_OUTPUT_CAPTURE/I_P_1GHz.txt
\o
\o Reading file:  /home/../DIVIDER_OUTPUT_CAPTURE/Q_M_1GHz.txt
\o
\o
\o Notice from spectre during topology check.
\o     Only one connection to the following 6 nodes:
\o
\o         net453
\o         net632
\o         net633
\o         net450
\o
\o         net449
\o         Further occurrences of this notice will be suppressed (except in log
\o         file).
\o
\o     No DC path from node `I416.XI0/net0197' to ground, Gmin installed to
\o         provide path.
\o
\o     No DC path from node `I416.XI0/net0191' to ground, Gmin installed to
\o         provide path.
\o     No DC path from node `I416.XI0/net0203' to ground, Gmin installed to
\o         provide path.
\o
\o     No DC path from node `I416.XI0/net0185' to ground, Gmin installed to
\o         provide path.
\o     No DC path from node `I416.XI0/net0308' to ground, Gmin installed to
\o         provide path.
\o         file).
\o
\o
\o Circuit inventory:
\o               nodes 76206
\o
\o             bsim3v3 1548
\o
\o           bsource_1 4
\o
\o           capacitor 88535
\o               diode 198
\o
\o            inductor 1
\o                port 5
\o
\o              res_va 194
\o
\o            resistor 89836
\o         transformer 6
\o                vcvs 4
\o
\o             vsource 9
\o
\o
\o
\o
\o Notice from spectre during initial setup.
\o     APS Enabled.
\o
\o     Multithreading Enabled: 8 threads on system with 16 available processors.
\o
\o
\o     12 notices suppressed.
\o     106 warnings suppressed.
\o
\o
\o
\o Time for parsing: CPU = 22.5206 s, elapsed = 23.5959 s.
\o
\o Time accumulated: CPU = 33.7099 s, elapsed = 37.6119 s.
\o Peak resident memory used = 413 Mbytes.
\o
\o
\o
\o
\o ******************
\o DC Analysis `dcOp'
\o
\o Important parameter values:
\o
\o     reltol = 1e-03
\o
\o     abstol(V) = 100 uV
\o
\o     abstol(I) = 100 pA
\o
\o     temp = 27 C
\o
\o     tnom = 27 C
\o
\o     tempeffects = all
\o
\o     gmindc = 1 pS
\o
\o     rabsshort = 1 mOhm
\o
\o Trying `homotopy = gmin'.
\o
\o Continuation method failed. Step size is too small.
\o
\o Trying `homotopy = source'.
\o
\o Trying `homotopy = dptran'.
\o .
\o .
\o .
\o .
\o
\o
\o Trying `homotopy = ptran'.
\o .
\o
\o
\o
\o
\o Warning from spectre during DC analysis `dcOp'.
\o     WARNING (SPECTRE-16093): Solution could not be computed at specified
\o         relative tolerance (reltol).
\o         The value of reltol was loosened to 0.005.
\o
\o     WARNING (CMI-2139): I416.XI0/XM0: The bulk-drain junction current exceeds
\o         `imelt'.  The results computed by Virtuoso(R) Spectre are now incorrect
\o         because the junction current model has been linearized.
\o
\o     WARNING (CMI-2144): I416.XI0/XM0: The bulk-drain junction current exceeds
\o         `imax'.
\o
\o     WARNING (CMI-2744): I416.XI0/XM0.dnw: Junction current density(I/Area)
\o         exceeds `imelt'.  The results computed by Virtuoso(R) Spectre(R) are
\o         now incorrect because the junction current model has been linearized.
\o
\o     WARNING (CMI-2744): I416.XI0/XM0.djdb_p: Junction current density(I/Area)
\o
\o     WARNING (CMI-2744): I416.XI0/XM0.djsb_p: Junction current density(I/Area)
\o
\o
\o     WARNING (CMI-2744): I416.XI0/XM0.djdb: Junction current density(I/Area)
\o
\o     WARNING (CMI-2744): I416.XI0/XM0.djsb: Junction current density(I/Area)
\o
\o
\o
\o Convergence achieved in 40 iterations.
\o
\o Total time required for dc analysis `dcOp': CPU = 1.34258 ks (22m  22.6s),
\o         elapsed = 312.5 s (5m  12.5s).
\o
\o Time accumulated: CPU = 1.3763 ks (22m  56.3s), elapsed = 350.222 s (5m
\o         50.2s).
\o
\o Peak resident memory used = 477 Mbytes.
\o
\o
\o
\o dcOpInfo: writing operating point information to rawfile.
\o
\o
\o ***************************************************
\o Periodic Steady-State Analysis `pss': fund = 40 MHz
\o
\o Trying `homotopy = gmin' for initial conditions.
\o
\o
\o
\o Warning from spectre during IC analysis, during periodic steady state analysis
\o         `pss'.
\o
\o
\o
\o =============================
\o `pss': time = (0 s -> 600 ns)
\o
\o Important parameter values in tstab integration:
\o
\o     start = 0 s
\o     outputstart = 0 s
\o     stop = 600 ns
\o     period = 25 ns
\o
\o     step = 625 ps
\o
\o     maxstep = 1 ns
\o
\o     ic = all
\o
\o     useprevic = no
\o     skipdc = no
\o
\o     reltol = 1e-03
\o
\o
\o
\o     temp = 27 C
\o
\o     tnom = 27 C
\o
\o     method = gear2only
\o
\o     lteratio = 3.5
\o
\o     relref = sigglobal
\o
\o     cmin = 0 F
\o
\o     gmin = 1 pS
\o
\o
\o
\o
\o     pss: time = 825 ps      (138 m%), step = 20 ps       (3.33 m%)
\o
\o     pss: time = 1.39 ns     (232 m%), step = 4.294 ps     (716 u%)
\o
\o     pss: time = 1.895 ns    (316 m%), step = 2.44 ps      (407 u%)
\o
\o     pss: time = 2.39 ns     (398 m%), step = 318.4 fs    (53.1 u%)
\o
\o     pss: time = 2.887 ns    (481 m%), step = 1.853 ps     (309 u%)
\o
\o     pss: time = 3.424 ns    (571 m%), step = 5.775 ps     (963 u%)
\o
\o     pss: time = 4.015 ns    (669 m%), step = 10 ps       (1.67 m%)
\o
\o     pss: time = 4.626 ns    (771 m%), step = 3.684 ps     (614 u%)
\o
\o     pss: time = 5.142 ns    (857 m%), step = 2.462 ps     (410 u%)
\o
\o     pss: time = 5.679 ns    (946 m%), step = 8.409 ps     (1.4 m%)
\o
\o     pss: time = 6.188 ns    (1.03 %), step = 9.388 ps    (1.56 m%)
\o
\o     pss: time = 6.754 ns    (1.13 %), step = 2.609 ps     (435 u%)
\o
\o     pss: time = 7.384 ns    (1.23 %), step = 3.694 ps     (616 u%)
\o
\o     pss: time = 7.895 ns    (1.32 %), step = 1.542 ps     (257 u%)
\o
\o     pss: time = 8.395 ns     (1.4 %), step = 148.4 fs    (24.7 u%)
\o
\o     pss: time = 8.897 ns    (1.48 %), step = 2.191 ps     (365 u%)
\o
\o     pss: time = 9.395 ns    (1.57 %), step = 2.638 ps     (440 u%)
\o
\o     pss: time = 9.891 ns    (1.65 %), step = 1.859 ps     (310 u%)
\o
\o     pss: time = 10.4 ns     (1.73 %), step = 614 fs       (102 u%)
\o
\o     pss: time = 10.96 ns    (1.83 %), step = 9.064 ps    (1.51 m%)
\o
\o     pss: time = 11.58 ns    (1.93 %), step = 26.53 ps    (4.42 m%)
\o
\o     pss: time = 12.13 ns    (2.02 %), step = 3.609 ps     (601 u%)
\o
\o     pss: time = 12.69 ns    (2.11 %), step = 9.653 ps    (1.61 m%)
\o
\o     pss: time = 13.23 ns    (2.21 %), step = 10.8 ps      (1.8 m%)
\o
\o     pss: time = 13.88 ns    (2.31 %), step = 2.217 ps     (370 u%)
\o
\o     pss: time = 14.4 ns      (2.4 %), step = 2.237 ps     (373 u%)
\o
\o     pss: time = 14.91 ns    (2.48 %), step = 4.638 ps     (773 u%)
\o
\o     pss: time = 15 ns        (2.5 %), step = 582.4 fs    (97.1 u%)
\o
\o     pss: time = 15.62 ns     (2.6 %), step = 20 ps       (3.33 m%)
\o
\o     pss: time = 16.12 ns    (2.69 %), step = 7.32 ps     (1.22 m%)
\o
\o     pss: time = 16.63 ns    (2.77 %), step = 4.66 ps      (777 u%)
\o
\o     pss: time = 17.15 ns    (2.86 %), step = 3.426 ps     (571 u%)
\o
\o     pss: time = 17.7 ns     (2.95 %), step = 8.706 ps    (1.45 m%)
\o
\o     pss: time = 18.29 ns    (3.05 %), step = 10 ps       (1.67 m%)
\o
\o     pss: time = 18.88 ns    (3.15 %), step = 4.427 ps     (738 u%)
\o
\o     pss: time = 19.4 ns     (3.23 %), step = 55.58 fs    (9.26 u%)
\o
\o     pss: time = 19.91 ns    (3.32 %), step = 5.653 ps     (942 u%)
\o
\o     pss: time = 20.4 ns      (3.4 %), step = 2.251 ps     (375 u%)
\o
\o     pss: time = 20.96 ns    (3.49 %), step = 8.874 ps    (1.48 m%)
\o
\o     pss: time = 21.47 ns    (3.58 %), step = 9.535 ps    (1.59 m%)
\o
\o     pss: time = 22.07 ns    (3.68 %), step = 20 ps       (3.33 m%)
\o
\o     pss: time = 22.62 ns    (3.77 %), step = 7.341 ps    (1.22 m%)
\o
\o     pss: time = 23.14 ns    (3.86 %), step = 4.244 ps     (707 u%)
\o
\o     pss: time = 23.66 ns    (3.94 %), step = 5.911 ps     (985 u%)
\o
