  2. RF Design
  3. Issue with ideal multiplier in ahdlLib library in Caden...
  • Subscribers 63
  • Views 18757
Issue with ideal multiplier in ahdlLib library in Cadence
lahsivece
lahsivece over 13 years ago
Dear All,
I am using multiplier (provided in ahdlLib library)  to simulate the behaviour of mixer. One of the inputs (RF input to the mixer) is a sinusoid withh 100mV amplitude and frequency f_rf. The other input (LO input to the mixer ) is a square pulse with V_High =1  and V_low = 0 wityh frequency f_LO.
Multiplier gain is set to 1.
I am using PSS analysis (shooting method , errpreset set to moderate) to analyze frequency tones at the multiplier output.
Ideally I expect that multiplier will generate a  frequency tone at IF frequency , f_IF= f_RF - f_LO with the peak amplitude given by
(2/pi)*  (V_RF =100mV) .
Since I am using an ideal multiplier , I expect RF signal to be present at IF output of multiplier with exactly same ampliude (multiplier gain is set to 1 ).
But , I am observing loss through multiplier . Observed RF amplitude at the RF frequency was supposed to be 100mV but is 60.6mV and I am observing same loss for IF frequency.
To summarize : I am observing loss through ideal multiplier (gain is set to 1 ) when I try to use multiplier as a mixer . I am using PSS analysis shooting method to simulate the multiplier.
Please advise .
With Best Regards,
Vishal
    Vishal,
    Are you using vsource (or vsin) as inputs, or port? It behaves perfectly (with vsource) in my case - I actually get half the peak amplitude at each tone (I'm not sure why it it whould be 2/pi). It's a voltage-based system.
    Here's my netlist (easier than showing all the properties on the sources):
    // Generated for: spectre
    // Generated on: May 29 18:42:13 2013
    // Design library name: RFworkshop
    // Design cell name: checkmult
    simulator lang=spectre
    global 0
    include "model/rfModels.scs"
    include "gpdk446.v10/models/nmos1.scs" section=nom
    include "gpdk446.v10/models/pmos1.scs" section=nom
    include "models/npnStd.scs"
    include "SpectreModels/RFmodels.scs"
    // Library name: RFworkshop
    // Cell name: checkmult
    // View name: schematic
    I0 (lo rf _net0) multiplier gain=1
    V0 (lo 0) vsource type=sine freq=1G ampl=1 fundname="LO"
    V1 (rf 0) vsource type=sine freq=900M ampl=1 fundname="RF"
    R0 (_net0 0) resistor r=1K
    simulatorOptions options reltol=1e-3 vabstol=1e-6 iabstol=1e-12 temp=27 \
        tnom=27 scalem=1.0 scale=1.0 gmin=1e-12 rforce=1 maxnotes=5 maxwarns=5 \
        checklimitdest=psf
    pss  pss  fund=100M  harms=20  errpreset=moderate  annotate=status
    subckts info what=subckts  where=rawfile
    ahdl_include "/export/home/apps/IC615_isr/tools/dfII/samples/artist/ahdlLib/multiplier/veriloga/veriloga.va"
    And attached is the picture of my results.
  • lahsivece
    Thanks for the quick reply.
    I am using voltage sources as input . With two sinusoids as input, I am getting correct output. I made two silly mistakes while using multiplier. First was with vpulse source. I assigned v_high=1.2 when I should have assigned v_high=1.  I was calculating gain as 2/pi when it should have been 1/pi ( upconverted and downconverted product). pi comes into picture when digital pulse is expanded into fourier series.
    Vishal
