  2. RF Design
  3. PSS and HB vs. Transient having touchstone models from ...
  • Replies 10
  • Subscribers 62
  • Views 19757
PSS and HB vs. Transient having touchstone models from HFSS
HamidKhatibi
HamidKhatibi over 11 years ago
Hello every one
I have designed a 100GHz oscillator and in order to see how much power it can produce I run different analyses. The issue is that the output voltage is quite different when I use different analyses. The frequencies are similar but the amplitudes are totally different. I have used PSS with harmonic balance and also probe-based HB (these two simulation give very similar results). However when I use Transient, the amplitude of the node voltages is quite different (the frequency is very similar).
Which one can I trust?
Thank you very much,
Hamid
PS: I have couple of transmission lines whose model are coming from EM simulation in HFSS.
  • Tawna
    Tawna over 11 years ago
    Regarding:
    HamidKhatibi said:
    Hello every one
    Hamid
    There could be a number of things going on.
    If you have access to Cadence Online Support, please check out these articles:
    • 20279103 MMSIM 13.1 Nport Overview and Guidelines
    http://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:ViewSolution;solutionNumber=20279103
    •  20158580 Tips for Using S-Parameters in Spectre and SpectreRF  (discusses troubleshooting)
    http://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:ViewSolution;solutionNumber=20158580
    • 20125630 Significant Improvements in S-parameter (nport) Simulation in MMSIM 12.1 and MMSIM 12.1.1  (particularly if using linear/spline interpolation)
    http://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:ViewSolution;solutionNumber=20125630
    1. What version of MMSIM are you using?  Typing the command in an xterm   spectre -W   will give this info.
    2. What are your nport settings?  (Post a snippet from the netlist).
    Best regards,
    Tawna
  • HamidKhatibi
    Hi Twana.
    Thank you  very much for your response. Unfortunately as a PhD student I have no access to those links.
    The version is : 11.1.0.722.isr24
    I have already read your useful note about the nport's settings and I have applied them in it.
    Thank you very much for your helpful responses.
    Hamid
    The netlist is:
    // Generated for: spectre
    // Generated on: Dec  4 08:22:54 2014
    // Design library name: 94GHz
    // Design cell name: BJT_Osc94GHz_NoYs_DCCapVer5_TL4u30u
    simulator lang=spectre
    global 0
    parameters Vdc2=880m Length=2.5 R3=1307 R2=51k R1=51k C1=4.88 C2=1.645 \
        C3=67.88 Q=50 Cs=44 RL=50
    include "/research/afshari-new/hk558/Cadence/ST_BICMOS130/Corners/corners.scs"
    // Library name: 94GHz
    // Cell name: BJT_Osc94GHz_NoYs_DCCapVer5_TL4u30u
    // View name: schematic
    C42 (net2 0) capacitor c=C1*1e-15
    C1 (net2 net023) capacitor c=1u
    C40 (net020 0) capacitor c=Cs*1e-15
    C44 (net016 0) capacitor c=C2*1e-15
    C43 (net016 net2) capacitor c=C3*1e-15
    Q5 (net20 net021 net020 0) npnvhsM2 l=Length*1e-6 nbc=4 nbb=6 nbe=3 mult=1 \
            mismatch=1 sh=1 lpe=0 dic_mdev=0 dib_mdev=0 soa=1
    R22 (net2 net016) resistor r=R3
    R23 (net2 0) resistor r=R1
    R24 (net016 0) resistor r=R2
    R21 (net020 0) resistor r=Q/(6.28*180*Cs*1e-6)
    R19 (net08 net019) resistor r=RL
    V9 (net17 0) vsource dc=Vdc2 type=dc
    V8 (net08 0) vsource dc=1.6 type=dc
    L21 (net17 net021) inductor l=10u
    L25 (0 net020) inductor l=10u
    I193 (net2 0) isource type=pulse val0=100.0u val1=0 rise=100f fall=100f \
            width=20p
    NPORT8 ( net016 0 net021 0) nport interp=spline fmax=3000G fdelta=.1G \
            imptrunc=1e-6 thermalnoise=no usewindow=yes datafmt=touchstone \
            file="/research/afshari-new/hk558/sNp/TL4u30u_190u_HFSSDesign1.s2p" \
            romdatfile="TL4u30u_150u" dcextrap=unwrap hfextrap=linear \
            passivity=enforce pabstol=1e-06 interp=spline thermalnoise=no
    NPORT9 ( net08 0 net019 0) nport interp=spline fmax=3000G fdelta=.1G \
            maxn=33 imptrunc=1e-6 thermalnoise=no usewindow=yes \
