  2. RF Design
  3. Reading parmetric sweep data through ocean
  • Replies 12
  • Subscribers 63
  • Views 25347
lahsivece
lahsivece over 13 years ago
Hi All,
I have a set of parmetric sweep results generated through spectre simulation . These file names are of the format
"sweep_variablename_-<iteration numbers>_sweep_another_variable_name-<iteration_number>_....tran.tran"
I am trying to read the file through Ocean and perform some analysis on data generated. My ocean script looks like following:
sprintf(rdir "<path_to_spectre_simulation_directory>/spectre/schematic")
openResults(strcat(rdir,"/psf"))
; The above sets the results directory to the psf folder. All parametric sweep results are dumped there.
selectResult('tran)
clip_v1p=clip(v("/V1P" ?result "sweepb2_1-000_sweepb1_1-000_sweepb0_1-001_tran-tran") 010e-09 28e-09)
On executing the script  i get following error message
The output '/V1P' you selected does not exist.  Type
          outputs() to see the list of available outputs or type
          help('v) for more information on the 'v' command.
However when I execute outputs() I get the netname in the list.
What am I doing wrong ?
I can read single spectre simulation data through ocean but Can I read parametric sweep spectre simulation data through ocean ?
Please advise.
Thanks & regards
Vishal
    ShawnLogan over 13 years ago
     Hi Vishal,
    I am not an expert, but my experience with accessing parametric results suggest that you need to use the value attribute to access the results for a specific sweep. I am not aware that you can change the name of the transient results to correspond to a specific analysis.
    In other words, in my experience, the output file containing the analysis is still called tran.trn, (i.e., ?results "tran-tran"), but the family of waveforms is accessed and the value function is used to select the specific analysis within the family of waveforms.
     Perhaps this example will help...
    If my parametric wave is
    VLOAD  waveformobject
    0                  w1
    0.1               w2
    0.5               w3
    Here are 2 potential expressions :
    val1 = value(i("/IB25_0/PLUS" ?resultsDir "./spectre/101508_css_ss_bc" ?result "ac-ac") "VLOAD" 0.5)
    val2  = value(i("/IB25_0/PLUS" ?resultsDir "./spectre/101508_css_ss_bc" ?result "ac-ac")  0.5)
    val1 will return the waveform object corresponding to VLOAD=0.5 ie w3.
    val2 will return a new waveform as given below :
    0                  value( w1  0.5 )
    0.1               value( w2  0.5 )
    0.5               value( w3  0.5 )
    The famValue function can also be used in this case ie :
    ib25_0 = famValue( ib25_0f VLOAD)
     Does this help?
    Shawn
  • lahsivece
    Hi Shawn ,
    Thanks for the reply.
    I tried your method I am still getting errors.
     ocean>clip_v1p=value(clip(v("/V2P" ?result "tran-tran") 010e-09 28e-09) "b0")
              Results "tran-tran" are not available for
              "/home/vishal/simulation/TB_RING_DIFF_INVERTER_4500MHz/spectre/schematic/psf". Use results() for a list of available
               results.
              The output '/V2P' you selected does not exist.  Type
    *Error* clip: can't handle clip(nil 1e-08 2.8e-08)
    There is no tran.tran file present in the psf directory.
    Also the output exists. The reason I know this is because when I exceute outputs() , I get the net name /V2P in the list of outputs.
    I am using spectre to do a set of nested parametric sweeps. All the output files are dumped in one location. In my case I have following section added in my input.scs file
    sweepb2_1 sweep param=b2 values=[0.0] {
      sweepb1_1 sweep param=b1 values=[0.0 ] {
        sweepb0_1 sweep param=b0 values=[0.0 1.2] {
    tran tran stop=50n write="spectre.ic" writefinal="spectre.fc" \
        annotate=status maxiters=5
    The above generates tran.tran files in the same psf folder with following names.
    sweepb2_1-000_sweepb1_1-000_sweepb0_1-000_tran.tran
    sweepb2_1-000_sweepb1_1-000_sweepb0_1-001_tran.tran
    I then intend to use some user defined function to run some anaylsis on these files using OCEAN script. However I am not able to read these files.
    Can I create multiple results directory using spectre simulation ?
    Please advise
    Vishal
     Hi Vishal,
    I noticed a couple of things...
    1. The syntax for your getData() command appears to be missing the results directory. This is why you received the error message "Use results() for a list of available results." I think you are missing the ?resultsDir attribute. The command syntax, as I recall is:
    getData( <output_name> ?results <anaysis_type> ?resultsDir <path_to_results_directory>)
    If you already opened the results with openResults( <path_to_results_directory>) and used selecResult(<analysis_type>), then you do not need these attributes.
     Since you received the error message about the "results()", my thought is you may have overlooked the  openResults() command.
