  2. RF Design
  3. Threshold voltage calculation
  • Subscribers 63
  • Views 28712
aravindkvarier
aravindkvarier over 12 years ago
Sir, can you specify the steps required for calculating the exact threshold voltage of an NMOS device?
    Andrew Beckett over 12 years ago +1
    What do you mean by the "exact threshold voltage"? Most devices output this as an operating point parameter - for example, if you do "spectre -h bsim4" you'll see a section labelled "Operating Point Parameters…
    What do you mean by the "exact threshold voltage"? Most devices output this as an operating point parameter - for example, if you do "spectre -h bsim4" you'll see a section labelled "Operating Point Parameters" and within that you have:
    1       region=triode     Estimated operating region. Spectre outputs the number (0-4) in a rawfile. Possible values are
                              off, triode, sat, subth, and breakdown.
    9       vgb (V)           Gate-bulk voltage.
    10      vth (V)           Threshold voltage (alias=lv9).
    11      vdsat (V)         Drain-source saturation voltage (alias=lv10).
    12      gm (S)            Common-source transconductance (alias=lx7).
    13      gds (S)           Common-source output conductance (alias=lx8).
    14      gmbs (S)          Body-transconductance (alias=lx9).
    So if you do a DC operating point analysis (assuming you're using spectre, you didn't say) in ADE (again, you didn't say if you're using the Analog Design Environment), you can then do a Results->Print->Operating Point and click on the device in the schematic and look at the vth. Or you could annotate the operating point parameters on the schematic and by using the Edit->Component Display in the schematic or View->Annotation... menu (in IC616 onwards) you can choose what gets annotated.
    Whether the model's implementation of vth is what you're expecting or not by "exact threshold voltage" is another question!
  • Rujie Zhao
    Rujie Zhao over 6 years ago in reply to Andrew Beckett
    It helps.
  • Rujie Zhao
    Rujie Zhao over 6 years ago in reply to Rujie Zhao
    how can we check a and Km value when we calculate Vth? Thanks
    Andrew Beckett over 6 years ago in reply to Rujie Zhao
    First of all, please don't post a new question in a 6 year old thread - please see Guidelines for the RF Design Forum
    Secondly, what are a and Km? I've no idea what you're referring to.
