  2. RF Design
  3. ERROR (VACOMP-1008): Cannot compile ahdlcmi module libr...
  • Subscribers 64
  • Views 23786
ERROR (VACOMP-1008): Cannot compile ahdlcmi module library
Shaa
Shaa over 12 years ago
Dear Friends,
I have faced to this problem, when I have added a VARICAP to my VCO circuit.
Error found by spectre during AHDL read-in.
    ERROR (VACOMP-1008): Cannot compile ahdlcmi module library. Check the log file input.ahdlSimDB//bsource.va.bsource_1.ahdlcmi/Linux/../ahdlcmi.out for details. If the compiler ran out of memory, use 'setenv CDS_CMI_COMPLEVEL 0', and try again. If the reason for the failure was a syntax error, contact your Cadence Customer Support representative with the netlist, log files, behavioral model files, and any other information that can help identify the problem.
    ERROR (SFE-91): Error when elaborating the instance bsource_1. Simulation should be terminated.
Does anybody know a solution for it?
Thanks in advance
Shaa
    Shaa,
    Did you check the log file (../ahdlcmi.out) as suggested? If it doesn't make sense to you, please post it here (as an attachment, using the Options tab).
  • Shaa
     Dear Andrew,
    I have attached a folder. I hope it's the right one.
    Shaa
  • Shaa
     And output log:
    Cadence (R) Virtuoso (R) Spectre (R) Circuit Simulator
    Version 11.1.0.509.isr14 32bit -- 14 Aug 2012
    Copyright (C) 1989-2012 Cadence Design Systems, Inc. All rights reserved worldwide. Cadence, Virtuoso and Spectre are registered trademarks of Cadence Design Systems, Inc. All others are the property of their respective holders.
    Protected by U.S. Patents:
            5,610,847; 5,790,436; 5,812,431; 5,859,785; 5,949,992; 5,987,238;
            6,088,523; 6,101,323; 6,151,698; 6,181,754; 6,260,176; 6,278,964;
            6,349,272; 6,374,390; 6,493,849; 6,504,885; 6,618,837; 6,636,839;
            6,778,025; 6,832,358; 6,851,097; 6,928,626; 7,024,652; 7,035,782;
            7,085,700; 7,143,021; 7,493,240; 7,571,401.
    Includes RSA BSAFE(R) Cryptographic or Security Protocol Software from RSA Security, Inc.
    User: shaahin   Host: kosh2   HostID: A8C08301   PID: 17250
    Memory  available: 3.0265 GB  physical: 33.7822 GB
    CPU Type: Intel(R) Core(TM) i5-2500 CPU @ 3.30GHz
              Processor PhysicalID CoreID Frequency
                  0         0        0     3601.0
                  1         0        1     1600.0
                  2         0        2     1600.0
                  3         0        3     1600.0
    Simulating `input.scs' on kosh2 at 3:46:57 PM, Mon May 19, 2014 (process id: 17250).
    Current working directory: /home/nst/shaahin/cds/spice/SG13SLBE_09/work/shaahin/cds/sim/VCO24_03/spectre/schematic/netlist.
    Environment variable:
        SPECTRE_DEFAULTS=-Ev
    Command line:
        /opt/spectre/MMSIM111/tools.lnx86/spectre/bin/32bit/spectre  \
            input.scs +escchars +log ../psf/spectre.out +inter=mpsc  \
            +mpssession=spectre1_13032_4 -format psfxl -raw ../psf  \
            -I/cds/spice/SG13SLBE_09/lib/TL_SG13/RLCG/spectre/ +lqtimeout  \
            900 -maxw 5 -maxn 5
    spectre pid = 17250
    Loading /opt/spectre/MMSIM111/tools.lnx86/cmi/lib/5.0/libinfineon_sh.so ...
    Loading /opt/spectre/MMSIM111/tools.lnx86/cmi/lib/5.0/libphilips_sh.so ...
    Loading /opt/spectre/MMSIM111/tools.lnx86/cmi/lib/5.0/libsparam_sh.so ...
    Loading /opt/spectre/MMSIM111/tools.lnx86/cmi/lib/5.0/libstmodels_sh.so ...