    2. When I perform a sweep analysis in IC 6.1.5, as in all prior versions, the result is a set of discrete directories whose names reflect the value of the sweep varaible(s). Within each subdirectory, there is a psf folder with the analysis results (i..e, tran.tran file for example). Are you using the paramRun() command in your script?
    For example, on a two variable sweep I recently performed the directory structure is:
    IBIAS=1.5e-05,NF_nmos=20  IBIAS=2e-05,NF_nmos=60    IBIAS=4.5e-05,NF_nmos=50
    IBIAS=1.5e-05,NF_nmos=30  IBIAS=3.5e-05,NF_nmos=20  IBIAS=4.5e-05,NF_nmos=60
    IBIAS=1.5e-05,NF_nmos=40  IBIAS=3.5e-05,NF_nmos=30  IBIAS=4e-05,NF_nmos=20
    IBIAS=1.5e-05,NF_nmos=50  IBIAS=3.5e-05,NF_nmos=40  IBIAS=4e-05,NF_nmos=30
    IBIAS=1.5e-05,NF_nmos=60  IBIAS=3.5e-05,NF_nmos=50  IBIAS=4e-05,NF_nmos=40
    IBIAS=2.5e-05,NF_nmos=20  IBIAS=3.5e-05,NF_nmos=60  IBIAS=4e-05,NF_nmos=50
    IBIAS=2.5e-05,NF_nmos=30  IBIAS=3e-05,NF_nmos=20    IBIAS=4e-05,NF_nmos=60
    IBIAS=2.5e-05,NF_nmos=40  IBIAS=3e-05,NF_nmos=30    IBIAS=5e-05,NF_nmos=20
    IBIAS=2.5e-05,NF_nmos=50  IBIAS=3e-05,NF_nmos=40    IBIAS=5e-05,NF_nmos=30
    IBIAS=2.5e-05,NF_nmos=60  IBIAS=3e-05,NF_nmos=50    IBIAS=5e-05,NF_nmos=40
    IBIAS=2e-05,NF_nmos=20      IBIAS=3e-05,NF_nmos=60    IBIAS=5e-05,NF_nmos=50
    IBIAS=2e-05,NF_nmos=30      IBIAS=4.5e-05,NF_nmos=20  IBIAS=5e-05,NF_nmos=60
    IBIAS=2e-05,NF_nmos=40      IBIAS=4.5e-05,NF_nmos=30  psf
    IBIAS=2e-05,NF_nmos=50      IBIAS=4.5e-05,NF_nmos=40
    Each sub-directory has a psf folder with the results. The top level psf folder only has the runObjFile. The containing diectory is the  name of the resuls directory I specify in the resultsDir() command.
    Shawn
  • lahsivece
    Hi Shawn,
     1) I have already opened the results directory using openResults command .
    2) I am not using paramRun command in my .scs file. Do I need to use it ? To do nested armetric analysis , I have modified my input .scs as  following
    This geneartes data at a single location when I execute netlist from command line. I would like to have seperate location for each sweep variable ouput run. (in ocean this is easy)
    Thanks & Regards
    Vishal
     Hi Vishal,
     I run the analysis using ocean. This is an example of the syntax:
    paramAnalysis("FREQ_ADJ" ?values '(0 1 2 3 )
      paramAnalysis("VLF_VAL" ?values '(0.15 0.2 0.25 0.3 0.35 0.4 0.45 0.5 0.55 0.6 0.65 0.7 )
    paramRun()
    This generates a set of directories - one for each of the simulations as I showed in prior example. I think this is what you want to do if you want to generate a separate set of directories and access the data as I showed in the initial example I provided.
