  2. RF Design
  3. S-parameter datafile path in nport
  • Subscribers 63
  • Views 18851
Aldo2
Aldo2 over 13 years ago
Is it possible to define a relative path in the S-parameter field of an nport component? If the library is transferred to a different path, have all the nport data file fiels to be modified?
    Yes. If you omit the full path and only give a relative path name, you can then specifying the include path in ADE - which can be relative to the working directory.
    So for example, say you have an s-parameter file, file.s2p, in a subdirectory "models" under your working directory. Specify the file on the nport as "file.s2p" and then in ADE under Setup->Simulation Files, specify Include Path as "./models".
  • Aldo2
    Many thanks Andrew
    Regards
    Aldo