\o     pss: time = 24.22 ns    (4.04 %), step = 9.149 ps    (1.52 m%)
\o
\o     pss: time = 24.8 ns     (4.13 %), step = 5 ps         (833 u%)
\o
\o     pss: time = 25.36 ns    (4.23 %), step = 20 ps       (3.33 m%)
\o
\o     pss: time = 25.9 ns     (4.32 %), step = 3.864 ps     (644 u%)
\o
\o     pss: time = 26.44 ns    (4.41 %), step = 9.511 ps    (1.59 m%)
\o
\o     pss: time = 27.02 ns     (4.5 %), step = 5.46 ps      (910 u%)
\o
\o     pss: time = 27.61 ns     (4.6 %), step = 18.19 ps    (3.03 m%)
\o
\o     pss: time = 28.14 ns    (4.69 %), step = 2.497 ps     (416 u%)
\o
\o     pss: time = 28.66 ns    (4.78 %), step = 5.912 ps     (985 u%)
\o
\o     pss: time = 29.22 ns    (4.87 %), step = 9.08 ps     (1.51 m%)
\o
\o     pss: time = 29.72 ns    (4.95 %), step = 8.85 ps     (1.48 m%)
\o
\o     pss: time = 30.26 ns    (5.04 %), step = 3.236 ps     (539 u%)
\o
\o     pss: time = 30.86 ns    (5.14 %), step = 20 ps       (3.33 m%)
\o
\o     pss: time = 31.38 ns    (5.23 %), step = 4.346 ps     (724 u%)
\o
\o     pss: time = 31.9 ns     (5.32 %), step = 3.554 ps     (592 u%)
\o
\o     pss: time = 32.48 ns    (5.41 %), step = 9.582 ps     (1.6 m%)
\o
\o     pss: time = 33.03 ns     (5.5 %), step = 10.89 ps    (1.82 m%)
\o
\o     pss: time = 33.65 ns    (5.61 %), step = 2.556 ps     (426 u%)
\o
\o     pss: time = 34.19 ns     (5.7 %), step = 7.267 ps    (1.21 m%)
\o
\o     pss: time = 34.88 ns    (5.81 %), step = 4.421 ps     (737 u%)
\o
\o     pss: time = 35.41 ns     (5.9 %), step = 3.942 ps     (657 u%)
\o
\o     pss: time = 35.95 ns    (5.99 %), step = 8.631 ps    (1.44 m%)
\o
\o     pss: time = 36.62 ns     (6.1 %), step = 20 ps       (3.33 m%)
\o
\o     pss: time = 37.15 ns    (6.19 %), step = 3.277 ps     (546 u%)
\o
\o     pss: time = 37.79 ns     (6.3 %), step = 23.92 ps    (3.99 m%)
\o
\o     pss: time = 38.37 ns     (6.4 %), step = 7.769 ps    (1.29 m%)
\o
\o     pss: time = 38.91 ns    (6.48 %), step = 4.03 ps      (672 u%)
\o
\o     pss: time = 39.46 ns    (6.58 %), step = 8.735 ps    (1.46 m%)
\o
\o     pss: time = 40.05 ns    (6.67 %), step = 4.653 ps     (775 u%)
\o
\o     pss: time = 40.64 ns    (6.77 %), step = 4.152 ps     (692 u%)
\o
\o     pss: time = 41.17 ns    (6.86 %), step = 5.589 ps     (932 u%)
\o
\o     pss: time = 41.71 ns    (6.95 %), step = 8.763 ps    (1.46 m%)
\o
\o     pss: time = 42.34 ns    (7.06 %), step = 30 ps          (5 m%)
\o
\o     pss: time = 42.89 ns    (7.15 %), step = 1.383 ps     (230 u%)
\o
\o     pss: time = 43.41 ns    (7.24 %), step = 5.719 ps     (953 u%)
\o
\o     pss: time = 44 ns       (7.33 %), step = 5.482 ps     (914 u%)
\o
\o     pss: time = 44.63 ns    (7.44 %), step = 3.214 ps     (536 u%)
\o
\o     pss: time = 45 ns        (7.5 %), step = 12.21 ps    (2.03 m%)
\o
\o     pss: time = 45.63 ns     (7.6 %), step = 3.213 ps     (535 u%)
\o
\o     pss: time = 46.15 ns    (7.69 %), step = 3.214 ps     (536 u%)
\o
\o     pss: time = 46.7 ns     (7.78 %), step = 8.667 ps    (1.44 m%)
\o
\o     pss: time = 47.25 ns    (7.88 %), step = 5 ps         (833 u%)
\o
\o     pss: time = 47.88 ns    (7.98 %), step = 3.553 ps     (592 u%)
\o
\o     pss: time = 48.4 ns     (8.07 %), step = 1.183 ps     (197 u%)
\o
\o     pss: time = 48.92 ns    (8.15 %), step = 6.212 ps    (1.04 m%)
\o
\o     pss: time = 49.5 ns     (8.25 %), step = 10.07 ps    (1.68 m%)
\o
\o     pss: time = 50.13 ns    (8.35 %), step = 3.595 ps     (599 u%)
\o
\o     pss: time = 50.65 ns    (8.44 %), step = 3.274 ps     (546 u%)
\o
\o     pss: time = 51.2 ns     (8.53 %), step = 8.579 ps    (1.43 m%)
\o
\o     pss: time = 51.82 ns    (8.64 %), step = 20 ps       (3.33 m%)
\o
\o     pss: time = 52.39 ns    (8.73 %), step = 2.346 ps     (391 u%)
\o
\o     pss: time = 52.9 ns     (8.82 %), step = 439.8 fs    (73.3 u%)
\o
\o     pss: time = 53.43 ns     (8.9 %), step = 8.535 ps    (1.42 m%)
\o
\o     pss: time = 53.99 ns       (9 %), step = 12.67 ps    (2.11 m%)
\o
\o     pss: time = 54.55 ns    (9.09 %), step = 5.538 ps     (923 u%)
\o
\o     pss: time = 55.14 ns    (9.19 %), step = 4.279 ps     (713 u%)
\o
\o     pss: time = 55.64 ns    (9.27 %), step = 2.65 ps      (442 u%)
\o
\o     pss: time = 56.16 ns    (9.36 %), step = 3.688 ps     (615 u%)
\o
\o     pss: time = 56.71 ns    (9.45 %), step = 8.44 ps     (1.41 m%)
\o
\o     pss: time = 57.25 ns    (9.54 %), step = 5 ps         (833 u%)
\o
\o     pss: time = 57.87 ns    (9.64 %), step = 20 ps       (3.33 m%)
\o
\o     pss: time = 58.38 ns    (9.73 %), step = 3.607 ps     (601 u%)
\o
\o     pss: time = 58.89 ns    (9.82 %), step = 2.325 ps     (387 u%)
\o
\o     pss: time = 59.4 ns      (9.9 %), step = 2.114 ps     (352 u%)
\o
\o     pss: time = 59.99 ns      (10 %), step = 12.56 ps    (2.09 m%)
\o
\o     pss: time = 60.59 ns    (10.1 %), step = 10.91 ps    (1.82 m%)
\o
\o     pss: time = 61.15 ns    (10.2 %), step = 3.115 ps     (519 u%)
\o
\o     pss: time = 61.7 ns     (10.3 %), step = 9.16 ps     (1.53 m%)
\o
\o     pss: time = 62.34 ns    (10.4 %), step = 30 ps          (5 m%)
\o
\o     pss: time = 62.89 ns    (10.5 %), step = 1.93 ps      (322 u%)
\o
\o     pss: time = 63.4 ns     (10.6 %), step = 4.537 ps     (756 u%)
\o
\o     pss: time = 64.01 ns    (10.7 %), step = 10 ps       (1.67 m%)
\o
\o     pss: time = 64.6 ns     (10.8 %), step = 24.09 ps    (4.02 m%)
\o
\o     pss: time = 65.15 ns    (10.9 %), step = 2.508 ps     (418 u%)
\o
\o     pss: time = 65.68 ns    (10.9 %), step = 9.065 ps    (1.51 m%)
\o
\o     pss: time = 66.29 ns      (11 %), step = 10 ps       (1.67 m%)
\o
\o     pss: time = 66.88 ns    (11.1 %), step = 3.446 ps     (574 u%)
\o
\o     pss: time = 67.4 ns     (11.2 %), step = 517.8 fs    (86.3 u%)
\o
\o     pss: time = 67.98 ns    (11.3 %), step = 10.37 ps    (1.73 m%)
\o
\o     pss: time = 68.53 ns    (11.4 %), step = 20 ps       (3.33 m%)
\o
\o     pss: time = 69.14 ns    (11.5 %), step = 2.643 ps     (441 u%)
\o
\o     pss: time = 69.65 ns    (11.6 %), step = 3.145 ps     (524 u%)
\o
\o     pss: time = 70.23 ns    (11.7 %), step = 10.08 ps    (1.68 m%)
\o
\o     pss: time = 70.7 ns     (11.8 %), step = 7.233 ps    (1.21 m%)
\o
\o     pss: time = 71.23 ns    (11.9 %), step = 10.09 ps    (1.68 m%)
\o
\o     pss: time = 71.88 ns      (12 %), step = 4.412 ps     (735 u%)
\o
\o     pss: time = 72.42 ns    (12.1 %), step = 6.095 ps    (1.02 m%)
\o
\o     pss: time = 72.99 ns    (12.2 %), step = 12.23 ps    (2.04 m%)
\o
\o     pss: time = 73.63 ns    (12.3 %), step = 3.732 ps     (622 u%)
\o
\o     pss: time = 74.17 ns    (12.4 %), step = 6.675 ps    (1.11 m%)
\o
\o     pss: time = 74.81 ns    (12.5 %), step = 10 ps       (1.67 m%)
\o
\o     pss: time = 75 ns       (12.5 %), step = 9.529 ps    (1.59 m%)
\o
\o     pss: time = 75.64 ns    (12.6 %), step = 3.264 ps     (544 u%)
\o
\o     pss: time = 76.18 ns    (12.7 %), step = 8.732 ps    (1.46 m%)
\o
\o     pss: time = 76.75 ns    (12.8 %), step = 12.35 ps    (2.06 m%)
\o
\o     pss: time = 77.37 ns    (12.9 %), step = 7.766 ps    (1.29 m%)
\o
\o     pss: time = 77.89 ns      (13 %), step = 1.485 ps     (248 u%)
\o
\o     pss: time = 78.42 ns    (13.1 %), step = 5.561 ps     (927 u%)
\o
\o     pss: time = 78.98 ns    (13.2 %), step = 10.18 ps     (1.7 m%)
\o
\o     pss: time = 79.54 ns    (13.3 %), step = 14.02 ps    (2.34 m%)
\o
\o     pss: time = 80.13 ns    (13.4 %), step = 3.59 ps      (598 u%)
\o
\o     pss: time = 80.65 ns    (13.4 %), step = 2.562 ps     (427 u%)
\o
\o     pss: time = 81.2 ns     (13.5 %), step = 8.446 ps    (1.41 m%)
\o
\o     pss: time = 81.85 ns    (13.6 %), step = 20 ps       (3.33 m%)
\o
\o     pss: time = 82.4 ns     (13.7 %), step = 2.409 ps     (402 u%)
\o
\o     pss: time = 82.96 ns    (13.8 %), step = 8.519 ps    (1.42 m%)
\o
\o     pss: time = 83.6 ns     (13.9 %), step = 2.312 ps     (385 u%)
