  2. RF Design
  3. pnoise spurs at multiples of clock frequency.
  • Replies 19
  • Subscribers 65
  • Views 23691
vamshiky
vamshiky over 11 years ago
 I have a simple inverter driven by a square wave, and ran pnoise on the circuit.
There is flicker and thermal noise and after that  has huge spurs ( about +20dBc ) at 2*Ffref , 5*Fref.
And this goes away if I carefully choose the sweep type and step size (delberately avoiding those freq points during sim).
Also I have noticed from earlier posts that while running pnoise sim, simulator automatically skips the freq point which is exact multiple of beat frequency and gives a message "Infinite flicker noise is ignored"
however I dont see this happening in my sims.
Are there any additonal settings/options which I missed out.
Vamshi
    Vamshi,
    Can you post your Netlist (the input.scs) here and also give the spectre subversion you're using? (Type "spectre -W" at the unix prompt; it will also appear near the top of the spectre output log)?
    Whilst I can throw together a simple example to show this, seeing your setup will help to understand why you are getting this.
  • vamshiky
    Andrew, Here is the netlist, and spectre is : sub-version 12.1.0.489.isr9 ---------------------------- // Generated for: spectre // Generated on: Dec 19 12:31:13 2013 // Design library name: xxxx // Design cell name: test_pss_pnoise // Design view name: schematic simulator lang=spectre global 0 include "xxxxx.scs" // Library name: xxxxxxxxx // Cell name: CKINVX2 // View name: schematic subckt CKINVX2 VDD VSS i o MN0 (o i VSS VSS) nch_lvt ..................... MP0 (o i VDD VDD) pch_lvt ...................... ends CKINVX2 // End of subcircuit definition. // Library name: xxxx // Cell name: test_pss_pnoise // View name: schematic V1 (avss 0) vsource dc=0 type=dc V0 (avdd0p8 avss) vsource dc=800.0m type=dc I1 (avdd0p8 avss in out) CKINVX2 V2 (in avss) vsource type=pulse val0=0 val1=800.0m period=20n delay=10p \ rise=10p fall=10p width=10n C0 (out avss) capacitor c=10f simulatorOptions options reltol=1e-3 vabstol=1e-6 iabstol=1e-12 temp=27 \ tnom=27 scalem=1.0 gmin=1e-12 rforce=1 maxnotes=5 maxwarns=5 digits=5 \ cols=80 pivrel=1e-3 sensfile="../psf/sens.output" checklimitdest=psf pss pss fund=50M harms=10 errpreset=conservative + annotate=status pnoise ( out avss ) pnoise start=1k stop=500M dec=20 + maxsideband=10 annotate=status modelParameter info what=models where=rawfile element info what=inst where=rawfile outputParameter info what=output where=rawfile designParamVals info what=parameters where=rawfile primitives info what=primitives where=rawfile subckts info what=subckts where=rawfile save out avss saveOptions options save=selected -------------------------------------------------------------------------- In this example I get tones at 100M,500M with -1.7dB magnitude, and & noisefloor is <-150dB. Not sure if can give the device details at the moment, so removed those lines here... Thanks, Vamshi
  • vamshiky
    As I mentioned earlier, when I changed sweep type these tones disappear. ------------ pnoise ( out avss ) pnoise start=1k stop=501M step=1.7M + maxsideband=10 annotate=status --------------
    I tried your circuit (with two pnoise analyses in the netlist to make it simpler), and with some made up models and device sizes, and I don't see the problem. Spectre also reports (using the same version you're using):
     Warning from spectre at freq = 100 MHz during PNoise analysis `pnoise'.
        WARNING (SPCRTRF-15037): Infinite flicker noise is ignored.
    Here's what I used (I fixed your line wrapped netlist - I assume you're using Chrome, which causes some problems with the forums on this web site, as far as I know).
    global 0
    //include "xxxxx.scs"
    model nch_lvt bsim4 type=n
    model pch_lvt bsim4 type=p
    MN0 (o i VSS VSS) nch_lvt w=1u l=0.1u
    MP0 (o i VDD VDD) pch_lvt w=2u l=0.1u
    ends CKINVX2
    + annotate=status
    pnoiseAlt ( out avss ) pnoise start=1k stop=501M step=1.7M
    save out avss
  • vamshiky
     Thanks for your efforts Andrew, I now need to understand if the issue is with models used or some kind of env variable which differs from your test.
    please suggest.
    -Vamshi
    It seems unlikely that it would be an environment variable. I can only imagine that it might be model related. Maybe the flicker noise profile is such that the flicker noise is still high near the harmonic multiples.
    That said, I just tried setting dec=200 on the pnoise line, and I no longer get the message about infinite flicker noise, and there is a huge peak at 100MHz if I do this. So my guess is that due to floating point numerical error, it may not detect the near-infinite flicker noise and out a value instead (e.g. if it was a small fraction of a Hertz away from the harmonic multiple).
    Either way, going through exact (or very near exact) multiples of the fundamental probably doesn't make a lot of sense anyway.
  • vamshiky
    OK, then I am only left with carefully choosing the step sizes/ sweep points. Linear step size with an irrational number does the job but actually slows my sims on actual circuit chargepump for PLL. (ofcourse still see a bit of wierd behaviour at high frequencies)
    Do you have any better suggestions to avoid those near/exact multiple frequencies in sims.
    Vamshi
    Vamshi,
    Could you alter your input frequency to not be exact "decade" frequency? Then you could use a number of points per decade, and know that your harmonics don't coincide with 10M, 100M, 1G etc.
  • vamshiky
     I understand that, however input frequncy is a system level spec and cant be changed.
    Vamshi
    The other alternative is that you specify start, stop and log - this is the number of log steps beween the two end points. For example:
    pnoiseLog ( out avss ) pnoise start=1k stop=501M log=110
    So I moved the end point to not be on an exact multiple, and I made the log roughly 20*numDecades (assuming you had dec=20 before).
