  2. RF Design
  3. Reading parmetric sweep data through ocean
  • Replies 12
  • Subscribers 63
  • Views 25358
lahsivece
lahsivece over 13 years ago
Hi All,
I have a set of parmetric sweep results generated through spectre simulation . These file names are of the format
"sweep_variablename_-<iteration numbers>_sweep_another_variable_name-<iteration_number>_....tran.tran"
I am trying to read the file through Ocean and perform some analysis on data generated. My ocean script looks like following:
sprintf(rdir "<path_to_spectre_simulation_directory>/spectre/schematic")
openResults(strcat(rdir,"/psf"))
; The above sets the results directory to the psf folder. All parametric sweep results are dumped there.
selectResult('tran)
clip_v1p=clip(v("/V1P" ?result "sweepb2_1-000_sweepb1_1-000_sweepb0_1-001_tran-tran") 010e-09 28e-09)
On executing the script  i get following error message
The output '/V1P' you selected does not exist.  Type
          outputs() to see the list of available outputs or type
          help('v) for more information on the 'v' command.
However when I execute outputs() I get the netname in the list.
What am I doing wrong ?
I can read single spectre simulation data through ocean but Can I read parametric sweep spectre simulation data through ocean ?
Please advise.
Thanks & regards
Vishal
    Vishal,
    If your sweep is like you described earlier, with nested sweeps for b0, b1 and b2, your calculations are not doing a value() on 'b2 - so you will get the frequency versus b2  in the output above. Try plotting the result and see what you get - it's quite handy to see what the waveform looks like when you're trying to understand such issues.
  • lahsivece
    Yes, it was the case. On plottting , the plot was of frequency() with respect to b2.
    After adding value() on b2 , I do get desired output.
    Thanks for your help
    Regards
    Vishal
