  2. RF Design
  3. [Help] How to set up digital sources in Cadence?
  • Subscribers 63
  • Views 17367
xxgenerall
xxgenerall over 12 years ago
Signal sources include some periodical digital signals, like "10111100110101100000,10111100110101100000,10111100110101100000,......". Is there any way to set up a signal souce conviniently?
I tried the "vpwl" of analogLib, but my digital codes exceed 50. Can any one help me, please?
Thank you very much.
    If it's a single bit stream, then you can use either vsource with the type set to "bit", or a "vbit" source from analogLib.
    If it's a bus, then the best way would be to use a vector file, accessible via Setup->Simulation Files in ADE. The format is covered in a chapter in the UltraSim documentation, but also "spectre -h vector" gives a bit of coverage (the UltraSim docs are more complete though).
  • xxgenerall
    Thank you so much. Mr. Beckett.
    ^_^
