  2. RF Design
  3. PSS Analysis Error
  • Subscribers 63
  • Views 16484
PSS Analysis Error
ksnf3000
ksnf3000 over 12 years ago
Hello All,
I am trying to design and simulate a LNA using Virtuoso IC6.1.5.500.1 32
While simulation using "PSS" as analysis, I am getting the following error.
ERROR (SPCRTRF-15177): PSS analysis doesn't support behavioral module components with hidden states found in component 'modnm_ahdl'
FYI... I am using AMS 350nm h35b4d3 technlogy and I am NOT using the PRIMLIBRF library; i am using the transistors from PRIMLIB library only.
 Do you think this may be the issue?
Thanks!
 Best Regards,
Kashif
    Assuming that modnm_ahdl is provided by the AMS kit, you will need to contact AMS over this. Hidden states are not supported in SpectreRF - you can find an explanation about this here - but in the case of a foundry model, they really should fix it, I think.