\o
\o     pss: time = 84.14 ns      (14 %), step = 2.49 ps      (415 u%)
\o
\o     pss: time = 84.67 ns    (14.1 %), step = 6.11 ps     (1.02 m%)
\o
\o     pss: time = 85.25 ns    (14.2 %), step = 5 ps         (833 u%)
\o
\o     pss: time = 85.88 ns    (14.3 %), step = 3.403 ps     (567 u%)
\o
\o     pss: time = 86.4 ns     (14.4 %), step = 2.416 ps     (403 u%)
\o
\o     pss: time = 86.92 ns    (14.5 %), step = 7.345 ps    (1.22 m%)
\o
\o     pss: time = 87.53 ns    (14.6 %), step = 20 ps       (3.33 m%)
\o
\o     pss: time = 88.13 ns    (14.7 %), step = 3.589 ps     (598 u%)
\o
\o     pss: time = 88.66 ns    (14.8 %), step = 3.543 ps     (591 u%)
\o
\o     pss: time = 89.21 ns    (14.9 %), step = 8.295 ps    (1.38 m%)
\o
\o     pss: time = 89.88 ns      (15 %), step = 4.41 ps      (735 u%)
\o
\o     pss: time = 90.4 ns     (15.1 %), step = 2.422 ps     (404 u%)
\o
\o     pss: time = 90.95 ns    (15.2 %), step = 8.203 ps    (1.37 m%)
\o
\o     pss: time = 91.62 ns    (15.3 %), step = 7.335 ps    (1.22 m%)
\o
\o     pss: time = 92.15 ns    (15.4 %), step = 2.511 ps     (418 u%)
\o
\o     pss: time = 92.72 ns    (15.5 %), step = 8.625 ps    (1.44 m%)
\o
\o     pss: time = 93.26 ns    (15.5 %), step = 10 ps       (1.67 m%)
\o
\o     pss: time = 93.89 ns    (15.6 %), step = 1.514 ps     (252 u%)
\o
\o     pss: time = 94.42 ns    (15.7 %), step = 5.632 ps     (939 u%)
\o
\o     pss: time = 94.99 ns    (15.8 %), step = 12.45 ps    (2.08 m%)
\o
\o     pss: time = 95.64 ns    (15.9 %), step = 4.175 ps     (696 u%)
\o
\o     pss: time = 96.16 ns      (16 %), step = 3.246 ps     (541 u%)
\o
\o     pss: time = 96.79 ns    (16.1 %), step = 21.63 ps     (3.6 m%)
\o
\o     pss: time = 97.38 ns    (16.2 %), step = 3.372 ps     (562 u%)
\o
\o     pss: time = 97.9 ns     (16.3 %), step = 2.703 ps     (450 u%)
\o
\o     pss: time = 98.45 ns    (16.4 %), step = 8.292 ps    (1.38 m%)
\o
\o     pss: time = 99.03 ns    (16.5 %), step = 20 ps       (3.33 m%)
\o
\o     pss: time = 99.64 ns    (16.6 %), step = 1.282 ps     (214 u%)
\o
\o     pss: time = 100.2 ns    (16.7 %), step = 8.035 ps    (1.34 m%)
\o
\o     pss: time = 100.8 ns    (16.8 %), step = 20 ps       (3.33 m%)
\o
\o     pss: time = 101.4 ns    (16.9 %), step = 2.341 ps     (390 u%)
\o
\o     pss: time = 101.9 ns      (17 %), step = 7.484 ps    (1.25 m%)
\o
\o     pss: time = 102.6 ns    (17.1 %), step = 26.65 ps    (4.44 m%)
\o
\o     pss: time = 103.1 ns    (17.2 %), step = 2.488 ps     (415 u%)
\o
\o     pss: time = 103.7 ns    (17.3 %), step = 6.019 ps       (1 m%)
\o
\o     pss: time = 104.2 ns    (17.4 %), step = 5 ps         (833 u%)
\o
\o     pss: time = 104.9 ns    (17.5 %), step = 791.1 fs     (132 u%)
\o
\o     pss: time = 105 ns      (17.5 %), step = 9.225 ps    (1.54 m%)
\o
\o     pss: time = 105.6 ns    (17.6 %), step = 7.334 ps    (1.22 m%)
\o
\o     pss: time = 106.1 ns    (17.7 %), step = 1.256 ps     (209 u%)
\o
\o     pss: time = 106.7 ns    (17.8 %), step = 7.796 ps     (1.3 m%)
\o
\o     pss: time = 107.2 ns    (17.9 %), step = 5 ps         (833 u%)
\o
\o     pss: time = 107.9 ns      (18 %), step = 797.9 fs     (133 u%)
\o
\o     pss: time = 108.4 ns    (18.1 %), step = 4.016 ps     (669 u%)
\o
\o     pss: time = 108.9 ns    (18.2 %), step = 5.362 ps     (894 u%)
\o
\o     pss: time = 109.5 ns    (18.3 %), step = 10 ps       (1.67 m%)
\o
\o     pss: time = 110.1 ns    (18.4 %), step = 7.314 ps    (1.22 m%)
\o
\o     pss: time = 110.7 ns    (18.4 %), step = 6.763 ps    (1.13 m%)
\o
\o     pss: time = 111.2 ns    (18.5 %), step = 8.169 ps    (1.36 m%)
\o
\o     pss: time = 111.9 ns    (18.6 %), step = 20 ps       (3.33 m%)
\o
\o     pss: time = 112.4 ns    (18.7 %), step = 20 ps       (3.33 m%)
\o
\o     pss: time = 112.9 ns    (18.8 %), step = 2.378 ps     (396 u%)
\o
\o     pss: time = 113.5 ns    (18.9 %), step = 9.571 ps     (1.6 m%)
\o
\o     pss: time = 114 ns        (19 %), step = 20 ps       (3.33 m%)
\o
\o     pss: time = 114.6 ns    (19.1 %), step = 2.434 ps     (406 u%)
\o
\o     pss: time = 115.2 ns    (19.2 %), step = 6.786 ps    (1.13 m%)
\o
\o     pss: time = 115.8 ns    (19.3 %), step = 19.8 ps      (3.3 m%)
\o
\o     pss: time = 116.3 ns    (19.4 %), step = 30 ps          (5 m%)
\o
\o     pss: time = 116.9 ns    (19.5 %), step = 1.424 ps     (237 u%)
\o
\o     pss: time = 117.5 ns    (19.6 %), step = 9.686 ps    (1.61 m%)
\o
\o     pss: time = 118.1 ns    (19.7 %), step = 10 ps       (1.67 m%)
\o
\o     pss: time = 118.6 ns    (19.8 %), step = 2.566 ps     (428 u%)
\o
\o     pss: time = 119.2 ns    (19.9 %), step = 3.064 ps     (511 u%)
\o
\o     pss: time = 119.7 ns      (20 %), step = 11.45 ps    (1.91 m%)
\o
\o     pss: time = 120.3 ns    (20.1 %), step = 20 ps       (3.33 m%)
\o
\o     pss: time = 120.9 ns    (20.1 %), step = 2.368 ps     (395 u%)
\o
\o     pss: time = 121.4 ns    (20.2 %), step = 6.343 ps    (1.06 m%)
\o
\o     pss: time = 122.1 ns    (20.3 %), step = 10 ps       (1.67 m%)
\o
\o     pss: time = 122.6 ns    (20.4 %), step = 2.345 ps     (391 u%)
\o
\o     pss: time = 123.2 ns    (20.5 %), step = 3.5 ps       (583 u%)
\o
\o     pss: time = 123.8 ns    (20.6 %), step = 10 ps       (1.67 m%)
\o
\o     pss: time = 124.4 ns    (20.7 %), step = 2.888 ps     (481 u%)
\o
\o     pss: time = 124.9 ns    (20.8 %), step = 5.954 ps     (992 u%)
\o
\o     pss: time = 125.6 ns    (20.9 %), step = 20 ps       (3.33 m%)
\o
\o     pss: time = 126.1 ns      (21 %), step = 1.257 ps     (210 u%)
\o
\o     pss: time = 126.7 ns    (21.1 %), step = 12.35 ps    (2.06 m%)
\o
\o     pss: time = 127.3 ns    (21.2 %), step = 30 ps          (5 m%)
\o
\o     pss: time = 127.9 ns    (21.3 %), step = 616 fs       (103 u%)
\o
\o     pss: time = 128.4 ns    (21.4 %), step = 3.795 ps     (632 u%)
\o
\o     pss: time = 128.9 ns    (21.5 %), step = 8.923 ps    (1.49 m%)
\o
\o     pss: time = 129.6 ns    (21.6 %), step = 20 ps       (3.33 m%)
\o
\o     pss: time = 130.1 ns    (21.7 %), step = 2.515 ps     (419 u%)
\o
\o     pss: time = 130.7 ns    (21.8 %), step = 12.35 ps    (2.06 m%)
\o
\o     pss: time = 131.3 ns    (21.9 %), step = 18.97 ps    (3.16 m%)
\o
\o     pss: time = 131.9 ns      (22 %), step = 1.99 ps      (332 u%)
\o
\o     pss: time = 132.5 ns    (22.1 %), step = 12.74 ps    (2.12 m%)
\o
\o     pss: time = 133.1 ns    (22.2 %), step = 3.023 ps     (504 u%)
\o
\o     pss: time = 133.7 ns    (22.3 %), step = 4.921 ps     (820 u%)
\o
\o     pss: time = 134.2 ns    (22.4 %), step = 12.65 ps    (2.11 m%)
\o
\o     pss: time = 134.9 ns    (22.5 %), step = 853 fs       (142 u%)
\o
\o     pss: time = 135 ns      (22.5 %), step = 11.05 ps    (1.84 m%)
\o
\o     pss: time = 135.6 ns    (22.6 %), step = 3.159 ps     (527 u%)
\o
\o     pss: time = 136.2 ns    (22.7 %), step = 3.322 ps     (554 u%)
\o
\o     pss: time = 136.8 ns    (22.8 %), step = 21.58 ps     (3.6 m%)
\o
\o     pss: time = 137.3 ns    (22.9 %), step = 13.75 ps    (2.29 m%)
\o
\o     pss: time = 137.9 ns      (23 %), step = 555.7 fs    (92.6 u%)
\o
\o     pss: time = 138.4 ns    (23.1 %), step = 6.095 ps    (1.02 m%)
\o
\o     pss: time = 139 ns      (23.2 %), step = 2.584 ps     (431 u%)
\o
\o     pss: time = 139.6 ns    (23.3 %), step = 3.624 ps     (604 u%)
\o
\o     pss: time = 140.1 ns    (23.4 %), step = 1.258 ps     (210 u%)
\o
\o     pss: time = 140.7 ns    (23.5 %), step = 12.18 ps    (2.03 m%)
\o
\o     pss: time = 141.3 ns    (23.6 %), step = 28.49 ps    (4.75 m%)
\o
\o     pss: time = 141.9 ns    (23.6 %), step = 1.924 ps     (321 u%)
\o
\o     pss: time = 142.4 ns    (23.7 %), step = 6.484 ps    (1.08 m%)
\o
\o     pss: time = 143 ns      (23.8 %), step = 16.05 ps    (2.67 m%)
\o
\o     pss: time = 143.6 ns    (23.9 %), step = 3.271 ps     (545 u%)
\o
\o     pss: time = 144.2 ns      (24 %), step = 2.805 ps     (467 u%)
