  2. RF Design
  3. Symbol view vs. spectre view
  • Subscribers 64
  • Views 21100
Magistus
Magistus over 13 years ago
I'm a little bit confused. I want to simulate some schematics using Spectre. The Cells i used have different Views. Until now i always used the symbol-view. But now i wondering: What are the other views used for? There are these views:
Should i use the spectre-view if i want to simulate using Spectre?
Thank you for all answers!
  • Frank Wiedmann
    Frank Wiedmann over 13 years ago
    You should always use the symbol view for building your schematics. The spectre view is used as a so-called stop view. Interestingly, the best explanation of the function of a stop view seems to be on Agilent's website at http://cp.literature.agilent.com/litweb/pdf/ads2008/dynlnkug/ads2008/Using_Switch_Views,_Stop_Views_and_the_Hierarchy_Editor.html
    Actually, this is documented in the Virtuoso Analog Design Environment L User Guide (in cdnshelp, or look at <ICinstDir>/doc/anasimhelp/anasimhelp.pdf ). There's a section called "How the Netlister Expands Hierarchy" which explains this. In fact Agilent's site seems to have lifted exactly the same flowchart from the ADE documentation ;-)
    It also refers to the hierarchy editor user guide (from the same document), which gives more control.
    The idea is that having determined how the netlister expands the hierarchy, once it reaches a stopping view, it will then use the information in the Simulation Information section of the CDF for that component to determine how the instance formatted in the netlister.
    Typically the stop view is usually just a copy of the symbol, and is just a marker to tell it where to stop - it doesn't really need much information from the view itself - except the terminals. The terminals may potentially have additional (inherited) terminals for adding bulk terminals to 3 terminal transistors (for example), but in most cases the stopping view looks identical to the symbol view.
  • Frank Wiedmann
    Thanks for letting me know, Andrew. For some reason, this document does not show up when I search support.cadence.com for "stop view".
  • Magistus
    I will read the User Guide an monday and write again if further questions occur.
    Thank you Frank and Andrew!
