  2. RF Design
  3. ADE GXL: Global Optimization
  • Subscribers 64
  • Views 16676
Eugene201
Eugene201 over 11 years ago
I'm running global optimization in ADE with a fairly large design space. As I understood from the documentation, global optimization does not require a starting point and will search the entire design space. However, the optimization run stops after only ~6000 points and says run complete no better design point can be found. If I then gave it a different starting point it finds a different optimum point. This tells me it is not searching the entire design space. In the options for the run I have tried both the "search points with no improvement" and "search points after condition met" set to 100000 and the simulation still stops after only ~6000 points. Also, the option is set to full evaluation instead of conditional.
Is there a way to get the optimizer to search more points or is this some sort of limit?
I'm running Cadence IC 6.1.5 and the simulation is s-parameter with noise.
Thank you,
    Please contact customer support.
  • Eugene201
    Thank you for your quick reply. I have been trying to get access to customer support all day and as it turns out we can't get customer support as university students. Would it be at all possible to look at this issue here in the forum?
    Thank you,
    Eugene
  • fanshujiao
    fanshujiao over 11 years ago
    I am a graduate student and I run into the same problem as yours with ADE GXL global optimization. Did you fix the problem or find any solution? Thank you very much!
  • Eugene201
    Unfortunately I have not found a "solution" to this to this problem but I have a good understanding as to why it is happening. As far as I understand GlobalOpt uses gradient optimization method which will by definition only find local minimums and not global minimums. It therefore finds the best operating point before it goes through every design point. There is no built in option to do random point optimization (which can continue until all points are simulated) but something like that can perhaps be made in SKILL code.
