  2. RF Design
  3. Model Parameters as "output" expressions
  • Subscribers 63
  • Views 3034
analogy
analogy over 12 years ago
Instead of printing model parameters, can we create an expression in ADE-L or ADE-XL to display value of the associated model parameter in output field ?
    You can either use the "mp" button in the calculator to find the expression for a parameter of the model associated with a named instance - e.g.
    MP("/I0/M4A","tox")
    Or if you know the name of the model, you can do:
    pv("gpdk090_pmos1v" "tox" ?result 'model)
    If you're not sure of the names, in the CIW you can do:
    selectResult('model)
    outputs()
    which will give you a list of the names of the models.
    You can find out the available parameter names by finding what model types are there:
    dataTypes() => ("capacitor" "bsim3v3" "phy_res")
    outputParams("bsim3v3") => (... huge list of parameters ...)
