  2. RF Design
  3. pnoise noise separation & pac analysis contradicitng
  • Subscribers 62
  • Views 1884
radiowaves
radiowaves over 12 years ago
I am simulating a circuit with nonlinearity, time variance & frequency translation. The output Vout=(V1) + (V2) .
I used pnoise+noise separation to find transfer function from drain noise of M1 to  V1, V2 and Vout i.e. TF1, TF2 and TF and I find that TF=TF1 - TF2 which I want because it cancels M1 noise.
 But when I model drain noise of M1 with a current source as shown in figure, and perform pac analysis, I do not see cancellation and I find TF=TF1+TF2
I also modelled it with small sinusoidal current and did transient, performed FFT and found TF=TF1+TF2
I am doubtful which one to trust. Can pac and transient do the job of pnoise OR it is a mistake?
    It's pretty hard to understand what you've done here, so I suggest you contact customer support and provide the example that you're simulating - this will make it much easier to understand if you've made a mistake or if what you're doing doesn't make sense.
