  2. RF Design
  3. RCX Error
  • Subscribers 63
  • Views 16960
RCX Error
analogy
analogy over 10 years ago
Althought it seems like a licensing error, I really don't know what wxactly is the reason for that :
            Assura (tm) Physical Verification Version av4.1:Production:dfII6.1.3:IC6.1.3.500.10
            Release 4.1
Copyright (c) Cadence Design Systems. All rights reserved.
@(#)$CDS: assura version av4.1:Production:dfII6.1.3:IC6.1.3.500.10 06/09/2009 14:40 (sfrh259) $
sub-version 4.1, integ signature 2009-06-09-1330
run on [machine] from /apps/cadence/ASSURA41/tools.lnx86/assura/bin/32bit/assura on Wed Feb 18 23:05:00 2015
Checking out 1 license for Assura_RCX 3.10
ERROR (LMF-02096): License call failed for feature Assura_RCX, version 3.100 and quantity 1. The license server search path is defined as [license server location]. The FLEXnet error message is as follows,
    FLEXnet ERROR(-96, 0, 0): License server machine is down or not responding.
Run 'lic_error LMF-02096' for more information.
ERROR (LMF-02096): License call failed for feature Virtuoso_QRC_Extraction_L, version 3.100 and quantity 1. The license server search path is defined as 5[license server location]. The FLEXnet error message is as follows,
ERROR (LMF-02096): License call failed for feature Encounter_QRC_Extraction_L, version 3.100 and quantity 1. The license server search path is defined as [license server location]. The FLEXnet error message is as follows,
Starting /apps/cadence/ASSURA41/tools/assura/bin/rcxToDfII /home/sh/shah6834/st50/rcx.test.rsf -t -cdslib /home/sh/shah6834/st50/cds.lib
@(#)$CDS: rcxToDfII version av4.1:Production:dfII6.1.3:IC6.1.3.500.10 06/09/2009 14:46 (sfrh259) $
run on [machine] from /apps/cadence/ASSURA41/tools.lnx86/assura/bin/32bit/rcxToDfII on Wed Feb 18 23:05:23 2015
*WARNING* Technology must be specified!
Loading gpdk045/libInit.il ...
    Loading gpdk045/loadCxt.ile ... done!
    Loading context 'gpdk045' from library 'gpdk045' ... done!
    Loading context 'pdkUtils' from library 'gpdk045' ... done!
    Loading gpdk045/gpdk045_customFilter.il ... done!
    Loading gpdk045/libInitCustomExit.il ...
    Loading Environment Settings ...
*WARNING* Cannot find /apps/cadence/ASSURA41/tools.lnx86/dfII/etc/tools/spectre directory to load environment variables
*WARNING* envSetVal: could not find tool[.partition] 'spectre.envOpts'
*WARNING* Cannot find /apps/cadence/ASSURA41/tools.lnx86/dfII/etc/tools/hspiceD directory to load environment variables
  *              Cadence Design Systems, Inc.                 *
  *                    Generic 45nm PDK                       *
  *                        (gpdk045)                          *
    VERSION: 2.0
done!
Loaded gpdk045/libInit.il successfully!
*WARNING* envSetVal: could not find tool[.partition] 'hspiceD.envOpts'
Finished /apps/cadence/ASSURA41/tools/assura/bin/rcxToDfII
Starting /apps/cadence/ASSURA41/tools/assura/bin/avRCXxref /home/sh/shah6834/st50/rcx.test.rsf
@(#)$CDS: avRCXxref version av4.1:Production:dfII6.1.3:IC6.1.3.500.10 06/09/2009 14:41 (sfrh259) $
run on [machine] at Wed Feb 18 23:05:28 2015
Reading rsf
Finished /apps/cadence/ASSURA41/tools/assura/bin/avRCXxref
Constructing the RCX run script
Could not open file /home/sh/shah6834/st50/Dependencies/assura/RCXspiceINIT for reading
*WARNING* Bad return status from RCX script generator. 0x100
    Did you mean to be using Assura RCX rather than QRC? I'm not sure that's the reason, because the error message is quite clear. Did you try doing:
    lmstat -f Assura_RCX -c 5280@licenseserver
    where the 5280@licenseserver is the bit that it reported as "license server location" in the error message? (typically this should be whatever the value of $CDS_LIC_FILE is, or failing that, whatever $LM_LICENSE_FILE is).
  • analogy
    SYNTAX ERROR found at line 1 column 30 of file *ciwInPort*
    *Error* lineread/read: syntax error encountered in input
    lmstat -f Assura_RCX -c 5280@[license domain]:/apps/cadence/license-current
    SYNTAX ERROR found at line 2 column 30 of file *ciwInPort*
    SYNTAX ERROR found at line 3 column 30 of file *ciwInPort*
    SYNTAX ERROR found at line 4 column 30 of file *ciwInPort*
    SYNTAX ERROR found at line 5 column 30 of file *ciwInPort*
    SYNTAX ERROR found at line 6 column 30 of file *ciwInPort*
    SYNTAX ERROR found at line 7 column 30 of file *ciwInPort*
    SYNTAX ERROR found at line 8 column 30 of file *ciwInPort*
    SYNTAX ERROR found at line 9 column 30 of file *ciwInPort*
    SYNTAX ERROR found at line 10 column 30 of file *ciwInPort*
    SYNTAX ERROR found at line 11 column 30 of file *ciwInPort*
    SYNTAX ERROR found at line 12 column 30 of file *ciwInPort*
  • analogy
    Oh, yes.We still use RCX as most of us are used to be using RCX.
    The lmstat was a UNIX command not a SKILL command, and so it has to be entered in a UNIX terminal. I mistakenly assumed that was obvious. The use model for QRC is essentially the same as for Assura RCX, so there is no good reason to keep using technology that has been obsolete for about 10 years and hasn't had any of the fixes in the intervening years... you just need to have a (recent) EXT release installed and in your path.
  • analogy
    [shah6834@eecad17 ~]$ lmstat -f Assura_RCX -c 5280@[license server domain]:/apps/cadence/license-current
    lmstat - Copyright (c) 1989-2011 Flexera Software, Inc. All Rights Reserved.
    Flexible License Manager status on Fri 2/20/2015 22:07
    License server status: 5280@[license server domain]
    License file(s) on [license server domain]: /apps/cadence/license-current:
    [license server domain]: license server UP (MASTER) v10.1
    Vendor daemon status (on [license server domain]):
    cdslmd: UP v10.8
    Feature usage info:
    verplex: The desired vendor daemon is down. (-97,29)
    That suggests you simply do not have the Assura_RCX license feature in your license file. Hence the problem...
    Maybe it really is time to move to QRC? Perhaps you can look in the license file itself to see what  you've got (or do lmstat -a -c 5280@...)?
