  2. RF Design
  3. [Help]About the CMFB simulation.
  • Subscribers 63
  • Views 6415
xxgenerall
xxgenerall over 12 years ago
A fully differential amplifier is like below.
  • xxgenerall
    First, the fully diff amp is simulated by stb in a closed loop.
  • xxgenerall
    The CMFB phase margin is as below.
  • xxgenerall
    Second, the fully diff amp is simulated like below.
  • xxgenerall
    And, the CMFB phase margin is as below.
  • xxgenerall
    I'm not sure which one is correct, the 1st or the 2nd smulation. In my opinion, the first simulation is correct.
    Could anyone help me, please?
    Thanks a lot.
    ShawnLogan over 12 years ago
    Dear xxgenerall,
    I am not sure if others are experiencing the same problem, but It is very difficult to see any detail in your various JPEG files. I cannot make out the axes of your stability plots and I also can not tell how you are simulating the stability. From what I can tell, it appears you are doing two stability analyses - one with the opamp outputs open (i.e. no connects) and one with the opamp outputs feeding back to the inputs through a feedback factor. I can barely make out the DC operating point values annotated on each JPEG file, but it appears in the file "2.sch_closed", the opamp input values are the same whereas in file "3.sch_open", the two DC input values are signficantly different. This suggests that the opamp input devices in the analysis referred to by "3.sch_open" does not have the opamp devices biased at or near their expected operating points. Hence, I would not expect any results from a stability analysis using this topology to necessarily correspond to the stability of the opamp in its closed loop configuration (such as shown in 2.sch_closed).
    Shawn
