  2. RF Design
  3. Unable to run PSS Analysis
  • Subscribers 63
  • Views 15060
aravindkvarier
aravindkvarier over 12 years ago
Sir,
I have used BSIM-CMG107.0.0 Mosfet Compact model for my thesis work. But when I go for pss analysis, an error is shown saying that the behavioural file that you have given is not supported for pss analysis. The model is actually a verilog-A file. It would be grateful if you give me any solution for the rectification of the problem.
Regards
Aravind
    Aravind,
    I'm guessing that the error is that there's a hidden state in the model. See this document which describes the issue well. But since you didn't give any information about the error or which version you're using, this is just guesswork.
