  2. RF Design
  3. VCO: PSS and pnoise analysis and Numerical Errors
  • Subscribers 63
  • Views 16125
rsrk
rsrk over 12 years ago
   I am Sivaramakrishna. My query is about the numerical/simulation errors in pnoise/pss analysis of VCO.
   I am designing a (CMOS LC-) VCO and Interesting I am getting different phase-noise for the same circuit with with same settings, such as initial conditions, and integration methods(it was suggested that I need to use *trap* integration method in-order to get correct results).
   Its varying around 1-to-2 dBc. I feel that this variation is significant as it is in log scale.
   The only way I can, at least to the best of my knowledge, see if the numerical/simulation noise is playing any role. Could someone shed light on it.
Thanks and Regards
Sivaramakrishna
  • Tawna
    Tawna over 12 years ago
    Hi Sivaramakrishna,
     If this is a strongly nonlinear circuit (e.g. ring oscillator), then pss-shooting is appropriate.  Otherwise, I would use hb (harmonic balance).
    Please check out your setup - very important to get correct results.   In my blog:
    SpectreRF Tutorials and Appnotes... Shhhh... We Have a NEW Best Kept Secret!
    I mention the new SpectreRF design workshops, which include  Simulating Oscillators:   LC and Ring Oscillators.
    The workshops take you through step by step the best way to set up your oscillator to get accurate results.  There is also a design database in the hierarchy.  The setup instructions are in Appendix A of the MMSIM12.1.1 or 13.1 SpectreRF User Guide.
    best regards,
    Tawna
