  2. RF Design
  3. phase noise of divider
  • Subscribers 65
  • Views 20476
Frank Opteynde
Frank Opteynde over 12 years ago
I need to simulate the phase noise of a divider (or, more generally, simulate the phase noise on a non-sinusoidal signal).   Most straightforward way is SpectreRF -> pss -> pnoise.  There used to be a Cadence application Note about how to do this.  I remember it had to do with simulating pnoise with 'time-domain' option, then dividing the voltage noise [V/sqrt(hz)] by the signal slope to obtain time noise [sec/sqrt(Hz)], then multiply by 2.pi.freq to obtain phase noise [radians/sqrt(hz)].  But since I don't remember the details, can anybody provide me with this application note?   Thanks in advance
  • MicheleA
    MicheleA over 12 years ago
    Hi Frank,
    I am not aware of a Cadence app note, so in case I will be glad to take a look :)
    However, there is quite some treatment on this and related topic in Kundert's designers-guide.org  site.
    This link is a good start : http://www.designers-guide.org/Analysis/PLLnoise.pdf
    If I may say, if you want to characterize the *phase* noise, then PSS and Pnoise are what you need. Just feed your divider with a pure signal (whatever it needs, sin or square), and the Pnoise will give you exactly the output power spectrum of the divided waveform.
    The 'strobed PNoise' is I think what you refer to, and was an indirect method based on sampling the noise of your 'edge producing circuit' only at the zero crossing times, and manipulating the PSD of this process (basically, jitter) into phase noise. Quite thick subject, I may add :)
    Hope this helps,
    Michele
  • Frank Wiedmann
    Frank Wiedmann over 12 years ago
    You might be looking for http://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:DocumentViewer;src=wp;q=ApplicationNotes/Custom_IC_Design/JitterAN0306.pdf. You also might want to take a look at http://www.designers-guide.org/Analysis/sc-filters.pdf and http://www.designers-guide.org/Forum/YaBB.pl?num=1224609785.