            file="/research/afshari-new/hk558/sNp/TL4u30u_550u_HFSSDesign1.s2p" \
            romdatfile="TL4u30u_170u" dcextrap=unwrap hfextrap=linear \
    NPORT10 ( net20 0 net019 0) nport interp=spline fmax=3000G fdelta=.1G \
            file="/research/afshari-new/hk558/sNp/TL4u30u_5u_HFSSDesign1.s2p" \
            romdatfile="TL4u30u_5u" dcextrap=unwrap hfextrap=linear \
    NPORT5 ( net019 0 net023 0) nport interp=spline fmax=3000G fdelta=.1G \
            file="/research/afshari-new/hk558/sNp/TL4u30u_130u_HFSSDesign1.s2p" \
            romdatfile="TL4u30u_360u" dcextrap=unwrap hfextrap=linear \
    simulatorOptions options reltol=1e-3 vabstol=1e-6 iabstol=1e-12 temp=27 \
        tnom=27 scalem=1.0 scale=1.0 gmin=1e-12 rforce=1 maxnotes=5 maxwarns=5 \
        checklimitdest=psf rawfmt=psfxl
    tran tran stop=1n errpreset=conservative outputstart=.1n \
        write="spectre.ic" writefinal="spectre.fc" method=gear2only \
        annotate=status maxiters=5
    dcOp dc write="spectre.dc" maxiters=150 maxsteps=10000 annotate=status
    dcOpInfo info what=oppoint where=rawfile
    subckts info what=subckts  where=rawfile
    save R19:1 L21:1 V8:p
  • Tawna
    Hi Hamid, The first thing you need to do is upgrade your MMSIM software to MMSIM12.1.1 or later. There have been a number of notable improvements since then in the algorithms and interface. Best regards, Tawna
  • Tawna
    Hi Hamid, Please see this blog... It talks about the improvements to nport starting in MMSIM 12.1. http://community.cadence.com/cadence_blogs_8/b/rf/archive/2012/11/19/spectre-rf-mmsim-12-1-preview-of-coming-attractions
  • HamidKhatibi
    Hi Tawna
    Thank you again.
    Unfortunately it is not possible for me to upgrade MMSIM. What do you think about those different outputs (PSS hb and Transient)? (The output power are 2.5dBm and 5.7dBm which are seriously different and unfortunately the optimum load is totally different for them, so I have to know which one I can trust more.)
    Hamid
  • Tawna
    Hi Hamid, I'm not sure if you are in the US or another country. Your University should have a program with Cadence where you can file a Case with Cadence Online Support. That way a Support AE (or myself) can take a look at your testcase. Without the actual data, it is difficult to say for sure - and I really hesitate to make a suggestion without seeing the s-parameter data. Many of the improvements in MMSIM12.1 and later releases are geared toward improving simulating s-parameters in transient analysis. For MMSIM 11.1, please see this article on how to set your nport parameters: http://community.cadence.com/cadence_blogs_8/b/rf/archive/2011/03/23/my-favorite-nport-settings But honestly, you really need to use a later version of code or have a Cadence Support AE take a look at this.
  • HamidKhatibi
    Hi Tawna
    Actually I am a PhD student at Cornell university (Ithaca, NY) but we do not have this luxury here at Cornell!
    Is there anything that I can send you so you might be able to help me?
    BTW, I have read the mentioned article more than once and thank to your suggestions in that note I think that I have used the best settings that I could.
    Thank you again,
    Hamid
  • Tawna
    Hi Hamid, Good news.... Cornell is a Cadence University Program Member. Details are on the Cornell website: http://www.ece.cornell.edu/ece/about/cadence.cfm Please contact the person at the bottom of the website page or contact your department chair to gain access to Cadence Online Support. Unfortunately, I cannot help over the community forum. (Several Cadence AEs answer questions here "outside of our normal work responsibilities." To get specific help, you need to contact Cadence Customer Support.)
  • HamidKhatibi
    Thank you very much for all your support.
    I had already asked people around and they did not know  this, even the professors. I will try that.
    Hamid
  • Tawna
    If you are in the EE department (I also have names if you're in the physics dept). Contacts for Cornell University - EE are:
    Licensing Professor: Carlos Otero
    Primary Tech Liaison: Dora Abdullah
    Secondary Tech Liaison: Doug McCool