\o
\o     pss: time = 144.7 ns    (24.1 %), step = 8.684 ps    (1.45 m%)
\o
\o     pss: time = 145.3 ns    (24.2 %), step = 18.33 ps    (3.06 m%)
\o
\o     pss: time = 145.9 ns    (24.3 %), step = 498.9 fs    (83.2 u%)
\o
\o     pss: time = 146.4 ns    (24.4 %), step = 7.977 ps    (1.33 m%)
\o
\o     pss: time = 147 ns      (24.5 %), step = 847.4 fs     (141 u%)
\o
\o     pss: time = 147.6 ns    (24.6 %), step = 20 ps       (3.33 m%)
\o
\o     pss: time = 148.1 ns    (24.7 %), step = 2.517 ps     (419 u%)
\o
\o     pss: time = 148.7 ns    (24.8 %), step = 11.84 ps    (1.97 m%)
\o
\o     pss: time = 149.3 ns    (24.9 %), step = 25.64 ps    (4.27 m%)
\o
\o     pss: time = 149.9 ns      (25 %), step = 3.451 ps     (575 u%)
\o
\o     pss: time = 150.5 ns    (25.1 %), step = 9.265 ps    (1.54 m%)
\o
\o     pss: time = 151.1 ns    (25.2 %), step = 10 ps       (1.67 m%)
\o
\o     pss: time = 151.7 ns    (25.3 %), step = 3.031 ps     (505 u%)
\o
\o     pss: time = 152.2 ns    (25.4 %), step = 6.46 ps     (1.08 m%)
\o
\o     pss: time = 152.8 ns    (25.5 %), step = 20 ps       (3.33 m%)
\o
\o     pss: time = 153.3 ns    (25.6 %), step = 3.259 ps     (543 u%)
\o
\o     pss: time = 153.9 ns    (25.6 %), step = 2.71 ps      (452 u%)
\o
\o     pss: time = 154.4 ns    (25.7 %), step = 3.581 ps     (597 u%)
\o
\o     pss: time = 154.9 ns    (25.8 %), step = 4.855 ps     (809 u%)
\o
\o     pss: time = 155.5 ns    (25.9 %), step = 7.18 ps      (1.2 m%)
\o
\o     pss: time = 156.1 ns      (26 %), step = 10 ps       (1.67 m%)
\o
\o     pss: time = 156.6 ns    (26.1 %), step = 2.431 ps     (405 u%)
\o
\o     pss: time = 157.2 ns    (26.2 %), step = 8.331 ps    (1.39 m%)
\o
\o     pss: time = 157.8 ns    (26.3 %), step = 20 ps       (3.33 m%)
\o
\o     pss: time = 158.4 ns    (26.4 %), step = 7.762 ps    (1.29 m%)
\o
\o     pss: time = 158.9 ns    (26.5 %), step = 3.046 ps     (508 u%)
\o
\o     pss: time = 159.5 ns    (26.6 %), step = 9.296 ps    (1.55 m%)
\o
\o     pss: time = 160.1 ns    (26.7 %), step = 20 ps       (3.33 m%)
\o
\o     pss: time = 160.6 ns    (26.8 %), step = 3.121 ps     (520 u%)
\o
\o     pss: time = 161.2 ns    (26.9 %), step = 2.677 ps     (446 u%)
\o
\o     pss: time = 161.8 ns      (27 %), step = 6.214 ps    (1.04 m%)
\o
\o     pss: time = 162.3 ns      (27 %), step = 20 ps       (3.33 m%)
\o
\o     pss: time = 162.8 ns    (27.1 %), step = 20 ps       (3.33 m%)
\o
\o     pss: time = 163.3 ns    (27.2 %), step = 2.544 ps     (424 u%)
\o
\o     pss: time = 163.9 ns    (27.3 %), step = 1.363 ps     (227 u%)
\o
\o     pss: time = 164.4 ns    (27.4 %), step = 2.336 ps     (389 u%)
\o
\o     pss: time = 164.9 ns    (27.5 %), step = 4.445 ps     (741 u%)
\o
\o     pss: time = 165 ns      (27.5 %), step = 5.739 ps     (956 u%)
\o
\o     pss: time = 165.5 ns    (27.6 %), step = 10 ps       (1.67 m%)
\o
\o     pss: time = 166.1 ns    (27.7 %), step = 20 ps       (3.33 m%)
\o
\o     pss: time = 166.6 ns    (27.8 %), step = 4.188 ps     (698 u%)
\o
\o     pss: time = 167.1 ns    (27.9 %), step = 2.519 ps     (420 u%)
\o
\o     pss: time = 167.7 ns    (27.9 %), step = 5.516 ps     (919 u%)
\o
\o     pss: time = 168.2 ns      (28 %), step = 5.978 ps     (996 u%)
\o
\o     pss: time = 168.8 ns    (28.1 %), step = 22.15 ps    (3.69 m%)
\o
\o     pss: time = 169.3 ns    (28.2 %), step = 20 ps       (3.33 m%)
\o
\o     pss: time = 169.9 ns    (28.3 %), step = 1.798 ps     (300 u%)
\o
\o     pss: time = 170.4 ns    (28.4 %), step = 2.481 ps     (413 u%)
\o
\o     pss: time = 171 ns      (28.5 %), step = 8.408 ps     (1.4 m%)
\o
\o     pss: time = 171.6 ns    (28.6 %), step = 26.71 ps    (4.45 m%)
\o
\o     pss: time = 172.1 ns    (28.7 %), step = 2.481 ps     (414 u%)
\o
\o     pss: time = 172.7 ns    (28.8 %), step = 14.3 ps     (2.38 m%)
\o
\o     pss: time = 173.3 ns    (28.9 %), step = 20 ps       (3.33 m%)
\o
\o     pss: time = 173.9 ns      (29 %), step = 1.372 ps     (229 u%)
\o
\o     pss: time = 174.4 ns    (29.1 %), step = 3.645 ps     (607 u%)
\o
\o     pss: time = 175 ns      (29.2 %), step = 9.722 ps    (1.62 m%)
\o
\o     pss: time = 175.6 ns    (29.3 %), step = 3.622 ps     (604 u%)
\o
\o     pss: time = 176.1 ns    (29.4 %), step = 2.48 ps      (413 u%)
\o
\o     pss: time = 176.7 ns    (29.5 %), step = 8.487 ps    (1.41 m%)
\o
\o     pss: time = 177.2 ns    (29.5 %), step = 9.83 ps     (1.64 m%)
\o
\o     pss: time = 177.9 ns    (29.6 %), step = 4.404 ps     (734 u%)
\o
\o     pss: time = 178.4 ns    (29.7 %), step = 3.014 ps     (502 u%)
\o
\o     pss: time = 178.9 ns    (29.8 %), step = 3.09 ps      (515 u%)
\o
\o     pss: time = 179.5 ns    (29.9 %), step = 8.98 ps      (1.5 m%)
\o
\o     pss: time = 180 ns        (30 %), step = 10.39 ps    (1.73 m%)
\o
\o     pss: time = 180.6 ns    (30.1 %), step = 4.189 ps     (698 u%)
\o
\o     pss: time = 181.2 ns    (30.2 %), step = 2.785 ps     (464 u%)
\o
\o     pss: time = 181.8 ns    (30.3 %), step = 16.69 ps    (2.78 m%)
\o
\o     pss: time = 182.2 ns    (30.4 %), step = 6.867 ps    (1.14 m%)
\o
\o     pss: time = 182.9 ns    (30.5 %), step = 4.403 ps     (734 u%)
\o
\o     pss: time = 183.4 ns    (30.6 %), step = 3.001 ps     (500 u%)
\o
\o     pss: time = 184 ns      (30.7 %), step = 9.783 ps    (1.63 m%)
\o
\o     pss: time = 184.5 ns    (30.7 %), step = 10.13 ps    (1.69 m%)
\o
\o     pss: time = 185 ns      (30.8 %), step = 5 ps         (833 u%)
\o
\o     pss: time = 185.5 ns    (30.9 %), step = 10 ps       (1.67 m%)
\o
\o     pss: time = 186.1 ns      (31 %), step = 4.33 ps      (722 u%)
\o
\o     pss: time = 186.6 ns    (31.1 %), step = 3.093 ps     (515 u%)
\o
\o     pss: time = 187.2 ns    (31.2 %), step = 4.835 ps     (806 u%)
\o
\o     pss: time = 187.7 ns    (31.3 %), step = 9.503 ps    (1.58 m%)
\o
\o     pss: time = 188.2 ns    (31.4 %), step = 377.2 fs    (62.9 u%)
\o
\o     pss: time = 188.9 ns    (31.5 %), step = 911.7 fs     (152 u%)
\o
\o     pss: time = 189.4 ns    (31.6 %), step = 3.365 ps     (561 u%)
\o
\o     pss: time = 189.9 ns    (31.7 %), step = 6.995 ps    (1.17 m%)
\o
\o     pss: time = 190.4 ns    (31.7 %), step = 2.794 ps     (466 u%)
\o
\o     pss: time = 191 ns      (31.8 %), step = 9.385 ps    (1.56 m%)
\o
\o     pss: time = 191.6 ns    (31.9 %), step = 26.72 ps    (4.45 m%)
\o
\o     pss: time = 192.1 ns      (32 %), step = 1.261 ps     (210 u%)
\o
\o     pss: time = 192.7 ns    (32.1 %), step = 6.794 ps    (1.13 m%)
\o
\o     pss: time = 193.2 ns    (32.2 %), step = 1.062 ps     (177 u%)
\o
\o     pss: time = 193.9 ns    (32.3 %), step = 1.834 ps     (306 u%)
\o
\o     pss: time = 194.4 ns    (32.4 %), step = 2.49 ps      (415 u%)
\o
\o     pss: time = 195 ns      (32.5 %), step = 8.608 ps    (1.43 m%)
\o
\o     pss: time = 195 ns      (32.5 %), step = 7.448 ps    (1.24 m%)
\o
\o     pss: time = 195.6 ns    (32.6 %), step = 7.329 ps    (1.22 m%)
\o
\o     pss: time = 196.2 ns    (32.7 %), step = 2.59 ps      (432 u%)
\o
\o     pss: time = 196.7 ns    (32.8 %), step = 11.23 ps    (1.87 m%)
\o
\o     pss: time = 197.3 ns    (32.9 %), step = 3.576 ps     (596 u%)
\o
\o     pss: time = 197.9 ns      (33 %), step = 2.765 ps     (461 u%)
\o
\o     pss: time = 198.4 ns    (33.1 %), step = 2.966 ps     (494 u%)
\o
\o     pss: time = 199 ns      (33.2 %), step = 8.632 ps    (1.44 m%)
\o
\o     pss: time = 199.6 ns    (33.3 %), step = 10.69 ps    (1.78 m%)
\o
\o     pss: time = 200.1 ns    (33.4 %), step = 1.261 ps     (210 u%)
\o
\o     pss: time = 200.7 ns    (33.5 %), step = 7.903 ps    (1.32 m%)
\o
\o     pss: time = 201.2 ns    (33.5 %), step = 3.327 ps     (554 u%)
\o
\o     pss: time = 201.9 ns    (33.6 %), step = 7.648 ps    (1.27 m%)
\o
\o     pss: time = 202.4 ns    (33.7 %), step = 3.028 ps     (505 u%)
\o
