  2. RF Design
  3. PSS analysis
  • Subscribers 63
  • Views 18015
PSS analysis
ErwinSuijker
ErwinSuijker over 13 years ago
Can anybody tell me how to increase the PSS maximum iteration limit to above the standard limit of 20?   thanks.
    Set the maxperiods parameter (on the PSS Options form if using ADE, or if using spectre command line add maxperiods=40 on the pss line).
    spectre -h pss
    will tell you more about this.
  • ErwinSuijker
    Thank you for your help.
     Best regards,
    Erwin
