  2. RF Design
  3. Noise correlation simulation in pnoise
  • Subscribers 63
  • Views 17438
radiowaves
radiowaves over 12 years ago
1. I am using IC6.1.6-64b.500.1 and my simulator version is 10.1.1.296.isr18 64 bit
2. I am simulating a basic downconversion mixer as shown in attached figure. I want to know the correlation between noise at
RF (red) and noise at IF (blue). I tried to follow the following article:
www.cadence.com/.../tdnoise.pdf
In page 7, it uses noisetype=correlations. But this option is not available in this version. How shall I find my required  correlation.
I shall highly appreciate if you provide me an appnote or the steps.
  • Tawna
    Tawna over 11 years ago
    Pnoise correlations is a byproduct of the pnoise modulated simulation. Pnoise modulated measurement is derived from the results of two analyses: pnoise and pnoise correlations. This means pnoise modulated results are only available when using the ADE GUI. (i.e. cannot plot the results in spectre standalone). “Correlations” was removed from the ADE GUI for several reasons - one being not many folks used it - it's mainly used to calculate pnoise modulation results. But pnoise correlations is still available in spectre standalone.
    Selecting noisetype=correlations correlates the noise at different ports of a multi-port circuit.
    For example, it computes the correlation of noise at different outputs, and the correlation of noise at the input and output of a circuit that exhibits frequency conversion. You can extract equivalent noise sources from these calculations. The parameter “cycles” refers to an array of cycle correlation frequencies when computing noise up- or down-converted to the output of a periodic driven circuit.
    To read more about correlations, see the section on Analyzing Time-varying Noise in the SpectreRF theory chapter . There is a simple example on Calculating Noise Correlation Coefficients and a Cyclostationary Noise Example. Also see the SpectreRF theory manual: http://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:DocumentViewer;src=pubs;q=/spectreRFTheory/spectreRFTheory14.1/chap1.html
  • radiowaves
    radiowaves over 11 years ago
    Hi Tawna,
    Thanks for the reply! I tried to run pnoise with noisetype= correlations simulation with maxcycles=5
    using the follwoing script:
    analysis('pnoise ?sweeptype "absolute" ?start "0" ?stop "100M"
    ?maxsideband "5" ?p "/voutp" ?n "/gnd!" ?oprobe ""
    ?iprobe "/PORT0" ?refsideband "1" ?noisetype "correlations" ?maxcycles "5" )
    analysis('pss ?engine "Harmonic Balance" ?flexbalance "yes" ?oversamplefactor "1"
    ?fund "2.4G" ?harms "5" ?errpreset "conservative" ?tstab "10n"
    ?step "" ?write "" ?writefinal "" ?swapfile ""
    ?checkpss "" ?backtracking "" )
    I tried to access the results using the tools>result browser>pnoise_corr folder. But I dont understand what those waveforms mean. I have read the documents including theory and user guide but this simulation and its output result format is NOT explained properly.
    The pnoise_corr folder  shows a list of I and V waveforms which are in complex form. The circuit is a mixer.
    What these waveforms mean?
    Are they PSDs?
    Are they correlation co-efficients? If yes then between which ports, which sidebands?
  • Tawna
    Hi radiowaves, Please submit a Case with Customer Support http://support.cadence.com . This is going to take some time/troubleshooting that can best be handled in a Case by a dedicated AE. (As opposed to the Cadence Community Forum...which we do in our spare time.) I am likely the person to whom it will be assigned. :-)
