  2. RF Design
  3. avoiding "hidden model in spectra rf" for verilog A integrator...
  • Subscribers 63
  • Views 2056
avoiding "hidden model in spectra rf" for verilog A integrator code
big joe
big joe over 11 years ago
hi all ,
i am new in verilog a , and i had a problem while i was trying  to simulate an ADPLL simulation with the pss analysis .
as you may know the "loop filer"  in adpll i implement with an integrator  on the phase, and since that i got an "hidden model" error .
i wonder if some of you can help me to fix my code, such that it will avoid form hidden model error ,or show me a better way to do it.
the error is on " accump1" which is important to me
thanks everybody.
my code:
 `include "constants.vams"
`include "disciplines.vams"
 module dig_loop(ick_refclk, i_pe_tdc, o_fine,);
  input                   ick_refclk;
  electrical              ick_refclk;
  input                   i_pe_tdc;                   // quantized Phase Error
  electrical              i_pe_tdc;                   // quantized Phase Error
  parameter real          pe_offset    = 0;
  parameter real                  i_prop_coeff = 1;
  parameter real          i_int_coeff  = 1/16;
  parameter real          i_kpscale    = 1;
  parameter real          i_kiscale    = 1/16;
  parameter real          vccd         = 1.00;
 real              pe, pe_ki, pe_kp, p1, accum_p1, big_reg, fract_int;
  integer       i, fine_int_lim, fine_int, frac;
  real          kp_scale_int, ki_scale_int, clk_cnt;
analog begin
                @(initial_step)
                begin
                                accum_p1 = 64;
                                clk_cnt = 0;
                end
                pe = V(i_pe_tdc);
                ki_scale_int = (clk_cnt > 32) ? i_int_coeff : i_int_coeff + i_kiscale;
                kp_scale_int = (clk_cnt > 32) ? i_prop_coeff : i_prop_coeff + i_kpscale;
                pe_ki      = pe * ki_scale_int;
                p1         = pe_ki + accum_p1;
                pe_kp      = pe * kp_scale_int;
                big_reg    = ((pe_kp + p1)<0) ? 0 : (((pe_kp + p1)>(127.984375) ? 127.984375 :(pe_kp + p1)));
                fract_int  = $floor((big_reg-($floor(big_reg)))*64);
                fine_int   = $floor(big_reg);
                frac       = fract_int;
                @(cross(V(ick_refclk)-vccd/2,+1))
                begin
                                accum_p1 =  (p1 < 0) ? accum_p1 : ((p1 >= 128) ? accum_p1 : p1);
                                clk_cnt = clk_cnt + 1;
                $debug("At time %fpS:pe=%f, big_reg=%f, fine_int=%d,fract_int=%f p1=%f, pe_kp=%f, pe_ki=%f,kp_scale_int=%f " ,$abstime*1e12, pe, big_reg, fine_int,fract_int, p1, pe_kp, pe_ki,kp_scale_int);
                end
//************************ OUTPUT ASSIGNMENT ********************************
                V(o_fine) <+ transition(fine_int, 0, 20p, 20p, 20p);
end
endmodule
    Rather than me re-writing your model for you, better to point you at an explanation of "hidden state" together with some examples of how to overcome it: Hidden state in SpectreRF
