  2. RF Design
  3. n1port
  • Subscribers 63
  • Views 15396
n1port
ajmedina
ajmedina over 12 years ago
Hi, can some please help me understand why my n1port properties box (pic below) doesn't look like the one in the link below?
uuu.enseirb.fr/.../Sparametre.html
As you can see it's missing the S Parameter data file field (and others) and I  haven't been able to get n1port to work when inserting the file name into the "Model name" field.
(ver. 5.10.41_USR5.053107 -- 31 May 2007).
Thanks!
Andy
    That's because you're using one from a different library. The one in the hyperlink is from analogLib, and you're using the one from some library called "NCSU_Analog_Parts". Try adding:
    analogLib       $(inst_root_with:tools/dfII/bin/icfb)/tools/dfII/etc/cdslib/artist/analogLib
    into your cds.lib and then you should be able to see the analogLib version (assuming it isn't in there already).
  • ajmedina
    Worked like a charm - thanks!
