  2. RF Design
  3. Printing pnoise summary from an ocean script
  • Subscribers 63
  • Views 15168
VishTI
VishTI over 11 years ago
I want to print a noise summary after running noise analysis where I want to sort the top 50 noise contributors but sort them by their composite noise.
I only see the following options in the oceanref documentation for noisesummary and I do not see an option to sort by composite noise. How do I do this using ocean?
noiseSummary(s_type [?result s_resultName [?resultsDir t_resultsDir]]
[?frequency f_frequency] [?weight f_weight] [?output t_fileName | p_port]
[?noiseUnit t_noiseUnit] [?truncateData x_truncateData]
[?truncateType s_truncateType] [?digits x_digits]
[?percentDecimals x_percentDecimals] [?from f_from] [?to f_to]
[?deviceType ls_deviceType] [?weightFile t_weightFile]
[?paramValues ls_paramValues])
Regards.
Vish
    Hi Vish,
    I filed an enhancement CCR on your behalf - 1377958. At the moment this is only possible using the underlying private SKILL function (which doesn't have such a convenient interface, so I don't want to advertise it), but it should be pretty straightforward to add to noiseSummary().
    Kind Regards,
