  2. RF Design
  3. spectre , multiple model files and mixed section names
  • Subscribers 63
  • Views 17682
marcelpreda
marcelpreda over 12 years ago
Hi there,
We have a case where we have to use multiple model files in spectre simulation.
I want to avoid situation where by mistake different section names are used in the simulation.
E.g.
include "/home/predamar/tests/spectre/my_models/include.scs" section=fast
include "/home/predamar/tests/spectre/basic/include.scs"
include "/home/predamar/tests/spectre/my_models_2/include.scs" section=nom
In one place is used "fast", in other is "nom".
 I want to have the possibility to provide an error message and to stop the simulation.
The include lines which have no "section" will be ignored.
So, all the included files should have the same section name.
The only solution that I see now is to trigger a script before starting spectre simulation,and to parse the top netlist file.
I want to know if spectre has something builtin that may help.
Best Regards,
Marcel
    Marcel,
    A few possibilities for doing this in spectre. One is to include a dummy parameter in each section:
    parameters includedMoreThanOnce=1
    Another is to define a dummy subckt in each section (with the same name). Unless the option redefinedparams has been changed (in the first case) or duplicate_subckt (in the second case) then it will fail. See "spectre -h options" for more details on these.
    The other approach would be to alter the flowchart (examples in this forum and on support.cadence.com) to trigger a check post-netlisting (say) to look at the output of asiGetModelLibSelectionList(asiSessionId) to check for duplicates. That would be cleaner than parsing the input.scs
  • marcelpreda
     There are just too many options :D
     I fully understood the 3rd one, but for the 1 and 2 I'll need some time to digest it.
    Marcel
