  2. RF Design
  3. Parametric Analysis over EM Simulated S-parameter Data
  • Replies 11
  • Subscribers 64
  • Views 26317
HamidKhatibi
HamidKhatibi over 11 years ago
Hi
I have employed HFSS to Em simulate some designed transmission lines with different lengths. Now I use them in Cadence-Virtuoso in NPORT and it works easily. I have named the data files such as TL100, TL105,TL110, ... and I have completed the sweep for 5u increment.
The problem is that I need to be able to sweep over these TLs. i.e. I want to be able to use ADE-L>Tools>Parametric Analysis in order to sweep over the existing lengths of the transmission line. However, in NPORT I have to type the full name of my data file and hence I have no idea how to do that.
Is there any way to do this kine of sweeping?
Hamid
  • Tawna
    Tawna over 11 years ago
    Hi Hamid,
    It sounds like you want to parameterize the filename for an nport in ADE/OCEAN and use it in parametric analysis.
    1. There is Article 11021266 on Cadence Online Support (http://support.cadence.com) that discusses one way to do this using a custom netlist procedure.
    2. Article 20040165 on Cadence online support describes a different way to do this.  (Note:  I have not personally tried this method.)
    The "VAR" function in IC615/616 does not work for the nport component and there is no easy way to define nport file name as a variable. However you can create a subcircuit around the nport and treat the nport as a primary device. For this primary device, you could define a model with sections for this nport. For each section, you could define a nport with unique file name. When you do simulation, just treat this nport the same as model files and switch to different sections accordingly in either ADE or ADEXL.
    ++++++++++Example for 2 port s-parameter files: (nport_model.scs)+++++++++++++++++
    simulator lang=spectre
    library nport_wrapper
    section FF
    subckt nport_wrapper n1 p1 n2 p2
    n1 (n1 p1 n2 p2) nport thermalnoise=yes file="fastfast.sp2"
    ends nport_wrapper
    endsection FF
    section SS
    n1 (n1 p1 n2 p2) nport thermalnoise=yes file="slowslow.sp2"
    ends nport_wrapper
    endsection SS
    section TT
    n1 (n1 p1 n2 p2) nport thermalnoise=yes file="typicaltypical.sp2"
    ends nport_wrapper
    endsection TT
    endlibrary nport_wrapper
    best regards,
    Tawna
  • HamidKhatibi
    Thank you very much Tawna for your quick response.
  • Frank Wiedmann
    Frank Wiedmann over 11 years ago
    I have successfully used the following workaround to define the nport file name as a variable: Leave the field "S-parameter data file" empty and enter file=filename in the field "Additional parameter list" (under "Rarely used parameters"). Then define a variable named filename; the value of this variable is the path to your S-parameter data file with quotes around it ("..."). Of course, you can also use a different name for the variable, it just has to match the name in the "Additional parameter list".
    One other thing that I meant to mention after seeing Tawna's response, and the same for Frank, you can't do a sweep of string values in the ADE L Parametric Analysis tool. You can do it in ADE XL though (either as a global variable, or as a corner).
  • HamidKhatibi
    Thanks Frank.
    This way, you cannot sweep, can you?
  • HamidKhatibi
    Thanks Andrew.
    Would you please elaborate more on how to do it in ADE XL ?
  • Frank Wiedmann
    Like Andrew mentioned, you can't do it in ADE L, but you can do it in ADE XL (use an Inclusion List for a global variable or define corners with the desired variable values).
  • HamidKhatibi
    Thanks Frank. I have no much experience with ADE XL. It seems that I have to try it though.
  • Litstbl
    Litstbl over 10 years ago
    Hi Frank, this option seems to be not available anymore, with latest version of Cadence. Is that true? This is actually a very useful feature, is there any other solution now? thanks!
  • Frank Wiedmann
    Frank Wiedmann over 10 years ago
    Do you have an example that works with an older version but does not work with the latest version? What versions exactly are you talking about?