\o     pss: time = 202.9 ns    (33.8 %), step = 5.44 ps      (907 u%)
\o
\o     pss: time = 203.5 ns    (33.9 %), step = 12.24 ps    (2.04 m%)
\o
\o     pss: time = 204.1 ns      (34 %), step = 3.582 ps     (597 u%)
\o
\o     pss: time = 204.7 ns    (34.1 %), step = 7.376 ps    (1.23 m%)
\o
\o     pss: time = 205.2 ns    (34.2 %), step = 9.296 ps    (1.55 m%)
\o
\o     pss: time = 205.9 ns    (34.3 %), step = 3.641 ps     (607 u%)
\o
\o     pss: time = 206.4 ns    (34.4 %), step = 3.169 ps     (528 u%)
\o
\o     pss: time = 206.9 ns    (34.5 %), step = 6.67 ps     (1.11 m%)
\o
\o     pss: time = 207.5 ns    (34.6 %), step = 10.23 ps     (1.7 m%)
\o
\o     pss: time = 208.1 ns    (34.7 %), step = 20 ps       (3.33 m%)
\o
\o     pss: time = 208.6 ns    (34.8 %), step = 4.245 ps     (708 u%)
\o
\o     pss: time = 209.2 ns    (34.9 %), step = 3.342 ps     (557 u%)
\o
\o     pss: time = 209.8 ns      (35 %), step = 9.446 ps    (1.57 m%)
\o
\o     pss: time = 210.3 ns    (35.1 %), step = 6.995 ps    (1.17 m%)
\o
\o     pss: time = 210.9 ns    (35.1 %), step = 2.323 ps     (387 u%)
\o
\o     pss: time = 211.4 ns    (35.2 %), step = 2.267 ps     (378 u%)
\o
\o     pss: time = 211.9 ns    (35.3 %), step = 2.514 ps     (419 u%)
\o
\o     pss: time = 212.4 ns    (35.4 %), step = 2.937 ps     (490 u%)
\o
\o     pss: time = 212.9 ns    (35.5 %), step = 2.736 ps     (456 u%)
\o
\o     pss: time = 213.4 ns    (35.6 %), step = 2.332 ps     (389 u%)
\o
\o     pss: time = 213.9 ns    (35.7 %), step = 4.583 ps     (764 u%)
\o
\o     pss: time = 214.4 ns    (35.7 %), step = 98.45 fs    (16.4 u%)
\o
\o     pss: time = 214.9 ns    (35.8 %), step = 277.6 fs    (46.3 u%)
\o
\o     pss: time = 215.4 ns    (35.9 %), step = 3.165 ps     (528 u%)
\o
\o     pss: time = 215.9 ns      (36 %), step = 2.279 ps     (380 u%)
\o
\o     pss: time = 216.4 ns    (36.1 %), step = 3.494 ps     (582 u%)
\o
\o     pss: time = 216.9 ns    (36.2 %), step = 8.308 ps    (1.38 m%)
\o
\o     pss: time = 217.5 ns    (36.3 %), step = 10 ps       (1.67 m%)
\o
\o     pss: time = 218.1 ns    (36.4 %), step = 3.581 ps     (597 u%)
\o
\o     pss: time = 218.7 ns    (36.4 %), step = 5.598 ps     (933 u%)
\o
\o     pss: time = 219.2 ns    (36.5 %), step = 2.704 ps     (451 u%)
\o
\o     pss: time = 219.8 ns    (36.6 %), step = 6.885 ps    (1.15 m%)
\o
\o     pss: time = 220.4 ns    (36.7 %), step = 20 ps       (3.33 m%)
\o
\o     pss: time = 220.9 ns    (36.8 %), step = 1.104 ps     (184 u%)
\o
\o     pss: time = 221.5 ns    (36.9 %), step = 10.18 ps     (1.7 m%)
\o
\o     pss: time = 222 ns        (37 %), step = 5 ps         (833 u%)
\o
\o     pss: time = 222.6 ns    (37.1 %), step = 4.237 ps     (706 u%)
\o
\o     pss: time = 223.2 ns    (37.2 %), step = 4.026 ps     (671 u%)
\o
\o     pss: time = 223.8 ns    (37.3 %), step = 20 ps       (3.33 m%)
\o
\o     pss: time = 224.4 ns    (37.4 %), step = 3.162 ps     (527 u%)
\o
\o     pss: time = 224.9 ns    (37.5 %), step = 4.366 ps     (728 u%)
\o
\o     pss: time = 225 ns      (37.5 %), step = 10.82 ps     (1.8 m%)
\o
\o     pss: time = 225.6 ns    (37.6 %), step = 4.39 ps      (732 u%)
\o
\o     pss: time = 226.2 ns    (37.7 %), step = 2.805 ps     (468 u%)
\o
\o     pss: time = 226.8 ns    (37.8 %), step = 5 ps         (833 u%)
\o
\o     pss: time = 227.4 ns    (37.9 %), step = 3.353 ps     (559 u%)
\o
\o     pss: time = 227.9 ns      (38 %), step = 4.33 ps      (722 u%)
\o
\o     pss: time = 228.5 ns    (38.1 %), step = 11.98 ps       (2 m%)
\o
\o     pss: time = 229.1 ns    (38.2 %), step = 20 ps       (3.33 m%)
\o
\o     pss: time = 229.7 ns    (38.3 %), step = 7.846 ps    (1.31 m%)
\o
\o     pss: time = 230.2 ns    (38.4 %), step = 6.985 ps    (1.16 m%)
\o
\o     pss: time = 230.9 ns    (38.5 %), step = 4.402 ps     (734 u%)
\o
\o     pss: time = 231.4 ns    (38.6 %), step = 2.669 ps     (445 u%)
\o
\o     pss: time = 231.9 ns    (38.7 %), step = 6.023 ps       (1 m%)
\o
\o     pss: time = 232.6 ns    (38.8 %), step = 10.66 ps    (1.78 m%)
\o
\o     pss: time = 233.1 ns    (38.9 %), step = 5.777 ps     (963 u%)
\o
\o     pss: time = 233.7 ns    (38.9 %), step = 3.859 ps     (643 u%)
\o
\o     pss: time = 234.2 ns      (39 %), step = 7.192 ps     (1.2 m%)
\o
\o     pss: time = 234.7 ns    (39.1 %), step = 5.88 ps      (980 u%)
\o
\o     pss: time = 235.2 ns    (39.2 %), step = 4.824 ps     (804 u%)
\o
\o     pss: time = 235.8 ns    (39.3 %), step = 20 ps       (3.33 m%)
\o
\o     pss: time = 236.4 ns    (39.4 %), step = 3.355 ps     (559 u%)
\o
\o     pss: time = 236.9 ns    (39.5 %), step = 223.7 fs    (37.3 u%)
\o
\o     pss: time = 237.4 ns    (39.6 %), step = 3.218 ps     (536 u%)
\o
\o     pss: time = 237.9 ns    (39.7 %), step = 3.63 ps      (605 u%)
\o
\o     pss: time = 238.5 ns    (39.7 %), step = 9.978 ps    (1.66 m%)
\o
\o     pss: time = 239 ns      (39.8 %), step = 11.36 ps    (1.89 m%)
\o
\o     pss: time = 239.5 ns    (39.9 %), step = 1.046 ps     (174 u%)
\o
\o     pss: time = 240.1 ns      (40 %), step = 10.62 ps    (1.77 m%)
\o
\o     pss: time = 240.6 ns    (40.1 %), step = 22.83 ps     (3.8 m%)
\o
\o     pss: time = 241.1 ns    (40.2 %), step = 2.469 ps     (411 u%)
\o
\o     pss: time = 241.7 ns    (40.3 %), step = 7.701 ps    (1.28 m%)
\o
\o     pss: time = 242.2 ns    (40.4 %), step = 4.8 ps       (800 u%)
\o
\o     pss: time = 242.8 ns    (40.5 %), step = 18.53 ps    (3.09 m%)
\o
\o     pss: time = 243.3 ns    (40.6 %), step = 20 ps       (3.33 m%)
\o
\o     pss: time = 243.9 ns    (40.6 %), step = 1.404 ps     (234 u%)
\o
\o     pss: time = 244.4 ns    (40.7 %), step = 7.345 ps    (1.22 m%)
\o
\o     pss: time = 245 ns      (40.8 %), step = 8.465 ps    (1.41 m%)
\o
\o     pss: time = 245.5 ns    (40.9 %), step = 4.974 ps     (829 u%)
\o
\o     pss: time = 246.1 ns      (41 %), step = 19.57 ps    (3.26 m%)
\o
\o     pss: time = 246.6 ns    (41.1 %), step = 2.857 ps     (476 u%)
\o
\o     pss: time = 247.1 ns    (41.2 %), step = 7.353 ps    (1.23 m%)
\o
\o     pss: time = 247.6 ns    (41.3 %), step = 4.222 ps     (704 u%)
\o
\o     pss: time = 248.1 ns    (41.4 %), step = 2.467 ps     (411 u%)
\o
\o     pss: time = 248.7 ns    (41.4 %), step = 4.988 ps     (831 u%)
\o
\o     pss: time = 249.2 ns    (41.5 %), step = 6.065 ps    (1.01 m%)
\o
\o     pss: time = 249.8 ns    (41.6 %), step = 5 ps         (833 u%)
\o
\o     pss: time = 250.3 ns    (41.7 %), step = 10 ps       (1.67 m%)
\o
\o     pss: time = 250.9 ns    (41.8 %), step = 4.403 ps     (734 u%)
\o
\o     pss: time = 251.4 ns    (41.9 %), step = 3.344 ps     (557 u%)
\o
\o     pss: time = 251.9 ns      (42 %), step = 420.5 fs    (70.1 u%)
\o
\o     pss: time = 252.4 ns    (42.1 %), step = 2.673 ps     (446 u%)
\o
\o     pss: time = 252.9 ns    (42.2 %), step = 3.245 ps     (541 u%)
\o
\o     pss: time = 253.4 ns    (42.2 %), step = 5.825 ps     (971 u%)
\o
\o     pss: time = 254 ns      (42.3 %), step = 11.02 ps    (1.84 m%)
\o
\o     pss: time = 254.5 ns    (42.4 %), step = 4.994 ps     (832 u%)
\o
\o     pss: time = 255 ns      (42.5 %), step = 5.168 ps     (861 u%)
\o
\o     pss: time = 255.6 ns    (42.6 %), step = 3.621 ps     (603 u%)
\o
\o     pss: time = 256.2 ns    (42.7 %), step = 2.505 ps     (418 u%)
\o
\o     pss: time = 256.7 ns    (42.8 %), step = 8.538 ps    (1.42 m%)
\o
\o     pss: time = 257.2 ns    (42.9 %), step = 11.73 ps    (1.95 m%)
\o
\o     pss: time = 257.9 ns      (43 %), step = 4.402 ps     (734 u%)
\o
\o     pss: time = 258.4 ns    (43.1 %), step = 3.06 ps      (510 u%)
\o
\o     pss: time = 258.9 ns    (43.2 %), step = 6.146 ps    (1.02 m%)
\o
\o     pss: time = 259.5 ns    (43.3 %), step = 7.496 ps    (1.25 m%)
\o
\o     pss: time = 260.1 ns    (43.4 %), step = 3.063 ps     (510 u%)
\o
\o     pss: time = 260.7 ns    (43.4 %), step = 3.534 ps     (589 u%)
\o
