  2. RF Design
  3. [Help] Problem on LVS
  • Subscribers 63
  • Views 14450
Qisong
Qisong over 12 years ago
I am doing the LVS, and I encounter a problem.  Thank you! And the following is the file:
Assura (tm) Physical Verification Version av4.1:Production:dfII6.1.3:IC6.1.3.500.10
            Release 4.1
Copyright (c) Cadence Design Systems. All rights reserved.
@(#)$CDS: assura version av4.1:Production:dfII6.1.3:IC6.1.3.500.10 06/09/2009 14:40 (sfrh259) $
sub-version 4.1, integ signature 2009-06-09-1330
run on ee308-09.nmsu.edu from /opt/cadence/ASSURA41/tools.lnx86/assura/bin/32bit/assura on Tue Aug 19 23:01:27 2014
Starting /opt/cadence/ASSURA41/tools/assura/bin/aveng /home/graduate/qshu/IBM_Design/sub_LNA_outres.rsf -exec1 -LVS -cdslib /home/graduate/qshu/IBM_Design/cds.lib
@(#)$CDS: aveng version av4.1:Production:dfII6.1.3:IC6.1.3.500.10 06/09/2009 14:41 (sfrh259) $
Starting dfIIToVdb...
@(#)$CDS: dfIIToVdb version av4.1:Production:dfII6.1.3:IC6.1.3.500.10 06/09/2009 14:44 (sfrh259) $
run on ee308-09.nmsu.edu from /opt/cadence/ASSURA41/tools.lnx86/assura/bin/32bit/dfIIToVdb on Tue Aug 19 23:01:28 2014
Loading IBM PDK cmrf7sf procedures...
IBM PDK cmrf7sf Device Status Table loaded.
*Error* eval: undefined function - hiGraphicMode
<<< Stack Trace >>>
hiGraphicMode()
(getd('dbGetDatabaseType) && (dbGetDatabaseType() == "OpenAccess") && (hiGraphicMode))
Compiling rules...
WARNING LVS Run detected.
Non-legacy mode has been disabled for this LVS run
Checking out license for Assura_DRC 4.10
Reading the design data...
Finished dfIIToVdb.
Building the VDB part 2 in background mode.
Building tables for LVS Preprocessing in background mode.
Starting /opt/cadence/ASSURA41/tools/assura/bin/vdbToCells . sub_LNA_outres
Finished /opt/cadence/ASSURA41/tools/assura/bin/vdbToCells
Starting Nvn PreExtraction...
Starting /opt/cadence/ASSURA41/tools/assura/bin/nvn /home/graduate/qshu/IBM_Design/sub_LNA_outres.rsf -preExtract -exec1 -cdslib /home/graduate/qshu/IBM_Design/cds.lib
@(#)$CDS: nvn version av4.1:Production:dfII6.1.3:IC6.1.3.500.10 06/09/2009 14:45 (sfrh259) $
run on ee308-09.nmsu.edu at Tue Aug 19 23:02:15 2014
 INFO (AVLVSNN-10120) : '.nocase' command in binding file also switches on softSearchDeviceName(t) option to ensure, that compare rules are applied correctly.
Reading schematic network
 inputting netlist /home/graduate/qshu/IBM_Design/LVS/sub_LNA_outres.netlist.lvs
*WARNING* *.EQUATION is not supported
*WARNING* *.MEGA is not supported
*WARNING* *.PIN is not supported
*ERROR*  on line 33 in file /home/graduate/qshu/IBM_Design/LVS/sub_LNA_outres.netlist.lvs
? expecting colon (:)
*.PININFO Vbn:I Vbp:I Vin
______________________^^^
Finished /opt/cadence/ASSURA41/tools/assura/bin/nvn
*WARNING* An error occurred during Nvn PreExtraction.
LVS preprocessing requires a successful run of Nvn.
Assura will now terminate.
*WARNING* /opt/cadence/ASSURA41/tools/assura/bin/nvn exit with bad status
*WARNING* Status 256
*WARNING* Assura execution terminated
*WARNING* Bad exit from child process .. 0x100
*****  aveng terminated abnormally  *****
*****  aveng fork terminated abnormally  *****
*WARNING* aveng exit with bad status
