  2. RF Design
  3. PSS analysis not converging for VCDL
  • Subscribers 63
  • Views 20356
Amessi
Amessi over 13 years ago
I am designing a VCDL for DLL. But the PSS analysis is not converging. I am trying to change "reltol" value but @ very begining of simulation it is showing a warning
'reltol' is not a valid parameter for an instance of `pss' . Ignored
Can anyone tell me if I can change reltol value at all in PSS analysis?
    reltol is an options parameter ("spectre -h options") not an analysis specific parameter. You can use errpreset to affect the reltol, but if you want to set reltol you'd do:
    myOpts options reltol=1e-5
    or similar.
  • Amessi
    Ya, its working. But I am not able to increase it from 1e-03(default value) though am able to decrease it....
    Setting errpreset=liberal on the PSS is as loose as we allow. It really doesn't make sense to loosen the tolerances too much with PSS as typically you want a reasonable dynamic range in whatever you're simulating with PSS.
    Did you try that?
  • Amessi
    I am using
    method=gear2only
    lteratio=6(default=3.5)
    errprest=moderate
    PSS is converging for 500MHz but fails in 800MHz
  • HamidKhatibi
    HamidKhatibi over 13 years ago
     Hi Amessi
    May I ask you were do you set the above parameters, if you are using Cadence Virtuoso?
     Best
  • Amessi
    It can be added in test bench manually
