  2. RF Design
  3. ERROR (LBRCXM-644): Bad return status from RCX script generator...
  • Subscribers 64
  • Views 15411
ERROR (LBRCXM-644): Bad return status from RCX script generator. 0x100
Shaa
Shaa over 10 years ago
Dear Friends,
I would like to extract a VCO layout, but I have a problem with Assura QRC.
I use: Cadence (IC6.1.5-64b.500.13), Spectre (12.1.1.164.isr15), Assura (4.1_USR1_HF13)
And this is Log file:
Cadence Extraction QRC - 64-bit Parasitic Extractor - Version 9.1.4-p003
Thu Sep 16 19:40:00 PDT 2010
Copyright 2010 Cadence Design Systems, Inc.
INFO (EXTQRCXOPT-249) : For Assura inputs, if the "output_setup -directory_name" option was not
specified, it is automatically set to the input directory.
INFO (LBRCXU-108): Starting
/opt/assura//tools/assura/bin/rcxToDfII /home/testuser/cds/spice/SG13SLBE_09/work/testuser/cds/Assura/VCO24_23_full_cmim/__qrc.rcx_cmd -t -f /home/testuser/cds/spice/SG13SLBE_09/work/testuser/cds/Assura/VCO24_23_full_cmim/extview.tmp -w /home/testuser/cds/spice/SG13SLBE_09/work/testuser/cds/Assura/VCO24_23_full_cmim -cdslib /home/testuser/cds/spice/SG13SLBE_09/work/testuser/cds/cds.lib
Virtuoso Framework License (111) was checked out successfully. Total checkout time was 0.07s.
@(#)$CDS: rcxToDfII_64 version av4.1:Production:dfII6.1.3-64b:IC6.1.3-64b.500.15 10/08/2010 03:19 (sfrop004) $
sub-version 4.1_USR1_HF13, integ signature 2010-10-08-0235
run on master from /opt/assura/tools.lnx86/assura/bin/64bit/rcxToDfII on Mon Jan 12 12:18:12 2015
SG13S SiGe:C-BiCMOS Library, Init rev. 90401 (30.04.2009), GGa
InitAddons rev. 90401 (30.04.09), GGa
INFO (LBRCXU-114): Finished /opt/assura//tools/assura/bin/rcxToDfII
INFO (LBRCXM-642): Constructing the RCX run script
INFO (RCXSPIC-27050): Could not open file /home/testuser/cds/spice/SG13SLBE_09/work/testuser/cds/RCXspiceINIT for reading
INFO (LBRCXM-709): ***** QRC terminated abnormally *****
I will be thankful, if you have any idea about it.
Shaa
  • MohsenShah
    MohsenShah over 7 years ago
    Did you find the solution for this Shaa? I face the same problem.
    Andrew Beckett over 7 years ago in reply to MohsenShah
    The QRC version that was being used above is ancient - hopefully you're using something more recent? If it's a problem with current versions you should contact customer support so that we can investigate properly with visibility of all the relevant information; it would be very hard to share that in a public forum.
