  2. RF Design
  3. Exporting s2p file from spetre
  • Subscribers 63
  • Views 24007
radiowaves
radiowaves over 12 years ago
I am using IC 6.1.6 and I want to export .s2p file after s parameter simulation. I tried using
sparameter analysis window>options>output parameters >filename.s2p>dtft=touchstone
But no file is saved when I run the simulation.
    I suspect you are looking in the wrong place for the file. Since you didn't give a full path for the file name, it will write it into the directory from which spectre is invoked. That's the netlist directory - ie the same place that the input.scs is created by ADE.
  • radiowaves
    Got it. Thank you very much!
