  2. RF Design
  3. pnoise spurs at multiples of clock frequency.
  • Replies 19
  • Subscribers 65
  • Views 27766
vamshiky
vamshiky over 12 years ago
 I have a simple inverter driven by a square wave, and ran pnoise on the circuit.
There is flicker and thermal noise and after that  has huge spurs ( about +20dBc ) at 2*Ffref , 5*Fref.
And this goes away if I carefully choose the sweep type and step size (delberately avoiding those freq points during sim).
Also I have noticed from earlier posts that while running pnoise sim, simulator automatically skips the freq point which is exact multiple of beat frequency and gives a message "Infinite flicker noise is ignored"
however I dont see this happening in my sims.
Are there any additonal settings/options which I missed out.
Vamshi
  • vamshiky
     Yes I did try this and something similar by changing both start and end points to not be on exact multiple.
     These help upto some extent,  probably ok for now and thanks for the support.
    -Vamshi
     Although changing the start and stop and keeping dec wouldn't help, because it will still start each decade on an exact exponent of 10. But at least log should help make it far more likely that you miss the exact multiples, whilst keeping the same type of distribution that dec would have.
  • ManuelSuarez
    ManuelSuarez over 10 years ago
    I am having problems with a spur as you said before in this post. I am calculating the jitter from the pnoise simulation.
    The situation is as follows:
    I am developing a distribution path for a 100MHz clock. When the phase noise is simulated, the results show a huge spur at the frequency of 100MHz. The integration of the noise power density spectrum neglecting the spur provides a jitter smaller than 1ps while the spur provides a jitter over 1ns. The top value of the spur compared with the noise at 1Hz stay constant independently of the cell simulated: buffers, inverters…
    Simulation parameters:
    · Toot: cadence spectre APS
    · Beat Freq:100MHz
    · Num Harmonics: 60
    · Points per Dec: 80
    · Sweeptype:absolute
    · Noise type: jitter/Sources
    as mentioned in earlier answers, less point/dec filter the peak more or less while the other noise spectrum stay +- the same.
    There is some explanation for the spur?
    Best regards
    Manuel
    ShawnLogan over 10 years ago
    Dear Manuel,
    I am not Andrew and certainly do not possess his expertise, but if I understand your issue correctly, I think I can provide some insight.
    If you are stimulating your clock distribution path with a 100 MHz clock, and you examine its phase noise spectrum with a fundamental frequency of 100 MHz, you will definitely observe "spurs" (as you call them) at 100 MHz. The spurs are associated with the sampling process - effectively a phase sample is created every period of your 100 MHz clock. Hence, the resulting spectrum will be periodic and limited to fs/2 in its frequency content. Hence, I would recommend you perform your integration up to 50 MHz. Does this make sense to you?
    I'm also a little confused as to the goal of your simulation. Are you trying to measure the random noise due to the distribution path - or are you trying to assess the deterministic jitter of your clock distribution path? There may be an alternative to your strategy that I could suggest if you are interested and provide a bit more detail on the goal of your effort.
    Shawn
  • ManuelSuarez
    hi Smlogan,
    Thanks by your answer. My case is a clock of 100MHz for an ADC and the specification was: Jitter < X fsRMS. I am interested in all contribution to the jitter so I took a large bandwidth in spite of the low frequencies has no impact.
    As you mentioned, several other answers in the forum recommend do the integration to fs/2. In the cadence documentation "FM jitter measurement ussing PSS shooting and pnoise jitter" (i use the jitter PM option) uses fs=1.9GHz and integration to 1GHz. Nevertheless, the white noise in my simulations is limited to the 1GHz where it decreases. Since we are analyzing periodic noise, i guess it has sense consider the freq=+-fs/2 only.
    I am new in the phase noise analysis and my knowledge is reduce to i read recently. In many "phase noise to jitter" tutorial, they integrate the noise in ranges from kHz to 2fs. At this point i am a little confused. The JcRMS(2fs) is close to 2JcRMS(fs/2) in the simulations, and more when I increase the bandwidth. The Jc calculated in cadence takes in to account the factor 2 of both sides of the noise around fs?
    The effects of the power supply i have to simulate them with the PXF right?
    M
    Dear Manuel,
    Thank you for your added application information. It is helpful!
    > I am interested in all contribution to the jitter so I took a large bandwidth in spite of the low frequencies has no impact..
    If you are using a 100 MHz A/D, the signal frequencies of interest must be well under 50 MHz. However, it is possible that the bandwidth of the ADC clock input may exceed the bandwidth of the input signal. If you happen to know the bandwidth of the ADC clock input, I might propose using that bandwidth as the maximum frequency to use in your clock jitter computation.
    If you have simulated the random phase noise component of a your clock signal, you can estimate its random jitter component by integrating the phase noise between the minimum and maximum frequencies of interest to compare to your requirement.
    As far as deterministic jitter components are concerned, for the clock path you are simulating, you might impose the amount of supply noise you expect on the buffer supplies and examine the resulting peak-to-peak time interval error (TIE) at the ADC input port. This will provide an estimate of the deterministic jitter. There is some frequency dependence to the peak-to-peak output TIE - so the frequency content of your supply noise is important to include in the simulation. This simulation can be a simple transient simulation.
    I hope this provides some help...
    Shawn
  • Frank Wiedmann
    Frank Wiedmann over 10 years ago
    Use pnoise jitter analysis with the fullspectrum option and make sure that the maxacfreq parameter of the pss analysis has a sufficiently large value (see http://www.designers-guide.org/Forum/YaBB.pl?num=1438976388 for some more details). Integrate the noise power from 0 Hz to half of the pss fundamental frequency. You can find some more information (also about pxf) in the thread starting at http://www.designers-guide.org/Forum/YaBB.pl?num=1224609785 and the links given there.
  • ManuelSuarez
    Hi and thanks by the answer, now it is clear. Only one more question. Is the value Jc the total jitter or i have to take into account a factor 2? I mean, the tool takes into account the contribution of both sides of the spectrum around the center freq?
    Thanks again
    M
  • Frank Wiedmann
    Jc(k) is the k-cycle jitter, that is the standard deviation of the duration of k cycles of the signal.