    The input.scs file is not impacted by the use of the paramRun() command. I believe the parameter sweep information is contained in the runObjFile contained in the psf directory. My interpretation of this file is that it is a script that controls the simulations requested. For a parametric analysis it contains lines such as:
    "FREQ_ADJ=0,VLF_VAL=0.2/psf" "runObject" (
    "../FREQ_ADJ=0,VLF_VAL=0.2/psf/logFile"
    "../FREQ_ADJ=0,VLF_VAL=0.2/psf/artistLogFile"
    "FREQ_ADJ=0"
    ) PROP(
    "netlistDir" "../netlist"
    "dataDir" "../FREQ_ADJ=0,VLF_VAL=0.2"
     "VLF_VAL" 2.000000e-01
    Shawn
    OK, I have a very simple example with a similar sweep to you:
    include "models.scs" section=nn
    parameters b2=0.0 b1=0.0 b0=0.0
    // silly circuit just to do something
    M1 (d g 0 0) nch w=1u l=0.5u
    vd (d 0) vsource type=dc dc=b1
    vg (g 0) vsource type=sine freq=1M ampl=b2
    sweepb2_1 sweep param=b2 values=[0.0 1.2] {
      sweepb1_1 sweep param=b1 values=[0.0 1.2] {
        tran_1 tran stop=1u
    When I run spectre, and then look in the resulting raw directory, I have:
     > ls testsweep.raw
    logFile
    sweepb2_1-000_sweepb1_1-000_sweepb0_1-000_tran_1.tran
    sweepb2_1-000_sweepb1_1-000_sweepb0_1-001_tran_1.tran
    sweepb2_1-000_sweepb1_1-000_sweepb0_1_tran_1.sweep
    sweepb2_1-000_sweepb1_1-001_sweepb0_1-000_tran_1.tran
    sweepb2_1-000_sweepb1_1-001_sweepb0_1-001_tran_1.tran
    sweepb2_1-000_sweepb1_1-001_sweepb0_1_tran_1.sweep
    sweepb2_1-000_sweepb1_1_tran_1.sweep
    sweepb2_1-001_sweepb1_1-000_sweepb0_1-000_tran_1.tran
    sweepb2_1-001_sweepb1_1-000_sweepb0_1-001_tran_1.tran
    sweepb2_1-001_sweepb1_1-000_sweepb0_1_tran_1.sweep
    sweepb2_1-001_sweepb1_1-001_sweepb0_1-000_tran_1.tran
    sweepb2_1-001_sweepb1_1-001_sweepb0_1-001_tran_1.tran
    sweepb2_1-001_sweepb1_1-001_sweepb0_1_tran_1.sweep
    sweepb2_1-001_sweepb1_1_tran_1.sweep
    sweepb2_1_tran_1.sweep
    Now, you shouldn't worry too much about the file names, because these get organized in the logFile to  provide the structure of the family data because of the nested sweeps.
    In OCEAN, if I do:
    openResults("testsweep.raw")
    results()
    Then results will return that there is a result called tran - this is the "aliased" name for the result because you have a single transient analysis - it makes it easier because you don't have to worry about the particulars of the result naming. Alternatively, if I do:
    results(?noAlias t)
    you see it returns  ("sweepb2_1_tran_1-sweep") - which is the name of the outer sweep. It's the same thing, and either name will do.
    So if I then call:
        selectResult('tran)
    or selectResult("tran")
    or selectResult("sweepb2_1_tran_1-sweep")
    then I'll access the results, and can type outputs() to see what is there.
    ocean> outputs()
    ("d" "g" "vd:p" "vg:p")
    Then if I do: plot(v("d")) I willl plot the drain voltage over all the sweeps.
    I can also do:
    ocean> sweepNames()
    ("b2" "b1" "b0" "time")
    ocean> sweepValues()
    (0.0 1.2)
    The sweepNames tells me all the sweep names, and sweepValues tells me the values of the outer sweeps. If I then do:
      d=v("d")
      plot(value(d 0.2u))
    it would plot the values across the sweep at the value of the inner sweep (0.2u on the time axis). Or I can do:
      value(value(value(value(d 0.2u) 1.2) 0.0) 1.2)
    which will successively remove an inner sweep and give me a particular combination. Or I can do:
      plot(value(d 'b1 1.2))
    which will give me the family curves (i.e. still time on x-axis, and with b2 and b0 around them, but for a specific value of b1).
    Note that rather than using selectResult(), I could have just done:
      v("d" ?result 'tran)
    or
      v("d" ?result  "sweepb2_1_tran_1-sweep")
    All the selectResult does is give me a convenient default.
  • lahsivece
    Hi Shawn ,
    Thanks for the information
    Vishal
  • lahsivece
    Hi Andrew ,
    Thanks for exlanation.
    This works.
    However , I get following message after I execute openResults("psf").
    Could not find psf/runObjFile under
              /home/vishal/sweep_test. Calculator data access functions
              will not work
    Since spectre simulation was done from command line this file was not generated.
    Is it needed for using some functions such as clip , frequency etc in ocean? Is there a way to generate it ?
    Thanks & Regards
    Vishal
    Vishal,
    This is just saying that the data access functions from the calculator (e.g. VT, VF, IT, etc) won't work because some of the mapping information is not there. However, providing you can access the data with v(), i(), getData() etc, you can use any of the calculator processing funcitons such as clip etc.
  • lahsivece
    Here's what I am doing
     d1=getData("V1P") ==> drwave:206614616
    in_b0=value(d1 'b0 1.2) ==> drwave:206614552
    in_b1=value(in_b0 'b1 1.2) ==>  drwave:206614952
    v1p_clip=clip(in_b1 10n 20n) ==> drwave:206615048
    frequency(v1p_clip) ==>  drwave:206614664 . I was expecting a number here but got a waveform. frequency is a waveform calculator function.
    Please tell me what I am doing wrong.
    With Regards,
    Vishal