\o     pss: time = 261.2 ns    (43.5 %), step = 6.519 ps    (1.09 m%)
\o
\o     pss: time = 261.8 ns    (43.6 %), step = 10 ps       (1.67 m%)
\o
\o     pss: time = 262.4 ns    (43.7 %), step = 3.354 ps     (559 u%)
\o
\o     pss: time = 262.9 ns    (43.8 %), step = 1.822 ps     (304 u%)
\o
\o     pss: time = 263.5 ns    (43.9 %), step = 8.76 ps     (1.46 m%)
\o
\o     pss: time = 264 ns        (44 %), step = 10 ps       (1.67 m%)
\o
\o     pss: time = 264.6 ns    (44.1 %), step = 3.139 ps     (523 u%)
\o
\o     pss: time = 265.2 ns    (44.2 %), step = 2.495 ps     (416 u%)
\o
\o     pss: time = 265.7 ns    (44.3 %), step = 8.192 ps    (1.37 m%)
\o
\o     pss: time = 266.2 ns    (44.4 %), step = 10.62 ps    (1.77 m%)
\o
\o     pss: time = 266.9 ns    (44.5 %), step = 3.61 ps      (602 u%)
\o
\o     pss: time = 267.4 ns    (44.6 %), step = 2.858 ps     (476 u%)
\o
\o     pss: time = 267.9 ns    (44.7 %), step = 7.373 ps    (1.23 m%)
\o
\o     pss: time = 268.5 ns    (44.8 %), step = 51.29 fs    (8.55 u%)
\o
\o     pss: time = 269 ns      (44.8 %), step = 10 ps       (1.67 m%)
\o
\o     pss: time = 269.6 ns    (44.9 %), step = 25.67 ps    (4.28 m%)
\o
\o     pss: time = 270.1 ns      (45 %), step = 4.132 ps     (689 u%)
\o
\o     pss: time = 270.7 ns    (45.1 %), step = 5.259 ps     (877 u%)
\o
\o     pss: time = 271.2 ns    (45.2 %), step = 4.988 ps     (831 u%)
\o
\o     pss: time = 271.8 ns    (45.3 %), step = 20 ps       (3.33 m%)
\o
\o     pss: time = 272.4 ns    (45.4 %), step = 3.354 ps     (559 u%)
\o
\o     pss: time = 272.9 ns    (45.5 %), step = 5.962 ps     (994 u%)
\o
\o     pss: time = 273.4 ns    (45.6 %), step = 6.901 ps    (1.15 m%)
\o
\o     pss: time = 274 ns      (45.7 %), step = 1.809 ps     (302 u%)
\o
\o     pss: time = 274.6 ns    (45.8 %), step = 3.62 ps      (603 u%)
\o
\o     pss: time = 275.2 ns    (45.9 %), step = 2.485 ps     (414 u%)
\o
\o     pss: time = 275.7 ns      (46 %), step = 11.19 ps    (1.87 m%)
\o
\o     pss: time = 276.2 ns      (46 %), step = 9.831 ps    (1.64 m%)
\o
\o     pss: time = 276.9 ns    (46.1 %), step = 971.5 fs     (162 u%)
\o
\o     pss: time = 277.4 ns    (46.2 %), step = 3.14 ps      (523 u%)
\o
\o     pss: time = 277.9 ns    (46.3 %), step = 8.457 ps    (1.41 m%)
\o
\o     pss: time = 278.6 ns    (46.4 %), step = 26.77 ps    (4.46 m%)
\o
\o     pss: time = 279.1 ns    (46.5 %), step = 2.465 ps     (411 u%)
\o
\o     pss: time = 279.7 ns    (46.6 %), step = 8.128 ps    (1.35 m%)
\o
\o     pss: time = 280.2 ns    (46.7 %), step = 7.948 ps    (1.32 m%)
\o
\o     pss: time = 280.9 ns    (46.8 %), step = 3.236 ps     (539 u%)
\o
\o     pss: time = 281.4 ns    (46.9 %), step = 3.153 ps     (526 u%)
\o
\o     pss: time = 281.9 ns      (47 %), step = 5.897 ps     (983 u%)
\o
\o     pss: time = 282.5 ns    (47.1 %), step = 11.14 ps    (1.86 m%)
\o
\o     pss: time = 283.1 ns    (47.2 %), step = 23.34 ps    (3.89 m%)
\o
\o     pss: time = 283.7 ns    (47.3 %), step = 3.538 ps     (590 u%)
\o
\o     pss: time = 284.2 ns    (47.4 %), step = 6.821 ps    (1.14 m%)
\o
\o     pss: time = 284.8 ns    (47.5 %), step = 10 ps       (1.67 m%)
\o
\o     pss: time = 285 ns      (47.5 %), step = 3.436 ps     (573 u%)
\o
\o     pss: time = 285.6 ns    (47.6 %), step = 3.016 ps     (503 u%)
\o
\o     pss: time = 286.1 ns    (47.7 %), step = 2.177 ps     (363 u%)
\o
\o     pss: time = 286.7 ns    (47.8 %), step = 5.209 ps     (868 u%)
\o
\o     pss: time = 287.2 ns    (47.9 %), step = 7.812 ps     (1.3 m%)
\o
\o     pss: time = 287.9 ns      (48 %), step = 19.54 ps    (3.26 m%)
\o
\o     pss: time = 288.4 ns    (48.1 %), step = 3.151 ps     (525 u%)
\o
\o     pss: time = 288.9 ns    (48.2 %), step = 5.885 ps     (981 u%)
\o
\o     pss: time = 289.5 ns    (48.2 %), step = 9.554 ps    (1.59 m%)
\o
\o     pss: time = 290.1 ns    (48.3 %), step = 17.39 ps     (2.9 m%)
\o
\o     pss: time = 290.6 ns    (48.4 %), step = 4.428 ps     (738 u%)
\o
\o     pss: time = 291.2 ns    (48.5 %), step = 2.471 ps     (412 u%)
\o
\o     pss: time = 291.7 ns    (48.6 %), step = 11.11 ps    (1.85 m%)
\o
\o     pss: time = 292.3 ns    (48.7 %), step = 5 ps         (833 u%)
\o
\o     pss: time = 292.9 ns    (48.8 %), step = 1.479 ps     (247 u%)
\o
\o     pss: time = 293.4 ns    (48.9 %), step = 3.396 ps     (566 u%)
\o
\o     pss: time = 294 ns        (49 %), step = 9.703 ps    (1.62 m%)
\o
\o     pss: time = 294.5 ns    (49.1 %), step = 10 ps       (1.67 m%)
\o
\o     pss: time = 295.1 ns    (49.2 %), step = 4.262 ps     (710 u%)
\o
\o     pss: time = 295.7 ns    (49.3 %), step = 4.916 ps     (819 u%)
\o
\o     pss: time = 296.2 ns    (49.4 %), step = 8.102 ps    (1.35 m%)
\o
\o     pss: time = 296.9 ns    (49.5 %), step = 4.395 ps     (732 u%)
\o
\o     pss: time = 297.4 ns    (49.6 %), step = 3.15 ps      (525 u%)
\o
\o     pss: time = 297.9 ns    (49.7 %), step = 3.689 ps     (615 u%)
\o
\o     pss: time = 298.5 ns    (49.7 %), step = 11.09 ps    (1.85 m%)
\o
\o     pss: time = 299.1 ns    (49.8 %), step = 17.26 ps    (2.88 m%)
\o
\o     pss: time = 299.6 ns    (49.9 %), step = 3.616 ps     (603 u%)
\o
\o     pss: time = 300.1 ns      (50 %), step = 4.321 ps     (720 u%)
\o
\o     pss: time = 300.7 ns    (50.1 %), step = 5.186 ps     (864 u%)
\o
\o     pss: time = 301.2 ns    (50.2 %), step = 11.32 ps    (1.89 m%)
\o
\o     pss: time = 301.8 ns    (50.3 %), step = 19.71 ps    (3.28 m%)
\o
\o     pss: time = 302.4 ns    (50.4 %), step = 3.363 ps     (561 u%)
\o
\o     pss: time = 302.9 ns    (50.5 %), step = 3.316 ps     (553 u%)
\o
\o     pss: time = 303.4 ns    (50.6 %), step = 6.671 ps    (1.11 m%)
\o
\o     pss: time = 304 ns      (50.7 %), step = 13.81 ps     (2.3 m%)
\o
\o     pss: time = 304.6 ns    (50.8 %), step = 7.215 ps     (1.2 m%)
\o
\o     pss: time = 305.1 ns    (50.9 %), step = 3.496 ps     (583 u%)
\o
\o     pss: time = 305.7 ns    (50.9 %), step = 4.834 ps     (806 u%)
\o
\o     pss: time = 306.2 ns      (51 %), step = 7.912 ps    (1.32 m%)
\o
\o     pss: time = 306.8 ns    (51.1 %), step = 3.086 ps     (514 u%)
\o
\o     pss: time = 307.4 ns    (51.2 %), step = 7.754 ps    (1.29 m%)
\o
\o     pss: time = 307.9 ns    (51.3 %), step = 1.14 ps      (190 u%)
\o
\o     pss: time = 308.4 ns    (51.4 %), step = 5.914 ps     (986 u%)
\o
\o     pss: time = 309 ns      (51.5 %), step = 5 ps         (833 u%)
\o
\o     pss: time = 309.6 ns    (51.6 %), step = 7.311 ps    (1.22 m%)
\o
\o     pss: time = 310.2 ns    (51.7 %), step = 2.676 ps     (446 u%)
\o
\o     pss: time = 310.7 ns    (51.8 %), step = 14.78 ps    (2.46 m%)
\o
\o     pss: time = 311.4 ns    (51.9 %), step = 20 ps       (3.33 m%)
\o
\o     pss: time = 311.9 ns      (52 %), step = 2.643 ps     (441 u%)
\o
\o     pss: time = 312.4 ns    (52.1 %), step = 2.827 ps     (471 u%)
\o
\o     pss: time = 313 ns      (52.2 %), step = 9.645 ps    (1.61 m%)
\o
\o     pss: time = 313.6 ns    (52.3 %), step = 18.16 ps    (3.03 m%)
\o
\o     pss: time = 314.1 ns    (52.4 %), step = 2.478 ps     (413 u%)
\o
\o     pss: time = 314.7 ns    (52.4 %), step = 5.234 ps     (872 u%)
\o
\o     pss: time = 315 ns      (52.5 %), step = 3.719 ps     (620 u%)
\o
\o     pss: time = 315.6 ns    (52.6 %), step = 20 ps       (3.33 m%)
\o
\o     pss: time = 316.1 ns    (52.7 %), step = 2.463 ps     (410 u%)
\o
\o     pss: time = 316.7 ns    (52.8 %), step = 7.363 ps    (1.23 m%)
\o
\o     pss: time = 317.3 ns    (52.9 %), step = 533.6 fs    (88.9 u%)
\o
\o     pss: time = 317.9 ns      (53 %), step = 5.795 ps     (966 u%)
\o
\o     pss: time = 318.4 ns    (53.1 %), step = 3.327 ps     (555 u%)
\o
\o     pss: time = 318.9 ns    (53.2 %), step = 5.535 ps     (922 u%)
\o
\o     pss: time = 319.5 ns    (53.2 %), step = 13.35 ps    (2.22 m%)
\o
\o     pss: time = 320.1 ns    (53.4 %), step = 3.052 ps     (509 u%)