    Warning from spectre in `res_rppd', during circuit read-in.
        WARNING (SFE-2296): "/cds/spice/SG13SLBE_09/tech/SG13_PASSIVES/spectre/SG13_res.lib" 146: The inline subckt definition `res_rppd' does not contain any inline components. The `inline' qualifier will therefore be ignored.
    Time for NDB Parsing: CPU = 65.989 ms, elapsed = 169.55 ms.
    Time accumulated: CPU = 65.989 ms, elapsed = 169.55 ms.
    Peak resident memory used = 22 Mbytes.
    Warning from spectre in `sg13_lv_nmos', during circuit read-in.
        WARNING (SFE-2941): "/cds/spice/SG13SLBE_09/tech/SG13_MOS/library/spectre/sg13_moslv_psp_mod.lib" 80: `sg13_lv_nmos': Parameter `l' redefines parameter of same name defined at higher level. Local parameter value will be used.
    Warning from spectre in `sg13_hv_svaricap', during circuit read-in.
        WARNING (SFE-2941): "/cds/spice/SG13SLBE_09/tech/SG13_MOS/library/spectre/sg13_svaricaphv_mosvar_mod.lib" 48: `sg13_hv_svaricap': Parameter `l' redefines parameter of same name defined at higher level. Local parameter value will be used.
    Opening directory input.ahdlSimDB/ (775)
    Opening directory input.ahdlSimDB//bsource.va.bsource_1.ahdlcmi/ (775)
    Opening directory input.ahdlSimDB//bsource.va.bsource_1.ahdlcmi/Linux/ (775)
    Compiling ahdlcmi module library.
    Warning from spectre in `sg13_hv_svaricap':`D0', during hierarchy flattening.
        WARNING (SFE-30): "/cds/spice/SG13SLBE_09/tech/SG13_MOS/library/spectre/sg13_svaricaphv_mosvar_mod.lib" 103: D0.mvcap1: `trise' is not a valid parameter for an instance of `D0.sg13_hv_svaricap'.  Ignored.
        WARNING (SFE-30): "/cds/spice/SG13SLBE_09/tech/SG13_MOS/library/spectre/sg13_svaricaphv_mosvar_mod.lib" 110: D0.mvcap2: `trise' is not a valid parameter for an instance of `D0.sg13_hv_svaricap'.  Ignored.
    Given the error in the ahdlcmi.out file:
     /opt/spectre/MMSIM111/tools.lnx86/cdsgcc/gcc/bin/cdsgcc: line 264: /opt/spectre/MMSIM111/tools.lnx86/cdsgcc/gcc/4.4/install/bin/gcc: cannot execute binary file
    The error is likely to be that you are trying to run  a 64-bit executable on a 32-bit operating system. Current versions of MMSIM only support 64-bit OS (in general all of our supported releases require a 64-bit OS, even if running the application in 32-bit mode - this has been the case for a few years now).
    See the Platform Support Roadmap, and also the  Supported Platforms Matrix. You'll see that MMSIM10.1 supported RHEL4 as a 32-bit OS, but MMSIM12.1 requires a 64-bit OS. MMSIM11.1 is not on the list, but if memory is correct, it was the first MMSIM release to require a 64-bit OS.
    If you do:
    file  /opt/spectre/MMSIM111/tools.lnx86/cdsgcc/gcc/4.4/install/bin/gcc
    it should say something like:
     ELF 64-bit LSB executable, x86-64, version 1 (SYSV), dynamically linked (uses shared libs), for GNU/Linux 2.4.0, not stripped
    and if "uname -a" does not have "x86_64" in the supported list, you're on a 32-bit OS. You'll need to find a machine with a 64-bit OS, or if it's 64-bit hardware on your computer (quite likely unless the machine is really old), then upgrade to a supported 64-bit OS.
     Linux lnx-mymachine 2.6.32-131.0.15.el6.x86_64 #1 SMP Tue May 10 15:42:40 EDT 2011 x86_64 x86_64 x86_64 GNU/Linux
    Kind Regards,
