  2. RF Design
  3. Link for "Virtuoso Spectre Circuit Simulator User Guide...
  • Subscribers 63
  • Views 11847
Link for "Virtuoso Spectre Circuit Simulator User Guide"
RFStuff
RFStuff over 13 years ago
 Dear All,
I am looking for the latest  "Virtuoso Spectre Circuit Simulator User Guide".
While searching in cadence online support it gives me many links with  "Virtuoso Spectre Circuit Simulator User Guide xxxxxxxx".
But I am not able to get the exact user guide.
Could anybody please point to the desired link
Kind Regards,
    Running cdnshelp either pointing at your MMSIM installation, or running the cdnshelp that's in your MMSIM installation will do this:
     `cds_root spectre`/tools/bin/cdnshelp &
    Then you can navigate down to spectre and find the  manual. You can search it, follow hyperlinks, and even open the pdf.
    You could also just look in the installation under the doc dir, and find spectreuser/spectreuser.pdf . But cdnshelp is intended to get you to the documentation...
    You can also bring up Help from within Virtuoso (assuming you're using IC61, which maybe you're not) and add a library to point to the MMSIM docs so that you can get it that way.