\o
\o     pss: time = 320.6 ns    (53.4 %), step = 4.319 ps     (720 u%)
\o
\o     pss: time = 321.1 ns    (53.5 %), step = 4.253 ps     (709 u%)
\o
\o     pss: time = 321.7 ns    (53.6 %), step = 6.211 ps    (1.04 m%)
\o
\o     pss: time = 322.2 ns    (53.7 %), step = 3.527 ps     (588 u%)
\o
\o     pss: time = 322.7 ns    (53.8 %), step = 13.49 ps    (2.25 m%)
\o
\o     pss: time = 323.3 ns    (53.9 %), step = 6.447 ps    (1.07 m%)
\o
\o     pss: time = 323.9 ns      (54 %), step = 20 ps       (3.33 m%)
\o
\o     pss: time = 324.4 ns    (54.1 %), step = 3.675 ps     (612 u%)
\o
\o     pss: time = 324.9 ns    (54.1 %), step = 706.2 fs     (118 u%)
\o
\o     pss: time = 325.4 ns    (54.2 %), step = 2.678 ps     (446 u%)
\o
\o     pss: time = 325.9 ns    (54.3 %), step = 6.65 ps     (1.11 m%)
\o
\o     pss: time = 326.5 ns    (54.4 %), step = 13.23 ps     (2.2 m%)
\o
\o     pss: time = 327.1 ns    (54.5 %), step = 10 ps       (1.67 m%)
\o
\o     pss: time = 327.6 ns    (54.6 %), step = 3.134 ps     (522 u%)
\o
\o     pss: time = 328.2 ns    (54.7 %), step = 2.368 ps     (395 u%)
\o
\o     pss: time = 328.7 ns    (54.8 %), step = 7.326 ps    (1.22 m%)
\o
\o     pss: time = 329.3 ns    (54.9 %), step = 18.55 ps    (3.09 m%)
\o
\o     pss: time = 329.9 ns      (55 %), step = 4.219 ps     (703 u%)
\o
\o     pss: time = 330.4 ns    (55.1 %), step = 2.424 ps     (404 u%)
\o
\o     pss: time = 330.9 ns    (55.2 %), step = 3.356 ps     (559 u%)
\o
\o     pss: time = 331.4 ns    (55.2 %), step = 7.219 ps     (1.2 m%)
\o
\o     pss: time = 332 ns      (55.3 %), step = 5 ps         (833 u%)
\o
\o     pss: time = 332.6 ns    (55.4 %), step = 10.75 ps    (1.79 m%)
\o
\o     pss: time = 333.1 ns    (55.5 %), step = 1.263 ps     (211 u%)
\o
\o     pss: time = 333.7 ns    (55.6 %), step = 7.988 ps    (1.33 m%)
\o
\o     pss: time = 334.2 ns    (55.7 %), step = 5.869 ps     (978 u%)
\o
\o     pss: time = 334.7 ns    (55.8 %), step = 9.323 ps    (1.55 m%)
\o
\o     pss: time = 335.2 ns    (55.9 %), step = 7.94 ps     (1.32 m%)
\o
\o     pss: time = 335.8 ns      (56 %), step = 19.94 ps    (3.32 m%)
\o
\o     pss: time = 336.3 ns      (56 %), step = 15.83 ps    (2.64 m%)
\o
\o     pss: time = 336.9 ns    (56.1 %), step = 1.854 ps     (309 u%)
\o
\o     pss: time = 337.4 ns    (56.2 %), step = 2.324 ps     (387 u%)
\o
\o     pss: time = 337.9 ns    (56.3 %), step = 5.029 ps     (838 u%)
\o
\o     pss: time = 338.4 ns    (56.4 %), step = 7.538 ps    (1.26 m%)
\o
\o     pss: time = 339 ns      (56.5 %), step = 18.19 ps    (3.03 m%)
\o
\o     pss: time = 339.6 ns    (56.6 %), step = 12.72 ps    (2.12 m%)
\o
\o     pss: time = 340.1 ns    (56.7 %), step = 2.447 ps     (408 u%)
\o
\o     pss: time = 340.7 ns    (56.8 %), step = 5.06 ps      (843 u%)
\o
\o     pss: time = 341.2 ns    (56.9 %), step = 9.553 ps    (1.59 m%)
\o
\o     pss: time = 341.8 ns      (57 %), step = 14.29 ps    (2.38 m%)
\o
\o     pss: time = 342.2 ns      (57 %), step = 9.697 ps    (1.62 m%)
\o
\o     pss: time = 342.8 ns    (57.1 %), step = 30 ps          (5 m%)
\o
\o     pss: time = 343.4 ns    (57.2 %), step = 2.058 ps     (343 u%)
\o
\o     pss: time = 343.9 ns    (57.3 %), step = 3.404 ps     (567 u%)
\o
\o     pss: time = 344.4 ns    (57.4 %), step = 2.966 ps     (494 u%)
\o
\o     pss: time = 345 ns      (57.5 %), step = 9.664 ps    (1.61 m%)
\o
\o     pss: time = 345 ns      (57.5 %), step = 5 ps         (833 u%)
\o
\o     pss: time = 345.5 ns    (57.6 %), step = 18.77 ps    (3.13 m%)
\o
\o     pss: time = 346.1 ns    (57.7 %), step = 2.475 ps     (413 u%)
\o
\o     pss: time = 346.6 ns    (57.8 %), step = 4.243 ps     (707 u%)
\o
\o     pss: time = 347.2 ns    (57.9 %), step = 3.139 ps     (523 u%)
\o
\o     pss: time = 347.7 ns      (58 %), step = 7.974 ps    (1.33 m%)
\o
\o     pss: time = 348.3 ns      (58 %), step = 6.333 ps    (1.06 m%)
\o
\o     pss: time = 348.9 ns    (58.1 %), step = 7.367 ps    (1.23 m%)
\o
\o     pss: time = 349.3 ns    (58.2 %), step = 3.281 ps     (547 u%)
\o
\o     pss: time = 349.9 ns    (58.3 %), step = 3.176 ps     (529 u%)
\o
\o     pss: time = 350.4 ns    (58.4 %), step = 10.25 ps    (1.71 m%)
\o
\o     pss: time = 350.9 ns    (58.5 %), step = 2.608 ps     (435 u%)
\o
\o     pss: time = 351.4 ns    (58.6 %), step = 5.798 ps     (966 u%)
\o
\o     pss: time = 352 ns      (58.7 %), step = 10 ps       (1.67 m%)
\o
\o     pss: time = 352.6 ns    (58.8 %), step = 26.79 ps    (4.47 m%)
\o
\o     pss: time = 353.1 ns    (58.9 %), step = 2.46 ps      (410 u%)
\o
\o     pss: time = 353.7 ns    (58.9 %), step = 6.298 ps    (1.05 m%)
\o
\o     pss: time = 354.2 ns      (59 %), step = 3.55 ps      (592 u%)
\o
\o     pss: time = 354.7 ns    (59.1 %), step = 13.38 ps    (2.23 m%)
\o
\o     pss: time = 355.3 ns    (59.2 %), step = 982.7 fs     (164 u%)
\o
\o     pss: time = 355.9 ns    (59.3 %), step = 5.026 ps     (838 u%)
\o
\o     pss: time = 356.3 ns    (59.4 %), step = 20 ps       (3.33 m%)
\o
\o     pss: time = 356.9 ns    (59.5 %), step = 1.548 ps     (258 u%)
\o
\o     pss: time = 357.4 ns    (59.6 %), step = 4.05 ps      (675 u%)
\o
\o     pss: time = 358 ns      (59.7 %), step = 11.88 ps    (1.98 m%)
\o
\o     pss: time = 358.6 ns    (59.8 %), step = 7.187 ps     (1.2 m%)
\o
\o     pss: time = 359.2 ns    (59.9 %), step = 2.36 ps      (393 u%)
\o
\o     pss: time = 359.7 ns    (59.9 %), step = 5.907 ps     (985 u%)
\o
\o     pss: time = 360.2 ns      (60 %), step = 4.41 ps      (735 u%)
\o
\o     pss: time = 360.7 ns    (60.1 %), step = 7.997 ps    (1.33 m%)
\o
\o     pss: time = 361.2 ns    (60.2 %), step = 11.19 ps    (1.87 m%)
\o
\o     pss: time = 361.9 ns    (60.3 %), step = 6.103 ps    (1.02 m%)
\o
\o     pss: time = 362.4 ns    (60.4 %), step = 3.355 ps     (559 u%)
\o
\o     pss: time = 362.9 ns    (60.5 %), step = 3.314 ps     (552 u%)
\o
\o     pss: time = 363.4 ns    (60.6 %), step = 4.026 ps     (671 u%)
\o
\o     pss: time = 364 ns      (60.7 %), step = 8.618 ps    (1.44 m%)
\o
\o     pss: time = 364.5 ns    (60.7 %), step = 12.94 ps    (2.16 m%)
\o
\o     pss: time = 365.1 ns    (60.9 %), step = 3.057 ps     (509 u%)
\o
\o     pss: time = 365.7 ns    (60.9 %), step = 3.633 ps     (605 u%)
\o
\o     pss: time = 366.2 ns      (61 %), step = 3.537 ps     (590 u%)
\o
\o     pss: time = 366.7 ns    (61.1 %), step = 4.729 ps     (788 u%)
\o
\o     pss: time = 367.2 ns    (61.2 %), step = 7.973 ps    (1.33 m%)
\o
\o     pss: time = 367.7 ns    (61.3 %), step = 5 ps         (833 u%)
\o
\o     pss: time = 368.3 ns    (61.4 %), step = 2.336 ps     (389 u%)
\o
\o     pss: time = 368.8 ns    (61.5 %), step = 34.01 ps    (5.67 m%)
\o
\o     pss: time = 369.3 ns    (61.5 %), step = 5 ps         (833 u%)
\o
\o     pss: time = 369.9 ns    (61.6 %), step = 1.853 ps     (309 u%)
\o
\o     pss: time = 370.4 ns    (61.7 %), step = 4.325 ps     (721 u%)
\o
\o     pss: time = 370.9 ns    (61.8 %), step = 1.771 ps     (295 u%)
\o
\o     pss: time = 371.4 ns    (61.9 %), step = 1.014 ps     (169 u%)
\o
\o     pss: time = 371.9 ns      (62 %), step = 5.804 ps     (967 u%)
\o
\o     pss: time = 372.4 ns    (62.1 %), step = 5.588 ps     (931 u%)
\o
\o     pss: time = 373 ns      (62.2 %), step = 9.01 ps      (1.5 m%)
\o
\o     pss: time = 373.5 ns    (62.2 %), step = 12.83 ps    (2.14 m%)
\o
\o     pss: time = 374.1 ns    (62.3 %), step = 20 ps       (3.33 m%)
\o
\o     pss: time = 374.6 ns    (62.4 %), step = 3.619 ps     (603 u%)
\o
\o     pss: time = 375 ns      (62.5 %), step = 12.43 ps    (2.07 m%)
\o
\o     pss: time = 375.5 ns    (62.6 %), step = 5 ps         (833 u%)
\o
\o     pss: time = 376.1 ns    (62.7 %), step = 3.03 ps      (505 u%)
\o
\o     pss: time = 376.6 ns    (62.8 %), step = 4.227 ps     (704 u%)
\o
\o     pss: time = 377.2 ns    (62.9 %), step = 3.953 ps     (659 u%)
