  2. RF Design
  3. Inductor Flattening
  • Subscribers 63
  • Views 14207
Inductor Flattening
analogy
analogy over 10 years ago
So, I am using gpdk045 (ind_a) and when I was faletting my ind_a layout cell, I came across this warning -
*WARNING* (BND-2005): Layout instances and terminals do not match the source.
Use 'XL Status' in the Navigator or run 'Connectivity - Check - Against Source' for more details.
If the bindings are correct, run the 'Update from Source' commands,
otherwise run 'Connectivity - Update - Binding'.
INFO (LX-1063): Building the layout generation form...
INFO (LCE-1009): The cell verifier found no violations.
*WARNING* (LE-103805): The Flatten command does not support PR boundary objects. These objects will not be
flattened.
What does this mean ?
    Not sure it makes much sense to be doing the flattening in VLS XL anyway, but even so, I don't see this at all. The ind_a I'm using (from gpdk045 v4.0) doesn't have a prBoundary - so I can't see why it would give this error. I tried gpdk045 v3.5 too - also no issue.
    The other messages are just normal VLS XL messages saying that your schematic and layout don't match (not surprising if you've flattened it).
