  2. RF Design
  3. oscillator jitter measurement(jc , jcc)
  • Subscribers 63
  • Views 10641
analogdesign
analogdesign over 11 years ago
Hai sir,
        I am simulating the LC VCO at a free running frequency of 5GHz.
PSS settings: Beat frequency - 4.5GHz, number of harmonics - 10, tstab=100n
pnoise settings: pss beat freq - 4.5GHz, sweep type - relative, sweep range 100k to 2.5GHz, max sidebands -10, noise type-jitter
are the above pss and pnoiose settings correct
I am getting the phase noise of -78dBc/Hz at 1MHz offset. the measurement of jitter jc gives 157fs
for measuring jcc what  must the value of k.
Is the setting noise type-jitter correct, if it is wrong which one we have to choose(source, modulated).
please help
thank you
satya
    ShawnLogan over 11 years ago
    Dear satya
    What is your objective? Why is your beat frequency 4.5 GHz when the oscillator frequency is 5 GHz?
    Jcc is the cycle to cycle jitter. This value is dependent on the number of cycles of the output signal over which it is measured. Hence, one must specify the number of cycles to measure Jcc.
    I am sorry for my vague answers and additional questions, but I am not clear what your actual simulation objective is and your expected result.
    Shawn
  • analogdesign
    hai
    thanks for your reply.
    Objective is to measure the jitter of the oscillator. which one to choose, jc or jcc. if jcc what must be the value of k.
    reference freq=50MHz, Oscillator freq=5GHz
    from transient analysis i get the oscillator frquency as 5GHz, but from pss and pnoise it is 4.92GHz.
    the value of beat frquency chosen can be less than 5GHz.
    thanks
    satya
    Dear satya,
    Thank you for the additional information- it is helpful in trying to answer your questions!
    The jitter measurement you are interested in is dependent on your application. For example, if the clock serves to access data from a memory device, the cycle to cycle jitter may be most important (jcc). Note that jcc is not dependent on the accuracy of the clock period from any specific reference clock. It is considered a short term jitter measurement. Jc is the k cycle jitter and is a measure of the difference in time between k cycles of the waveform and a single cycle time and is expressed as standard deviation. The value of k specifies the number of cycles over which the measurement is made. It is considered a "long term" jitter measurement. The value of k you choose is a function of what your oscillator is driving. The larger values of k (1000, 10,000,...etc) provide more certainty in your estimate of jcc or jc.
    If the clock serves as a reference for a frequency synthesizer, its long term and short term jitter is more important. The latter can be characterized more readily by integrating the phase noise characteristic over the specific frequency range of interest.
    I hope this helps your understanding.
    from transient analysis i yget the oscillator frquency as 5GHz, but from pss and pnoise it is 4.92GHz.
    The difference you observe in frequency may be due to incomplete settling of your transient simulation or an inaccurate oscillator period measurement (for example measuring the frequency over too short a time or including the settling portion of the oscillator in your measurement period).
    Shawn