\o
\o     pss: time = 377.7 ns      (63 %), step = 8.29 ps     (1.38 m%)
\o
\o     pss: time = 378.2 ns      (63 %), step = 11.13 ps    (1.86 m%)
\o
\o     pss: time = 378.9 ns    (63.1 %), step = 7.289 ps    (1.21 m%)
\o
\o     pss: time = 379.4 ns    (63.2 %), step = 20 ps       (3.33 m%)
\o
\o     pss: time = 379.9 ns    (63.3 %), step = 634.5 fs     (106 u%)
\o
\o     pss: time = 380.4 ns    (63.4 %), step = 2.801 ps     (467 u%)
\o
\o     pss: time = 380.9 ns    (63.5 %), step = 4.911 ps     (818 u%)
\o
\o     pss: time = 381.5 ns    (63.6 %), step = 10.56 ps    (1.76 m%)
\o
\o     pss: time = 382.1 ns    (63.7 %), step = 20 ps       (3.33 m%)
\o
\o     pss: time = 382.6 ns    (63.8 %), step = 3.01 ps      (502 u%)
\o
\o     pss: time = 383.1 ns    (63.9 %), step = 2.524 ps     (421 u%)
\o
\o     pss: time = 383.7 ns    (63.9 %), step = 5.067 ps     (844 u%)
\o
\o     pss: time = 384.2 ns      (64 %), step = 8.046 ps    (1.34 m%)
\o
\o     pss: time = 384.7 ns    (64.1 %), step = 7.941 ps    (1.32 m%)
\o
\o     pss: time = 385.2 ns    (64.2 %), step = 9.001 ps     (1.5 m%)
\o
\o     pss: time = 385.8 ns    (64.3 %), step = 8.213 ps    (1.37 m%)
\o
\o     pss: time = 386.3 ns    (64.4 %), step = 5.51 ps      (918 u%)
\o
\o     pss: time = 386.9 ns    (64.5 %), step = 1.852 ps     (309 u%)
\o
\o     pss: time = 387.4 ns    (64.6 %), step = 2.667 ps     (444 u%)
\o
\o     pss: time = 388 ns      (64.7 %), step = 8.536 ps    (1.42 m%)
\o
\o     pss: time = 388.5 ns    (64.7 %), step = 11.28 ps    (1.88 m%)
\o
\o     pss: time = 389.1 ns    (64.8 %), step = 8.815 ps    (1.47 m%)
\o
\o     pss: time = 389.6 ns    (64.9 %), step = 3.64 ps      (607 u%)
\o
\o     pss: time = 390.2 ns      (65 %), step = 2.449 ps     (408 u%)
\o
\o     pss: time = 390.7 ns    (65.1 %), step = 4.745 ps     (791 u%)
\o
\o     pss: time = 391.2 ns    (65.2 %), step = 6.009 ps       (1 m%)
\o
\o     pss: time = 391.7 ns    (65.3 %), step = 7.909 ps    (1.32 m%)
\o
\o     pss: time = 392.3 ns    (65.4 %), step = 10.03 ps    (1.67 m%)
\o
\o     pss: time = 392.9 ns    (65.5 %), step = 3.493 ps     (582 u%)
\o
\o     pss: time = 393.4 ns    (65.6 %), step = 2.997 ps     (499 u%)
\o
\o     pss: time = 393.9 ns    (65.6 %), step = 774.7 fs     (129 u%)
\o
\o     pss: time = 394.4 ns    (65.7 %), step = 3.32 ps      (553 u%)
\o
\o     pss: time = 394.9 ns    (65.8 %), step = 8.628 ps    (1.44 m%)
\o
\o     pss: time = 395.5 ns    (65.9 %), step = 10 ps       (1.67 m%)
\o
\o     pss: time = 396.1 ns      (66 %), step = 5.545 ps     (924 u%)
\o
\o     pss: time = 396.7 ns    (66.1 %), step = 3.636 ps     (606 u%)
\o
\o     pss: time = 397.2 ns    (66.2 %), step = 8.001 ps    (1.33 m%)
\o
\o     pss: time = 397.7 ns    (66.3 %), step = 12.55 ps    (2.09 m%)
\o
\o     pss: time = 398.4 ns    (66.4 %), step = 20 ps       (3.33 m%)
\o
\o     pss: time = 398.9 ns    (66.5 %), step = 547.4 fs    (91.2 u%)
\o
\o     pss: time = 399.4 ns    (66.6 %), step = 4.174 ps     (696 u%)
\o
\o     pss: time = 400 ns      (66.7 %), step = 10 ps       (1.67 m%)
\o
\o     pss: time = 400.5 ns    (66.8 %), step = 7.836 ps    (1.31 m%)
\o
\o     pss: time = 401.1 ns    (66.9 %), step = 6.248 ps    (1.04 m%)
\o
\o     pss: time = 401.7 ns    (66.9 %), step = 3.675 ps     (612 u%)
\o
\o     pss: time = 402.2 ns      (67 %), step = 4.708 ps     (785 u%)
\o
\o     pss: time = 402.7 ns    (67.1 %), step = 13.33 ps    (2.22 m%)
\o
\o     pss: time = 403.3 ns    (67.2 %), step = 11.27 ps    (1.88 m%)
\o
\o     pss: time = 403.9 ns    (67.3 %), step = 2.435 ps     (406 u%)
\o
\o     pss: time = 404.4 ns    (67.4 %), step = 2.077 ps     (346 u%)
\o
\o     pss: time = 404.9 ns    (67.5 %), step = 6.943 ps    (1.16 m%)
\o
\o     pss: time = 405 ns      (67.5 %), step = 1.261 ps     (210 u%)
\o
\o     pss: time = 405.6 ns    (67.6 %), step = 12.26 ps    (2.04 m%)
\o
\o     pss: time = 406.1 ns    (67.7 %), step = 4.046 ps     (674 u%)
\o
\o     pss: time = 406.7 ns    (67.8 %), step = 3.587 ps     (598 u%)
\o
\o     pss: time = 407.2 ns    (67.9 %), step = 4.729 ps     (788 u%)
\o
\o     pss: time = 407.8 ns      (68 %), step = 10 ps       (1.67 m%)
\o
\o     pss: time = 408.3 ns    (68.1 %), step = 25.96 ps    (4.33 m%)
\o
\o     pss: time = 408.9 ns    (68.1 %), step = 2.436 ps     (406 u%)
\o
\o     pss: time = 409.4 ns    (68.2 %), step = 3.707 ps     (618 u%)
\o
\o     pss: time = 410 ns      (68.3 %), step = 3.779 ps     (630 u%)
\o
\o     pss: time = 410.5 ns    (68.4 %), step = 14.75 ps    (2.46 m%)
\o
\o     pss: time = 411.1 ns    (68.5 %), step = 6.985 ps    (1.16 m%)
\o
\o     pss: time = 411.7 ns    (68.6 %), step = 3.641 ps     (607 u%)
\o
\o     pss: time = 412.2 ns    (68.7 %), step = 6.909 ps    (1.15 m%)
\o
\o     pss: time = 412.7 ns    (68.8 %), step = 10.7 ps     (1.78 m%)
\o
\o     pss: time = 413.3 ns    (68.9 %), step = 10 ps       (1.67 m%)
\o
\o     pss: time = 413.9 ns      (69 %), step = 1.622 ps     (270 u%)
\o
\o     pss: time = 414.4 ns    (69.1 %), step = 3.532 ps     (589 u%)
\o
\o     pss: time = 415 ns      (69.2 %), step = 10.63 ps    (1.77 m%)
\o
\o     pss: time = 415.6 ns    (69.3 %), step = 13.79 ps     (2.3 m%)
\o
\o     pss: time = 416.1 ns    (69.4 %), step = 2.849 ps     (475 u%)
\o
\o     pss: time = 416.7 ns    (69.4 %), step = 5.064 ps     (844 u%)
\o
\o     pss: time = 417.2 ns    (69.5 %), step = 8.399 ps     (1.4 m%)
\o
\o     pss: time = 417.8 ns    (69.6 %), step = 4.063 ps     (677 u%)
\o
\o     pss: time = 418.3 ns    (69.7 %), step = 8.887 ps    (1.48 m%)
\o
\o     pss: time = 418.9 ns    (69.8 %), step = 1.483 ps     (247 u%)
\o
\o     pss: time = 419.4 ns    (69.9 %), step = 2.473 ps     (412 u%)
\o
\o     pss: time = 419.9 ns      (70 %), step = 208.7 fs    (34.8 u%)
\o
\o     pss: time = 420.4 ns    (70.1 %), step = 1.721 ps     (287 u%)
\o
\o     pss: time = 420.9 ns    (70.1 %), step = 573.8 fs    (95.6 u%)
\o
\o     pss: time = 421.4 ns    (70.2 %), step = 3.368 ps     (561 u%)
\o
\o     pss: time = 421.9 ns    (70.3 %), step = 6.357 ps    (1.06 m%)
\o
\o     pss: time = 422.4 ns    (70.4 %), step = 5.52 ps      (920 u%)
\o
\o     pss: time = 423 ns      (70.5 %), step = 9.781 ps    (1.63 m%)
\o
\o     pss: time = 423.5 ns    (70.6 %), step = 10 ps       (1.67 m%)
\o
\o     pss: time = 424.1 ns    (70.7 %), step = 7.316 ps    (1.22 m%)
\o
\o     pss: time = 424.7 ns    (70.8 %), step = 3.593 ps     (599 u%)
\o
\o     pss: time = 425.2 ns    (70.9 %), step = 3.639 ps     (607 u%)
\o
\o     pss: time = 425.7 ns    (70.9 %), step = 7.932 ps    (1.32 m%)
\o
\o     pss: time = 426.2 ns      (71 %), step = 6.816 ps    (1.14 m%)
\o
\o     pss: time = 426.8 ns    (71.1 %), step = 10 ps       (1.67 m%)
\o
\o     pss: time = 427.4 ns    (71.2 %), step = 9.652 ps    (1.61 m%)
\o
\o     pss: time = 427.9 ns    (71.3 %), step = 1.113 ps     (185 u%)
\o
\o     pss: time = 428.4 ns    (71.4 %), step = 3.491 ps     (582 u%)
\o
\o     pss: time = 428.9 ns    (71.5 %), step = 2.537 ps     (423 u%)
\o
\o     pss: time = 429.4 ns    (71.6 %), step = 3.828 ps     (638 u%)
\o
\o     pss: time = 430 ns      (71.7 %), step = 9.741 ps    (1.62 m%)
\o
\o     pss: time = 430.5 ns    (71.8 %), step = 593.4 fs    (98.9 u%)
\o
\o     pss: time = 431 ns      (71.8 %), step = 3.987 ps     (665 u%)
\o
\o     pss: time = 431.5 ns    (71.9 %), step = 10 ps       (1.67 m%)
\o
\o     pss: time = 432.1 ns      (72 %), step = 3.049 ps     (508 u%)
\o
\o     pss: time = 432.6 ns    (72.1 %), step = 3.029 ps     (505 u%)
\o
\o     pss: time = 433.1 ns    (72.2 %), step = 2.422 ps     (404 u%)
\o
\o     pss: time = 433.7 ns    (72.3 %), step = 6.127 ps    (1.02 m%)
\o
\o     pss: time = 434.2 ns    (72.4 %), step = 7.94
IT HANGS AT THIS POINT........................
